SOURCE: Ricoh Aficio 1224c
Hello billboards,
SC 570 means that despite the fact that the the copier had been giving a "FUSER OIL LOW" prompt in the upper left hand corner of the display for quite some time, the prompt was ignored and now the oil is more than low it is empty. You will first need to aquire fusing oil for your machine.Typically it would be purchased from the same source you would aquire toner as it is something that is consumed as the copier is used similliar to toner. Once you have the oil you will need to replenish the copier's supply of oil. To do this you will need to access the back of the machine. Once you are at the back of the machine,look down to the lower right hand corner. You will see a small square panel with what I would describe as an oversized white plastic flathead screw that needs to be turned counterclockwise to release the small panel/cover. Once you remove the cover you will see a clear container witha black screw on cap. Unscrew it,and fill the container with the oil and stop filling when it reaches the neck of the container. Button everything back up and now you are halfway out of the woods. Now we go to the front of the machine. We need to reset the code. There is a yellow rectangular button above the nine key pad used to enter the number of copies you want. Now that you have located it, press it once and then press the "1" then the "0" then the "7" and then press the round red stop button and hold it down until the screen changes and beeps. At this point the display will have several blocks showing. One of the blocks will say "copier".Press the copier block. Now you will have a drop down menu to the left and several options across the top of the display. At the top,from left to right,the fourth box should say "SP DIRECT" and should actually already be highlighted. At this point,merely press "5810" on the keypad and then press the " # " pound sign. The pound sign means enter. At this point you should see a prompt that says something like "SC reset" and there will be a bar below the prompt that says "EXECUTE" .Press the execute button. This resets the code. But now you must turn the main power off (the red switch located next to your left knee on the front panel of the copier) and wait a few seconds. Now turn that switch back on and you should be good to go. I just reviewed my instructions and wanted to stress that the yellow button above the nine key pad says clear/stop. Just wanted to be more specific. I bet you have this problem whipped in no time! I hope this helps.Take care and good luck.And please feel free to let the folks at "FIX YA" know if I helped you. I don't get paid by them but I like the pats on the head . :-) ...........spinal.......
SOURCE: Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
SOURCE: code error sc543 ricoh aficio
SC-543
Heating roller fusing lamp overheat
The detected fusing temperature stays at 200 °C or more for five seconds.
Replacetment the PSU.
Got it here: http://www.websitetoolbox.com/mb/copierquestions
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Hope this helps!please rate how i did
