Question about ASUS M2N-MX Motherboard
BOOT BLOCK COMPATIBLE VERSION VER .005 BAD BIOS CHECKSUM CHECKING FOR CD ROM READING FILE "P5SD2VM.ROM" READING FILE "P5SD2VM.ROM" READING FILE "P5SD2VM.ROM" READING FILE "P5SD2VM.ROM" READING FILE "P5SD2VM.ROM" NO CD-ROM FOUND CHECKING FOR FLOPPY DISK READING FILE "P5SD2VM.ROM" READING FILE "P5SD2VM.ROM" READING FILE "P5SD2VM.ROM" READING FILE "P5SD2VM.ROM" READING FILE "P5SD2VM.ROM" NO FLOPPY DISK FOUND
  • 1,591 Answers
Click this link or copy and paste it in your browser address bar:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5SD2-VM&p=1&ft=3&os=29#P5SD2-VM-0515.zip
In the most recent (top) listing, click the GLOBAL that does NOT say DLM at the end (the second GLOBAL link)
Make note of where the file is being saved!
Unzip the file using winzip or power archiver or some such utility (Depending on your OS, Windows may simply open it for you)
Copy the extracted file P5SD2VM.ROM either to a floppy, or burn it to a CD.
Put the disk with the file on it in the appropriate drive and reboot the system.
The motherboard should now repair itself, and give you the latest bios in the process.
This will fix your system, but I'd get a program called FIX-CIH from http://www.grc.com/fix-cih.htm
Run that program to make sure you aren't infected with the CIH virus (one of very very few viruses that will kill your BIOS like your is) Just to be sure it wasn't a virus that did it.
That should FixYa.
Posted on Apr 06, 2011
    Sergeant:
    Champion:
  • 217 Answers
This error can be caused by many things. The first and easiest thing to try is this. Start up your computer and enter the bios by hitting the delete key repeatedly as it begins to turn on. Look at the tabs on the top of the screen and go to the last tab on the right, select it, and choose "load bios default settings" or similiar. Exit and save. If it boots up fine check you are done. If not you will need to remove the side panel of your computer to gain access to the motherboard (unplug the power first). You are going to clear the cmos memory and reset it back to default from factory. To do this you can use the "clear cmos" jumpers, if you are unsure how to do that then simply locate the battery and carefully remove it. The battery is a coin sized disc (like a watch battery). Remove the battery for at least 5 minutes. You can push the power button while it is out to help dissapate any charge left in the circuit. Replace the battey, close your computer case, and plug it in. Now you will need to enter the bios the same way as before and on the first page displayed you will have to reset the date and time. Save and exit your bios and start your computer. If you continue to have a problem your cmos battery on the motherboard may need to be replaced.
  • josemigueljh
    josemigueljh Feb 23, 2013
    thank you so much i love you....you save my life.i love you so much,i save alot of many doing this,think you!,thank you! thank you!
  • ASUS Master
  • 3,606 Answers
Hi, i think you have to renew the cmos battery
So the bios can remember its settings:
The battery is a watch type 2032.
When you have installed a new battery enter the bios
and set the settings for the boot configure.
You can download a manual and drivers here:
http://www.asus.com/Product.aspx?P_ID=0pKBwEIE8tqMT4j7&content=specifications
Hope this will help you.
How do you flash the BIOS
What happens when you turn the computer on?
If the bios is working enough to enable you to boot from a CD download the new bios from asus along with there AFUDOS.exe flash utility and make a bootable CD and copy both to it.
If the bios is completly none functional you should be getting this msg when you turn the computer on,
Boot Block Compatible Version Ver .010
Bad BIOS checksum. Starting BIOS Recovery
Checking for floppy . .
Floppy not found
Checking for CD rom . . .
CD not found
Floppy not found
CD not found
Repeat adinfinitum.
If this is the case you need download the most recent BIOS from compaq and either copy it to a bootable CD if you have this capability or buy a floppy drive for $5 and make a bootable floppy on a working computer and copy this BIOS file to it. Then rename the bios file to A8N32SLI.ROM.
You may not even need make the floppy bootable but I would just in case.
Stick the floppy in the drive turn the computer on and you will see
Checking for floppy . . .
Floppy found.
Reading file "A8N32SLI.ROM" . Completed.
Start Erasing...
Start programing . . ./
Please turn off your system and power on again to get system back.
and happy days will be here.
Jun 29, 2012 | Compaq Presario CQ61-310US Laptop
BAD BIOS CHECKSUM, STARTING BIOS RECOVERY...
I have seen this be a CMOS battery many times. Also, you can try flashing the BIOS if you continue to have troubles after replacing the battery. You should be able to find that information on the motherboard manufacturer's website.
May 05, 2011 | Computers & Internet
Everytime i switched on my asus eee pc netbook, this will come out: Boot Block Compatible Version Ver.032 Please do NOT insert any disc into CD-ROM if you want to recovery with an USB device. Bad BIOS...
It sounds like you will have to make a Bootable Flash Drive with your Netbooks latest BIOS and a Flashing program (which ever ASUS uses, i'm not sure). Once you have that then you plug it in to the USB port and start the computer and follow the on-screen instructions. There are a lot of tutorials on the web on how to make a bootable flash drive for your BIOS.
Mar 16, 2011 | Computers & Internet
This is my first time building a computer. When I turn the computer on, I get a screen that reads: "Boot Block Compatible Version Ver.022 Bad BIOS checksum. Starting BIOS recovery... Checking...
My first thought is that you have a defective motherboard. I've never seen so many things going wrong except when the board was a dud. It sounds like the BIOS ROM or its interface circuitry is bad. If this board is still under warranty you can probably get it replaced. Try the vendor first. If you bought your board from a company like TigerDirect or Newegg, they're pretty good about replacing defective parts. Then check the manual or Asus website to see what you need to do if the vendor won't exchange it. I have used this same board (purchased from TigerDirect) in a couple of systems, and they went together without a hitch.
Once you've got a working motherboard, it should be pretty much smooth sailing with the rest of the assembly. Good luck and thanks for using Fixya! Please post a followup to let me know when you get your system running.
Dec 26, 2010 | ASUS M4A785M (890552666775) Motherboard
My K8V-VM SE MOTHER BOARD .swith on the computer ,K8VVMSE.ROM FAIL INSERT THE FLOPPY OR CD.REPET THIS MESSAGE SURESH
iat the time of boot a message as follows is displayed
"boot block compatible version .005"
bad bios cheksum. starting bios recovery
checking for floppy. floppy not found
checking for cd rom. cd rom not found"
.. using asus motherboard
Sep 06, 2010 | ASUS A8V-VM Motherboard
Asus k8v-vm mother board drivers
boot block compatible version ver 003
bad bios checksum, start recovery
is alone window seen in my computer
Dec 26, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Bad BIOS checksum.... CMOS bad checksum errors
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
NO CD-ROM FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Please Tell me, ASUS P4S8X-MX Problemn
First of all, try to reseat all the cables inside your computer just make sure there aren't any loose connections.
If that doesn't work you will have to reset your BIOS. (Follow the instructions in your motherboard manual.)
If even after resetting the BIOS the problem is not solved, you may have to replace your CMOS Battery.
Oct 18, 2007 | ASUS P4S8X-MX Motherboard
Bios failure
you may have a flat cmos battery, but first try reseting the bios by the cmos reset terminals, refer to the manual
Sep 14, 2007 | ASUS A8V-VM Motherboard
ASUS M2N-MX Motherboard Logo
4,241 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
