Question about Elna 1010
I have an Elna 1010. I have not used it for several years. When I turned it on and pressed the foot petal all the way down, it sounded like something was going to happen, but nothing did. I am in the process of cleaning and oiling the machine now. if this does not work, what else should I try? Thanks.
  • Elna Master
  • 1,133 Answers
If you have not used it for several years and now not getting any drive action, then it is possible one of the gears inside it has failed, broken or siezed up. This would be inside the free arm or near the motor probably.
I would suggest that you take it to a sewing machine repair shop and get it serviced, all machine manufacturer's recommend a service every 1-2 years to lube internally, clean out and address any issues. Just the same as getting the car serviced.
My local shop charges $80 for a service/clean plus any parts to be replaced, well worth the money in my humble opinion.
Posted on Apr 15, 2011
  • jgingin Apr 15, 2011
    Thanks Tally Girl. I got it to work. It needed to be cleaned and oiled. TLC really works!
No foot switch for Elna Su (1972-78?)-can I use the foot petal from an Elna Zigzag that I have?
I'm asuming you have the integrated foot controller and power lead in one, yes these are both Swiss Tavaro made machines and should have the same plug shape so should be interchangeable. Also the bobbins should be identical, seven holes on top and dished. And the feet should be the same too.
Feb 16, 2014 | Elna Sewing Machines
Can a genic foot pedal be used on an Elna Super?
Take a look at the side plate on your Elna and look for a two digit code, this is the model number.
I'm assuming that you are in the USA on 110 Voltage. If so visit this website,
http://www.sewingpartsonline.com/elna-sewing-machine-parts-model-list.aspx and choose your model. They sell replacement foot pedals, just check the profile of the plug that goes into your machine.
The other option is contact the Elna guru, www.whitesewingcenter.com, he stocks a wide range of swiss Elna parts and may have the original foot control second hand.
If you are on 240 voltage then you'll need to source it from a country that has the same voltage like UK, Australia or NZ.
Lastly, you may wish to join the Yahoo group called "ELna Heirlooms" this user group of Elna owners is really helpful and shares lots of their love and knowledge for these beautifully made Swiss machines. Many of them have even earlier models than yours such as the Green Grasshopper, the first Elna machine.
Dec 19, 2011 | Elna 2007 Mechanical Sewing Machine
I need to replace the electrical lead and pedal to connect to my elna machine model 1010 , any idea where to look?
try www.sewingpartsonline.com for this, I'm assuming you are in the USA and need 110V foot control and lead? If not and you need a 240V cable, might need to try further afield.
www.sewusa.com is also a good source for sewing machine parts
Mar 10, 2011 | Elna 1010
Broken walking foot
there are many companys on the net that sell secound hand electronics parts like car wreckers google secound hand elna parts good luck
Apr 20, 2010 | Elna 1010
I have a ELNA model 1010 and there seems to be no tension when do a test strip it bloobs up
Try re-threading the machine with the presser foot up.
This opens the tension and allows the thread to "seat".
Thread with the presser foot down and the tension is closed and the thread cannot seat.
Mar 07, 2010 | Elna 1010
Would like toknow how to clean and oil my elna 1010
http://www.scribd.com/doc/3714472/Elna-1010-Manual
page 34 shows some oil use.
older models have a "red dot" to show you where to put 1-2 drops of oil per month (depending on your use)
Jan 26, 2010 | Elna 1010
Elna 9000 presser foot
This is a cleaning issue. There is gummy residue holding your presser foot bar which needs to be cleaned out. Unfortunately, you need to split the case on your machine to access it for cleaning and this is best done by a qualified technician. Let's face it, it's probably been a long time since the machine was serviced anyway and they do work better with regular servicing.
sewman7
Oct 25, 2008 | Elna 1010
Elna 9000 sews automatically
Most likely this is a problem in the foot control and it will need to be replaced or repaired.
sewman7
Jul 11, 2008 | Elna 1010
Elan Pro 5 DC
Try contacting Elna directly, or find your nearest agent thru their website, if in USA ....here
having this photo should help trace a part number if you can get onto an Elna service technician, if it were Janome, I could look up our references, so it should be straightforward.
Feb 15, 2008 | Elna 1010
Sewing Machines Logo
59 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
