Windows XP Pro will not boot up after installing Goflex external hard drive. I have disabled Legacy USB and reset boot drive order to my drive as first.
    Guru:
  • 868 Answers
Hi oysjerry,
I see that you are experiencing a no boot issue after you installed your Goflex external HDD. before doing the options below, you can try booting into windows but do no connect your external Hard Drive on the system.
  • Keep on tapping f12 upon powering the system to get into the Boot menu screen then select you hard drive in the machine then press enter to boot to it.
  • If it boots into you internal hard drive after doing the Boot menu option then you do the last option provided.
  • Try changing the BIOS setting, check the Boot sequence if boot to other devices is the first boot priority then change it to your internal hard drive in the machine.
this should fix you concern,
if still this does not boot into windows
Posted on Apr 07, 2011
My seagate freeagent goflex 1tb hdd appearing as local disk in my computer... the autoplay dialog window doesn't come up when the drive is connected..
AUTO PLAY DIALOGUE IS OFF IN YOUR OPERATING SYSTEM
ENABLE AUTO PLAY
WHAT OS YOU ARE USING
OR CHECK BELOW LINKS
Windows 7, Windows Server 2008, Windows Vista, Windows Server 2003,or Windows XP
Fix it for meTo disable or enable Autorun automatically, click the appropriate Fix this problem link. Then, click Run in the File Downloaddialog box and follow the steps in this wizard.
Disable AutorunEnable Autorun
Fix this problem
Fix this problem
Oct 29, 2013 | Seagate FreeAgent GoFlex Desk - 1 TB...
The Samsung Freeagent GoFlex external hard drive is not recognized by Windows 7 OS. I tried to initialize disk under computer management / storage / disk management and got the cyclic redundancy check...
This is a good read on what this error actually means:
http://www.softwarepatch.com/tips/cyclic-redundancy.html
What I recommend is reformatting the drive under Computer Management, and seeing if that fixes the problem.
May 03, 2011 | Seagate FreeAgent GoFlex Pro 500 GB USB 20...
Just bought the GoFLex Pro 750 GB. I have two PCs, both on XP... neither can see the HD via my computer... I have done a check via computer managment and it says the HD is fine... but it is not...
Hi, Thanks for using fixya.
Try this go back in disk management right click on the disk assigned to your GoFLex Choose change drive letter and paths. After you make the change go back in My Computer and see if you can ues it.
Terry
Feb 17, 2011 | Seagate FreeAgent GoFlex Pro 750 GB USB 30...
My WDBAAU0015HBK external harddrive don't boot when i start up my computer. It says initalising USB divices and then when it autodetect the USB mass storage devices it stops. In the BIOS i put the boot...
It sounds like the BIOS is set to auto-boot from the USB device.
Have you reset the 'boot order' in the BIOS?
Also if you are still running sp2 go to Microsoft update and install the updates. You should be running on service pack 3.
(the updates are free, and are more secure than sp2)
Jul 20, 2010 | Computers & Internet
Windows Server trying to boot from external hard drive
go into your 'update settings'. there is a section of where it asks you about how you want your settings set and where to send updates to. You may find the problem here. Check all the 'advanced' settings as well. If your Western digital is plugged in via USB and not requiring updates, unplug it while starting your system, after complete start up, reinsert the USB plug. It may show new devise found, then from here, you may be asked to reinstall it to stop the rebooting.
Aug 24, 2009 | Western Digital My Book Essential Edition...
Windows Vista does not boot with hard drives plugged in
You've cross-posted your request. I'm linking the other post since I'munsure of which is the most recent, or which I should respond to.
Here.
Now, as far as your boot setup being fine, the other possibility is that windows, in its great wisdom, cannot get its head around a Plug and Play device and Device detection at the same time, both of which are services.
1> Go Start -> Control Panel -> ( under Performance) Admin Tools -> Computer Mangement
2>After opening the computer manager, you'll see three explorer brancheson the left of the util, the last will be Services and Applications.Click the + next to it to expand it if needed.
3>Under Services and Apps, click on Services in the left explorer panel.
4>It should show several services to the right hand side. Find: "Shell Hardware Detection"
4.1>right click on the entry and then Properties.
4.2>Oncein properties, make sure you're in the "General" tab. Once there, apop-down field next to a label of "Startup type" is where you want tochange it to Manual.
5>Restart computer with external HD plugged in and check whether or not it starts up.
6>If problem persists, Repeat #4.2 but instead of setting the service startup to Manual, set it to Disabled.
*Setting the service to manual or disabled will stop autoplay hardware events. I.e. inserting a cd in a cd drive will not automatically pop up to play it, sticking a USB flash thumb drive in will not automatically respond, etc. You will need to access these devices directly in whatever fashion the device dictates.
- If there is a new problem, please repeat the steps above, but reset the service Startup Mode to Automatic.
*Also please note that you do not have to do a hard restart in order for the windows initialization to continue, in my experience. Simply unplugging the USB storage device allows windows to start up.
If, in fact, unplugging the device does not allow windows to continue initialization, please state so again.
Dec 14, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book freezes computer on boot up.
Mine boots fine if I unplug (better yet, hold the flat button down on the back for about 5 seconds, and it will turn off).
Aug 31, 2008 | Western Digital My Book Essential Edition...
Computers & Internet Logo
482 people viewed this question
David Payne
David Payne
