Question about Homelite Garden
How to replace throttle cable for a homelite vac attack II ut08544/ut08546
4 Suggested Answers
  • 2926 Answers
SOURCE: I have a VAC ATTACK
The cruise lever may be hung up. Click here for a breakdown of the components.
http://www.homelite.com/service_support/order_parts
Use ut-08544
Posted on Dec 12, 2010
  • 16 Answers
SOURCE: Homelite VAC Attack II stalls at open throttle
try to adjust hi speed/ low speed on carburetor
Posted on Nov 07, 2009
SOURCE: I own a Homelite Vac Attack II Model UT08546. The
OK! You know if you put fuel in it runs. You have replaced the fuel lines and filter which is great too. What is left? Two things....
1) fuel inlet screen inside the carb.
2) diapragm lever arm clearance.
Both of these are under the little covers on the carb. The one with four screws is the diapragm. The other will have one or two screws which is the inlet screen side.
Remove the gas from the vac and proceed to take the fuel inlet cover off.
The cover is under the air filter body so you have to pull the two star head screws out to get to it. With the fuel inlet cover removed you can pick out the screen inside the round hole and check it for debris/gelled fuel. These things plug at the drop of a hat! You can either try to clean the screen or go to a parts store and pickup a fresh one. I would go with a new one since the screens are so delicate cleaning is almost impossible. If you hold the screen up and look through it you will understand what I mean. You can also look on Ebay and order one and get it by mail. Which might be easier and still cost effective.
Once you replace the screen *(you put in the new by setting it in the hole and gently pressing it in with something blunt and about the size of the hole. It wont take much effort so be gentle. Once the screen is in put it back together, add a little fuel, and check the primer for rebound.
That is to say that the primer , once pushed in, should come back out quickly and fill with fuel. If it drags or stays in you still have a block somewhere in the system. This might mean removing the carb and stripping it completely and cleaning all the passages.
Do the screen thing first and we can discuss the diapragm work after that. Here is a link to homelite too:
Posted on Aug 06, 2010
Blower Vac HBL26BVN. The plastic primmer button has split. I cannot get a relacement. Help
Try this link:
http://www.ereplacementparts.com/homelite-ut08544-vac-attack-parts-c-18807_18808_139650.html
Jun 18, 2014 | Homelite Leaf Vac Attack
I have a Homelite VAC Attack II that dies when you increase the throttle after it has warmed up for about 5 minutes. Any ideas?
Sounds as if its running out of petrol to the carb,have you checked for dirt in the tank,and or carb,failing that,you may need a new carb kit ,diaphram etc,they are available on ebay,rgds
Sep 26, 2010 | Homelite Leaf Vac Attack
My Homelite vac attack 2 won't start. It's out of
My Homwlitw Attack ii won't start. Spark plug is dry even after priming more than 10 times. Where so I start? Thanks, Fred
May 05, 2010 | Homelite Leaf Vac Attack
Nov 04, 2009 | Garden
Does this blower use 2 cycle mix; I have a homelite vac attack II 200mph blower and it is having trouble starting
Yes it will use a fuel mixture of 40:1(3.2 oz of two cycle oil to 1 gallon of gas). Any fuel sitting over 30 days now is considered bad fuel. All the manufacturers schools this year and told us this. We are finding it to be true.
Good day.
Oct 12, 2009 | Homelite Leaf Vac Attack
What is the gas ratio for Homelite Vac Attack II
The mix that I would use is one ounce of two cycle oil per quart or four ounces of two cycle oil per gallon of unleaded gasoline. Hope this helped and best wishes.
Aug 31, 2009 | Homelite Leaf Vac Attack
Garden Logo
805 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
