Please help, the machine WHIRLPOOL AWM8142 throws an error if F11 is only possible to reset and how, or anything else I need to do .... help Google translator translated from Serbian
  • 5,911 Answers
"F11" is defined as a Serial Communications error. This is an indication of a communications problem between the Central Control Unit (CCU), Motor Control Unit (MCU), or the interconnecting wiring between the two. The following link explains:
http://www.fixya.com/support/r3608695-f11_error_code
To rule out the possibility of an erroneous program error, UNPLUG the washer for AT LEAST 30 minutes to reset the CCU. Plug the washer back in and attempt to run a program (DRAIN and SPIN is recommended since the washer has already run through a wash cycle). The washer should allow the tub to fill and run through a drain sequence, before finally doing a final spin. If the error code reappears, you know you have a legitimate problem and will need to troubleshoot.
Remove the top panel of the washer and check all the connections at the CCU, first. Remove the connectors that run between the CCU and MCU and reseat them, one at a time (refer to the tech sheet that comes with the appliance). Sometimes reseating the connector plugs can correct certain problems.
FYI: If you do determine that the CCU is the cause of the problem, some sites may carry a refurbished version that costs less than a new one.
For a full explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to accurately troubleshoot this error code.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices will vary between sites so shop and compare. The first three sites on the list include helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. If you have questions, or need additional assistance, please post back and let me know.
Read through the information provided and if you have questions, please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
Posted on Apr 06, 2011
How do I fix a F11 code on Whirlpool duet washer
Error code F11 = Serial Communication Error. Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.Aug 25, 2009
give it a try - worth unplugging and plugging back in.
Jan 29, 2018 | Whirlpool Washing Machines
Tip
Fix your F11 FDL error forever.....
STOP the insanity....that's what you're saying if you encounter the F11 and/or fDL error codes on your washer. If you're not there yet, you will be soon....
The dreaded F11 and/or fDL codes - been there done ALL that!! Our Whirlpool DUET washer is just over 5 years. We experienced our first F11 code 6 months ago (warranty just expired what else is new?). When it first happened, I thought nothing of it - hit the cancel button and the machine reset itself. Then it happened again and again and again. Each time it happened it was more challenging to reset it. I searched for the fix on line - I should have done my research before we purchased the washer.
I was able to determine the error was stemming from the CCU board. Order a new one at over $300.00 and have the same thing happen again - I don't think so. We tried EVERYTHING suggested on multiple websites.....unplugging the washer, hitting the right upper side, checking wires, wiggling the wires, wedging things to improve contacts, soldering, re-soldering, Vaseline, changed relays....anything and everything was a temporary fix. Contact Whirlpool directly? Tried that too, they apparently don't recognize there is an issue with F11 fDL errors, "not a commonly called in concern". Really?? We started searching washers to purchase....I couldn't bare spending $$$ for another washer, but we are a busy active family with 4 kids - what are our options? Then one night after searching the websites for one last desperate attempt at salvaging our washer, I followed through on a link:
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2
email: selling.surplus@gmail.com
Now, I'm the biggest sceptic in the world and the most frugal consumer - really I am. I am posting my testament to this service because I've been there - frustrated, disappointed, angry. I am so pleased with the service Ed provided - from answering all my questions, to the superb job he did on the CCU. You can review all the comments posted by all his other pleased customers on eBay. I had to stand by my washer for the first 6 loads - just in case the beep beep beeps started. To my astonishment, amazement, and surprise - it never happened!! In my opinion, this is the only true fix for your F11/Fdl error!!
I never imagined in my wildest dreams ever telling anyone how happy I am to be doing my laundry again, but I really am!!
on May 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    When starting a cycle the door locks then immediately unlocks and throws an f11 code could it be a door r lock problem instead of the CCU
    F11 is a communication error between main board and control unit..
    check all plugs are firmly fitted (best to unplug and refit each one).
    but usually it is the main Pcb..
    Aug 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    Ghw9150pw2 My 2006 Whirlpool Duet washer is showing an F11 code. It will run a small amount of water initially, but then stop and throw the code. It was ran a few loads successfully one night, and the next...
    The F11 code indicates that there is a communication error between the motor or MCU and the CCU (central control unit or clock). To reset the washer and try again, press Pause/Cancel twice. Then press Drain/Spin. Then try setting up to run a load.
    If the error recurs, you need to check the wiring harnesses and connectors between multiple components, check for wear at the motor bearings and other drive components. Then next components to check are the MCU (motor control unit) and the CCU. This may be a good time to get a technician to check out the unit.
    I hope this helps.
    Oct 26, 2013 | Washing Machines
    Have whirlpool duet that kept giving f11 code I replaced front control panel and still giving code. Do I need to reset after installing and how or does problem exist in main computer
    This seems to be a communication error and it is possible that there is harness issue from the main panel to the motor panel. remove and reset the connections.
    Please check this link for error codes for the machine
    Jan 18, 2013 | Washing Machines
    Error message E11
    May 11, 2010 | Washing Machines
    Hi. Whirlpool washer (Duet front load) GETS F11 error code. Any ideas as to the cause and repair?
    Pull off bottom panel, there should be a schematic and trouble shooting guide to help you through any questions about you fault code.
    Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Keep getting f11 error on
    Click on the following link for an explanation of the "F11" error code:
    http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
    If you require additional assistance, please let me know. I hope this helps you.
    Jul 09, 2008 | Whirlpool Washing Machines
    F11 error
    Click on the following link for advice on how to troubleshoot and diagnose the "F11" Error.
    If you require further assistance, or need help in locating parts, please post back and let me know. I hope this is helpful to you.
    Jun 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    73 people viewed this question
    Top Washing Machines Experts
