Question about Bernina Virtuosa 150
Hi - hope someone can help me. I have a Bernina 121 and no manual. It seems that the bobbin winder is on - and I can't figure out how to switch it off so the needle will go on.
  • Bernina Master
  • 1,122 Answers
Do you use the flywheel to disengage the clutch and wind the bobbin?
Alternatively, newer machines have a bobbin winder on top and usually you just flick the winder over to engage, then back to disengage. There may be a button on the front that drives the winder motor during this process.
You may find some ongoing help if you join the Yahoo Bernina virtuosa user group,
http://groups.yahoo.com/group/BerninaVirtuosa/ I find user groups are a great resouce and you learn lots from fellow owner/users of your machine.
Good luck.
Posted on Apr 09, 2011
My 1130 bobbin threader turns, but will not wind thread.
Check that the bobbin winder is snapped all the way over.
Sorry, unable to provide more help, but a standalone bobbin winder may be helpful. You can find one brand (called "Sidewinder") at sewing stores like JoAnn's or online for ~ $30. Just verify that your bobbins will work (some Singer bobbins do not), but I assume your machine is a Bernina. Even if your bobbin winder is repaired, this standalone bobbin winder will save wear and tear on your machine--also, makes it so-o-o-o much easier to wind a bobbin without first removing the thread from your machine.
Oct 10, 2016 | Sewing Machines
How do I turn off THE BOBBIN winder on a Bernette 65 sewing machine?
The bobbin spindle needs to be moved to the left in the slot to disengage the winding mechanism. (It may be easier to do this with the bobbin on the spindle. The bobbin and spindle should be moved to the right after putting the bobbin on for winding.)
The directions and pictures for winding the bobbin are on page 30-31 of the manual. The manual is available from Bernina on their support page for the out-of-print Bernette machine manuals: .http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/bernette-manuals/Bernette-Sewing-Machines . The direct link to the Bernette 65 manual is here: http://www.bernina.com/getdoc/6d2754b8-af09-4edb-a6a6-7a4c57965b8d/bernette-55-65-80e-90e .
I hope this helps.
Oct 13, 2015 | Bernina BERNETTE 65 Mechanical Sewing...
Bobbin on Bernina 807 won't wind?
Please follow the logic checks and possible corrections:
1. Check the winder shaft for a sticking or a stuck condition. If stuck or sticking, add a drop or two of mineral spirits to the winder shaft and the winder support bushing. This will generally release the winder shaft.
If the winder shaft becomes free wheeling, clean off excess solvent and apply a drop of Bernina machine oil which is typically a class 68 machine oil. You can also use a common white mineral sewing machine oil.
Do not use WD-40 or 3 in 1 oil!
If WD-40 had been used prior to the winder seizure then you'll know why....Removing sticky WD-40 residues requires further measures.
2. If only the rubber wheel has hardened, you will need to replace the winder hub with a new hub and replaceable winder ring or the entire winder can be replaced. There are some very good after-market parts available online.
3. If the winder parts are good and you are describing a condition where the hand-wheel will not release so that the machine drives while trying to wind a bobbin, this would requite another question and detailed answer... SewTechnical Home
Jan 25, 2015 | Bernina Sewing Machines
Bernina manual
Winder rubber is likely needing replacement
Feb 20, 2014 | Sewing Machines
Sewing machine wheel won't turn, motor whirrs also the wheel seems to be jammed, it cannot be turned either clockwise or anticlockwise
Make sure your bobbin winder is not engaged. Ten check to see if you have thread stuck in the bobbin race area. That's where I would look first.
Sep 12, 2013 | Bernina Sewing Machines
Fix bobbin winder hub on bernina nova 900 sewing maching
are you talking about the bobbin winder spindle or the hook & hook race that holds the bobbin case?
Apr 02, 2012 | Bernina Sewing Machines
Broken Bernina Aurora bobbin winder post!! Help!
http://www.berninausa.com/news-n325-sUS.html
check this site out. you may be able to find a dealer near you for your model. they should have the part for you.
hope this helps :)
Sep 02, 2009 | Bernina Virtuosa 160
Kenmore by sears model 1581457180 need a manual or a how to thread the bobbin
hi there,
on my manual 1581 kenmore show figure on how you thread your bobbins and upper thread.
to thread bobbin insert the thread on one hole of winder holding thread and rotate thread on counter clockwise rotation several times, loop the thread on tension thread and insert bobbins winder on winder shaftat top of your sewing machine push the latch to lock bobbin winder
pull the handwheel to disengage the clutch and to move the winder free rotation.
press the foot pedal to run your winder and thread your bobbins be sure on counterclock wise rotation.
if winder is full of thread this will automatically disengage the shafting winder from clutch.
4843169.jpginsert winder as in fig. check the thread direction
5d74924.jpg 153629c.jpg on figure hold and insert bobbins on shuttle race assymble.
on figure show upper threading.
3cba620.jpg follow the red thread on figure.
you can also check your manual on internet
search box type www.kenmore 1581
have a nice day,rate my fix,thank's a lot
Jun 12, 2009 | Sewing Machines
Bernina 145 Bobbin winding problem
If the winder is working without thread as it should you can rule out an electronic and motor issue. At this point it won't hurt to remove the two screws on top and lift your top cover off. Take a close look at your winder and see if there is any thread or anything wound around or blocking it. There are one or two screws that will adjust the eveness of your bobbinwinding but I don't think this is part of the problem (just a slight turn for that until the bobbin winds evenly). There is a spring beneith the winder that may have popped loose, check that but if the little arm snaps back and forth thats ok. The spring should be in the second tooth of the gear notches.
I hope this helps.
Jul 19, 2008 | Sewing Machines
Sewing Machines Logo
313 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
