Question about RCA R52WH73 Projection Television
AUTO CONVERGENCE PROBLEM
I HAVE A CONCAVE PICTURE WITH ALL 3 COLRS MIS-ALGINED
  • Anonymous Oct 01, 2008
    My TV will be three in November. The picture is contoured and the red, green and blue are overlapping each other.
  • anunciatel Apr 07, 2009
    I hav the same problem, but I don't find a solution! The manual says is very easy to fix. But... the option needed un the configuration menu it in't.
  • RCA Master
  • 8,617 Answers
You need the convergence power supply board. you can get one at the following link.
http://servicemanuals.vstore.ca/
Posted on Aug 10, 2008
Picture appears concave and doubled
Most likely scenario is that the auto convergence option has disappeared which will cause the set to have an arced picture with double images. You can get the RCA repair kit called ITC222 & ITC222A convergence option missing repair kit from www.tvrepairworld.com which has the replacement parts and the CD with instructions.
Jul 31, 2010 | RCA HD52W56 52" Rear Projection HDTV
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
Tv picture looks warped
I am Vortash this is a problem we call pincushion where the picture appears bowed or concave . It is a fault associated with convergence problems also green or red lines around people and objects if this is the case on your set try your manual and look up the proceadure for the auto convergence , if you do not have a manual try downloading one from http://www.safemanuals.com for free most likely but there are a few of the more later models they charge for hope this helps regards Vortash
Jun 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Picture on projection screen is concave in the middle
This set does not use IC's for convergence. Most other brands do use IC's.They use individual transistors in this one and honestly I don't remember ever seeing these go bad. Normally it is the power supply that runs the convergence transistors or more commonly known as the convergence board. It gets pretty technical with this type of problem. Have a repair shop check it out for you and avoid the headache. Thanks
Jun 07, 2009 | RCA P61939 61" Rear Projection Television
Colors split on my ony rear projection tv
If by a color split, it looks like a 3-D picture, the problem is in the convergence circuit. Since it recovers on its own, it suggests to me that there is a poor solder connection at the convergence ICs. If you can solder, this should be a simple repair. Locate the convergence ICs (large black ICs attached to a heat sink that should be marked STKxxx). Resolder the pins on both ICs. If that does not resolve the problem, let me know.
Dan
Dec 21, 2008 | Televison & Video
Picture Problem
I have the same situation. Called my repairman, who knew exactly that it needed a "570 kit" . It will be repaired this week. Cost $360
Sep 26, 2008 | Mitsubishi WS-65809 65" Rear Projection...
By the picture that you have supplied with the question you have a rear projection tv. The problem you are describing sounds like you have had the convergence module in your tv fail. Depending on the age and make of the tv, the repair costs ( if out of warranty ) can be prohibitive. The convergence module on rear projection tv's not only is in charge of bringing the 3 different color images together into a watchable picture but also handles the east west correction ( concave / convex aspect to the picture or lack there of ).
Jul 02, 2008 | RCA R52WH73 Projection Television
Picture has 3 images, all different colors (red-blue-green) screen looks concave in the middle top & bottom
This is what is known as convergence..(very common)... first question DO you have the "CONVERGENcE" option in your setup menu?.... if you dont there may be a special fuse issue... if not then more than likely it is what is known as convergence power supply issue. you have complete loss of convergence?
Jun 01, 2008 | RCA D52W19 52" Rear Projection Television
My RCA Tv has a concave picture!!!
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Dec 21, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA R52WH73 Projection Television Logo
113 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
