Question about Euro-Pro Steam Generator EP8001 Iron
Europro steam cleaner with iron
How do you know how much water to add?we have misplaced the instructions and need to know where to get them-online or the manufacturer?
  • sandy3333 Aug 14, 2008
    I bought this iron and the instructions were not in the box and now I do not want to use this iron with out reading the instructions first. I have looked all over on the internet and can not find them does some one out there have a copy they can add to this site. It would be greatly apprecitate.
    Thanking you inadvance Steamed
    Problem Solver:
  • 12 Answers
Hello Margoi,
Unfortunatly I can not help you with instruction, but from user reviews I know that it has exactly 1 liter capacity.
regards,
Konstantin
Posted on Aug 06, 2008
SOURCE:
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
Steam iron model 14884. Need replacement filter. Can I get locally or only order online
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please provide manufacturer name of your steam iron. Also which city are you located in.
Jul 31, 2014 | Irons
Must I use distilled water?
Yes, it is ALWAYS best to use distilled water in any iron, no matter what a specific manufacturer may, or may not, say. The reason is simple: There's nothing in distilled water to contaminate your iron, and as a result, you will not have stained clothes.
If your iron is already dirty from using tap water... clean with mixture of vinegar and water by pouring mixture into iron, bring to full temp for a few mins, flush through steam vents, and rinse with distilled water. You may need to invert your iron to purge the water from tank as well. Repeat as many times as needed until perfectly clean.
Once clean, NEVER use any other type of water in you iron. Period. Always use distilled water. Hope this helps...
Jun 10, 2013 | Rowenta Perfect Iron
The water that is spitting out when I press the steam button is clear and boiling hot. A LOT of water comes out.
Check to see the amount of water the iron requires. If too much is added it will spit water out can also come out of where the water goes in plus the holes the steam should come out. In order for the iron to steam the water must boil inside the iron. Check the instructions and see how mmuch the manufacturer suggests. You may have to fill it several times while doing the ironing. If there is no instruction try consulting the manufacturers web site for information on your make and model of iron. They should have instruction manuals available for download. If that is not the problem it could be cracked on the inside. Give the water adjustment a try first though a lot cheaper in the long run.
Aug 06, 2012 | Irons
Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Jul 31, 2012 | Bosch Irons
Can't see water level
read you owner manual, and clean the level, for to see the level.In the manual you must have instruction when to add watter.
download free from www.retrevo.com or www.fitness.manualsonline.com
God bless you
Jul 23, 2012 | Euro-Pro Irons
Brown water and seems like sand or fine grit comes from iron ,when first put on with the steam
sounds like it is time to de-scale the iron to loosen all the deposits inside the unit.
add some white viegar to the water ( which should be distilled water ) and heat up and let the iron steam out the solution. now add just water to the unit shake it and rinse out with water and drain. now do one more vinegar / water de-scaling and rinse out again. now fill with just distilled water and let it steam out and now your iron should be clean as new.
c...
Feb 12, 2011 | Russell Hobbs 13153 Iron
Black water coming out and staining clothes
Hi , couple of soloutions
black water could mean that the scale inside needs flushing out (follow instructions from manufacturer)
or it could be the inside of the iron has deteriorated that it is past cleaning
Sep 16, 2009 | Irons
Scale build up problem in iron
White vinegar and a toothbrush. You can clean the whole steam path with 25% vinegar to 75% water. Steam it through. Run plain water afterwards to rinse it out.
Feb 06, 2009 | Sunbeam Irons
Treatment of new iron
Before first use, remove any labels or stickers, on the body or soleplate of the iron. On first use only, iron over an old cotton cloth using steps 1 thru 5 below on setting 5 or above (and the SURGE button for models with that function) to remove any protective surface treatments. 1. Using a clean cup, pour water into one of the two openings in the Water Fill Hole until the level reaches the MAX mark on the Water Window (A). Refill as needed. 2. Ordinary tap water can be used for ironing. Do not use water processed through a home softening system. In extremely hard water areas, consider using distilled or demineralized water, however, use tap water the first time you use the iron and once a month thereafter to maintain steam performance.
Jan 01, 2006 | Black & Decker Quick N Easy X485 Iron
Euro-Pro Steam Generator EP8001 Iron Logo
129 people viewed this question
Top Euro-Pro Irons Experts
Bruce Showalter
Sheldon Dedek
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
