Question about Timex Pedometer Calorie Counter 5E021 Pedometers Stopwatches
Pedometer setup instructions Step by step the pedometer instructions Basic style pedometer
How do I adjust the step setting on a new haven pedometer
You didn't indicate what model you have. Here's the instructions for a model 230 - 100 mile pedometer.
Oct 06, 2016 | Cars & Trucks
Good afternoon, My 4202 pedometer does not show accurate number of steps even when I actually count the step while walking. Some day it's fine, but most days it's way lower that what it should show.
well, all your steps are not measured exactly the same... from hour to hour.. they are different. and hen even more from days to day they are different. your mood is different thus having an effect on your strides. so unfortunately any step machine can only guesstimate your steps. I suggest reviewing the setup you used to measure each step.. and go thru that again... you might need to re-enter the your step size. I really hope that helps.
Aug 11, 2016 | Exercise & Fitness
How do I reset the time?
How to Configure Your Omron HJ-303 Pedometer
www.walking4fun.com/.../pedometers/...pedometer/how-to-configure.ht...
When your pedometer first comes out of the box, you'll need to configure it. When youchange the battery, you'll have to reset the time on your pedometer, but the ...
[PDF]Getting Started: Setting Up Your Pedometer
www.whoi.edu/fileserver.do?...
Woods Hole Oceanographic Institutionyour pedometer and walk your way to better health. Pedometer Setup ... down theRESET button. Additional ... you'll track steps, time, and miles throughout your daily routine. And, in ... Do the math: 20 divided by the number of steps equals.
How to Reset an Omron Walking Style Pedometer ...
www.livestrong.com > Sports and Fitness
Oct 28, 2015 - Your Omron pedometer is a fitness accessory used to provide a great amount of ... session, including steps taken, time walked, distance traveled and calories burned. ... Do not use the end of a pencil to perform a system reset.
Dec 14, 2015 | Exercise & Fitness
I have a new sportline belt clip pedometer. It has 3 buttons: mode,set and r/s. How can the length of stride be entered into it so an accurate mileage reading is possible?
I have an older Sportline pedometer with the same three button arrangement.
My pedometer is set as follows:
First press Mode to get the unit in the Distance mode. Note if the unit is in Kilometers or Miles. (Press and hold Reset for 5 seconds to switch the setting. This will reset the entire pedometer.) Press and hold Set for 2 seconds. The current (or default) step length will appear and flash. Press Set repeatedly until your step length is displayed. It changes by 1" or 1 cm at a time. Then release the Set button. (The pedometer will return to the normal operating mode if you do not press a button for 5 seconds.) When you reach the maximum step length, the unit will advance to the lowest step lenght when you press Set again. Since my step length is actually not a whole number, I rounded down.
A different Sportline step and distance pedometer (the 340) is set slightly differently. To switch from Miles to Kilometers, press and hold Mode when in the Step mode. Then switch to the distance mode and press and hold Set until the step length flashes. Press Reset to advance the current step length by 1" or 2 cm. Then release the button when you have the correct step length displayed. The pedometer will return to the normal mode after 5 seconds with no button presses.
Many Sportline pedometer manuals are available from the company's web site on the product site: http://www.sportline.com . You can look up the model number.
If you add your Sportline pedometer model, I'll be glad to give the specific setting procedure for you.
I hope this helps.
(on her third Sportline pedometer, two had the plastic spring clip fail. They all had similar programming details.)
Aug 18, 2011 | Sportline step and distance Pedometer New...
My Omron Walking Style 1 pedometer is not recording all steps.
OK I couldn't find the owners manual for the original posters unit however I did write to the manufacturer so I will keep you updated on that. So basic pedometer trouble shooting. If you replaced the batteries you have to reset all your settings including your stride length. make sure the unit is not hanging off where you click it as irregualr movements will mess up the accuracy. also ensure the unit is upright at all times. Also make sure you are not shuffling or wearing sandals as that will mess up the stride count as well Here is the manual for the HJ-112 model http://www.omronhealthcare.com/img/shop/hj-112---2005-112inst-rev-d.pdfll.
Apr 15, 2009 | Exercise & Fitness
I changed the battery on my Omron pedometer and don't have the instructions to reprogram the step distance.
pedometersaustralia.com/UserFiles/.../File/HJ720ITE Mtrc Ped Aus.pdf
Attached is a pdf of the instructions that will explain how to measure and reporgram the step distance.
Jan 07, 2009 | Omron Hj 720ITC Advanced Pocket Pedometer
Omron walking style HJ-112
http://www.ccrane.com/instruction-manuals/omron-hj-112-premium-pedometer.pdf
This website has the instruction manual for the Omron pedometer. It may not be the exact same model as yours but it will still help. I just changed my batteries and have a different model which has the reset button on the back. Still, the basic stuff is there and I was able to re enter all info. Hope this helped.
Sep 30, 2008 | Omron Body Logic Body Fat Analyzer HBF...
Pedometer directions
I have no instructions how do yoou setup step lenghts? I put 14 in and steps come up 78 when I do 24 steps.
Please help me set it right
PAT SMITH
May 11, 2008 | Navman Sport Tool S300 GPS Pedometer...
Timex Pedometer  Calorie Counter 5E021 Pedometers  Stopwatches Logo
82 people viewed this question
Top Timex Exercise & Fitness Experts
Dennis Fitzsimmons
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Timex Exercise and Fitnes Expert? Answer questions, earn points and help others
