Question about Whirlpool AWZ412 Front Load Washer
Key light is on -wash is finished-door wont open?
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 06, 2011
Red light will not go out so I cannot open the door
Generally machine take time approx 5 minit to open automatically open the door if not open please check door switch or pcb
Aug 07, 2016 | Washing Machines
All the display lights are on and the door won't open but the cycle is not finished
inbuilt lid safety switch wont let the door open till wash cycle is complete and drum has stop all motion
if you cant open the door at all after cycle ends
turn off at the wall
if no better
could be a timer fault or faulty lid switch
May 31, 2016 | Washing Machines
The green clean light wont go off when cycle is finished unless door is opened then shut again
Mark,
That is normal with most dishwashers. Mine at home does that.
Jun 12, 2015 | Dishwashers
Door remains locked after wash, no error code or anything.
if there is water left in the machine it will not open pull out the washer if under work top tilt the machine back wards the door should open thwn clean filter and try
Dec 02, 2012 | Washing Machines
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Door wont open on my washing machine hoover select 1500
I just had the same problem and came here looking for a solution...I went back one last time and tried to unplug. That didn't work. Then I put it on drain/spin and after a minute interrupted by hitting the pause/cancel button - and it released! I am so happy!
Sep 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
A problem with my Bosch washing machine
It usually takes 2 minutes after the wash to open the door; do not force the door. Doesn't matter if the active light is on. Just try.
Oct 05, 2007 | Washing Machines
Whirlpool AWZ412 Front Load Washer Logo
78 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
