Question about Now Software Now Up-to-Date & Contact (NUM40E23A)
I saw the question above but not the resolution. I keep getting the same error: Cant open file due to a preference file not being created.
    Scholar:
  • 92 Answers
1) Make sure you know where your primary contact file is stored on your hard drive. You'll need to know where it is to set it as your primary file again at the end of this process.
2) Quit Now Contact (if it is running).
3) Open a new Finder window and select Home from the Go menu.
4) Once in your Home folder, go to: /Library/Preferences/
5) Find the file named com.poweronsoftware.nowcontact.plist and move it to the desktop.
6) Find the folder named Now Contact Prefs and move it to the desktop as well.
7) Open your Now Contact file and make it your primary contact file (Launch Now Contact, open the File menu, select Open, make sure there is a checkmark next to the option "Make this my primary file," locate your Now Contact file, highlight it and click Open).
Cool Trash the items moved to the desktop in steps 5 and 6.
Posted on Apr 06, 2011
Testimonial: "perfect. Thank you so much."
Huge files of page maker 6.5 was kept in local drive F, when i tried to open the said files it does not open and show that this format cannot open with this application.
Try re-creating the preferences of your pagemaker software by following the mentioned steps: (Steps are mentioned considering you have Windows XP installed)
1. Close PageMaker id its running
2. Open the Program Files/Adobe/PageMaker 6.5/Rsrc/Usenglsh folder.
3. Rename thefollowing files (for example, to Pm70old.cnf):
-- Pm70.cnf
-- Pm70filt.cnf
-- Pm70ppd.cnf
-- PStyles.cnf files
4. Start PageMaker. It will re-create preferences files.
If the problem continues, the preferences files is not the cause. To restore custom settings, delete the new preferences files and restore the original names of the previous preferences files.
See if this works and reply back.
Jun 01, 2011 | Computers & Internet
HOW TO SOLVE VFP FILE CURRUPT WHEN POWER FAILURE
At times, you may view that your MS Visual FoxPro 9.0 database is behaving abnormally. Some of the abnormal symptoms could be an error message while opening any database table, invalid characters in place of pre-defined values, and and more. The main reason for abnormal behavior of the database is its corruption due some logical crash. Few common reasons for corruption of MS Visual FoxPro 9.0 database are abnormal termination, faulty network devices, simultaneous modifications, conflicting third-party software, and incompatible service packs.
To overcome such database corruption scenarios, the user can use an up-to-date backup and perform restoration. However, restoration fails in cases where the user either forgets to create a database or the database backup itself gets damaged. In such cases, the database users can use a third-party DBF File Repair application to repair his/her corrupted database.
To illustrate the above case, consider a real-time scenario wherein you execute a query to modify your MS Visual FoxPro 9.0 database. While the query was performing the modification, the system shutdown due to power failure. However, the next time you tried to mount the database, you encountered an error message that did not allow you to access the database records. Moreover, the same error message appears every time you try to access the database.
Cause:
The root cause for the error message is MS Visual FoxPro 9.0 database corruption due to improper system shutdown.
Resolution:
The database corruption error message can be surmounted by following the below steps:
Use a complete database backup and perform restoration. However, in case of database backup unavailability, you will need to search for a commercial DBF File Repair utility.
A third-party DBF Repair application uses effective repair techniques to repair logically damaged MS Visual FoxPro 9.0 database and restore it at a new and safe location. The original database during the repair process remains intact. The tool is easy-to-understand and allows even a non-technical person to perform repair.
DBF Recovery Software is a comprehensive solution to repair databases created in MS Visual FoxPro 9.0, MS Visual FoxPro 8.0, and MS Visual FoxPro 7.0. The tool also repairs databases built in dBase III, dBase IV, and dBase V. Supported by Windows 7, Vista, 2003, XP, and 2000, the DBF Repair tool creates a new repaired file that can be attached to existing database.
Tanvi Sharma is a self employed Internet entrepreneur and product reviewer. This DBF Repair utility is extremely useful when the dBase and Foxpro database gets corrupted due to internal program errors, hardware malfunctioning, accidental deletion of data and more. This DBF Repair software repairs all types of database components including table name, column name, column data type, indexes and primary keys.
May 31, 2010 | Microsoft Visual FoxPro Professional...
I get the error message "The application preference file
In case of a Windows machine Navigate to C Drive>>Program files>>QuarkXPress folder and create a new folder by the name Preferences with P in upper case.
For Mac HDD>>Applications>>QuarkXPress folder and create a new folder by the name Preferences with P in upper case.
Now launch QuarkXPress and it should work
May 20, 2009 | QuarkXPress Passport 6.0 for Mac
Cant download music
try NOT going through media player as it tries to convert any audio. keep your files as mp3. preferably stored in "My music" file on your computer. then when you connect your psp via USB go to "open folder to view files" then open psp/music file. leave it open and open a "My computer" window my documents/my music, then just click and drag to psp/music file.
Apr 25, 2009 | Sony PlayStation Portable (PSP) Slim...
I keep getting error 1-2070
Resolution
Check to see if the required files are present:
  • Go to C:\WINDOWS\system32\kodak. Check for 2 folders "kds_aio5000(for AiO 5000 series printers) and kds_aioesp(for ESP series)
  • Depending on printer model, open kds_aio5000 or kds_aioesp.
    • For kds_espaio it should only have the lib folder. It doesn't have the ekaiowia.dll
  • Inside the lib folder it should have cct.ekpgct, hippo.dll. Both for kds_aio5000 and kds_aioesp.
  • If hippo.dll is missing then try the following:
Option 1: 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 2 Option 2: 1. Insert the Home AiO CD. Go to CD rom drive\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 3 Option 3: (manual installation) 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner or on CDROM drive ..\printer\scanner 2. Open the aioscnnr.cab file then look for the missing file(files needed: cct.ekpgct, hippo.dll, and ekaiowia.dll) Extract the files anywhere on to the computer (Desktop is preferable). 3. Copy the cct.ekpgct, and hippo.dll to C:\WINDOWS\system32\kodak\kds_aio5000\lib 4. Copy the ekaiowia.dll to C:\WINDOWS\system32\kodak\kds_aio5000
Apr 12, 2009 | Kodak ESP 5 Printer
I cant play a cideo
The viewty will play .avi (divx) and MP4 files providing the display resolution is not above 320x240. If the the display resolution is above this for either format, you will receive a "file type is not supported" error. Please be aware that the viewty CAN play Divx .avi, Xvid .avi, .3GP and MP4, but only if they are not above that resolution.
Jan 28, 2009 | LG KU990 Viewty
Adobe acrobat v7 can't open file
Do this:
1. Exit Acrobat.
2. Choose Start > Run, and type: %APPDATA%\Adobe\Acrobat\ into the Open text box. Click OK.
3. Right-click either the 6.0 or 7.0 folder, and choose Delete.
4. Start Acrobat and attempt to print.
Note:Acrobat preference files contain application settings such as toolbar arrangements. When you restart Acrobat, new preferences are created automatically based on application defaults. Deleting preference files will not result in the loss of saved documents.
Or, if u have having Quarkexpress in your machine update the version. Quarkexpress also creates PDF files, maybe this is where it was created from
Mar 14, 2008 | Adobe Acrobat 7.0 for PC
Scanning error / not enough disc space to create file
Hi again, I Think the reason you cant use Microsoft Scanner and cam's but can use Office Doc scanning, is a setting that is set incorrectly in the other program so it is making bad/too big files, probally something like file type, resolution, colour. Or it could be using wrong scanning device.
Cheers
Feb 10, 2008 | HP PSC 750 All-In-One InkJet Printer
Quark 6.5 Error code -39 in a Mac platform
in this case try creating a preferences folder under the HDD>>Applications>>quarkXPress 6.x folder and then check the results.
if it still continues then try to downsave the document to version 5 by doing a file>>save as and changing the version to 5 from there
Feb 05, 2008 | QuarkXPress
Now Software Now Up-to-Date & Contact (NUM40E23A) Logo
119 people viewed this question
Top Now Software Computers & Internet Experts
David Payne
David Payne
Are you a Now Software Computer and Internet Expert? Answer questions, earn points and help others
