Question about Refrigerators
The cooling of refrigerator and freezer is low and ice accumulation in freezer on the front side.
    Scholar:
  • 125 Answers
It sounds like your door seal is getting old. Check all the way around the door seal for air leakage. You should be able to trap a dollar bill in the door seal without it moving. Check particularly thoroughly where you have more ice. If you find your seal is going bad try heating it slightly with a hair dryer and see if you can get it to seal up while it is malleable. Good luck.
Posted on Apr 06, 2011
The freezer and ice maker are not working properly I have a side by side fridge freezer
Check your freezer temp. If it is not 10 degrees or less the icemaker will not work.
And if the temp does not go below that you have a problem with your cooling unit - perhaps the defrost cycle is not working and you have ice accumulating in back of freezer. Check for that.
Mar 10, 2016 | Neff K3965XO Side by Side Refrigerator
Refrigerator is not cooling
Could you look and describe in detail? There are MANY possibilities. Assuming plugged in and thermostat not turned off. Do you hear anything running, any fans? Have often seen ice accumulation due to doors not fully closed or bad defrost timer or temp set too low or food blocking air flow in freezer or refrigerator - (easiest is unload food, open doors, wait a day or 2 for ice to melt), have seen dust accumulation stops air flow through cooling coils - this is usually under refrigerator. Thanks and good luck, Bill
Aug 17, 2012 | Dacor Epicure EF42BDCB Stainless Steel...
Ice is collecting on the fan in the freezer causing whirring sound.
Reduce thermostat setting point by point till no ice accumulation on fan.
Oct 01, 2017 | General Electric GSH25JFX Side by Side...
My refrigerator is freezing my food and pushing a piece of the fridge out... and it has somehow accumulated ice inside of it....
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 07, 2011 | Samsung RS2534 Side by Side Refrigerator
Water accumulating and freezing on bottom of freezer compartment
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 18, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Freezer side is working, but frige side isn't cooling?
Probably a defrost problem. I would suspect that the freezer is not as cold as it should be, even though it still freezes ice cream.
It could be air circulation, so make sure you have not packed the freezer or refrigerator too tightly and blocked the cross over vents.
To check if the problem is the defrost system, look in the louvered vents, or around the fan, to see if there is thicker accumulations of frost/ice on the cooling coil.
Dec 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator and freezer not cooling/freeding
Possibly a defrost circuit problem -
1) Bad defrost thermostat
2) Bad defrost heater
3) Bad defrost timer
4) Failed evaporator fan motor.
Look for frost accumulated inside the louvers at the back panel, top and bottom. If you see it, remove food from freezer and put in ice chest. Take out shelves, get hair dryer and warm the backside of the freezer, directing air down the louvers. Then leave to sit for 4-6 hours with the freezer door open. Put towels in the bottom of the freezer to catch any melted ice.
After period of time, plug unit back in and power the unit back up. Once you know it's cooling, empty ice chests back into freezer.
If there is a problem in any of the above components, then it will show up in 3-4 weeks witht he same problem again.
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
