Question about Yamaha YDP223 Digital Piano
1 key does not spring back when it is pressed and 1 key has a bit of resistance when pushed
  • 3 Answers
The elektrotanya website link proposed in the other solution here did not work for me. So with a similar sticky keys problem on my YDP-113 yamaha digital piano, i just started taking it apart.
I found that the problem was that the sticking keys actually had small cracks at the hinge end. See attached photo for a picture of the hinge end of the key. The cracks are very small and hard to see, but if this is your problem, you will see it in a good light. Having the key apart will also allow you to clean the sides well in case there has been a bubble gum attack or similar problem.
After learning that replacement keys are extremely expensive (like $15 per key...) I decided to move the bad keys to the highest and lowest notes on the keyboard (88 key keyboard so there is some seldom used territory). The center several octaves are now free of sticky keys and this is good enough for now.
The procedure on my YDP-113 was:
1. Remove black screws from back panel of unit to allow top to slide forward and then lift off. Set aside.
2. Roll the roll top all the way closed and then simply lift up to remove. Set aside.
3. Remove the six screws which attach the roll top gear rail (3 screws on each side panel). Set aside the gear rails.
4. Remove 2 screws in the key top bracket, and 1 screw from each end of the key top. "Key top" is my name for the small strip which lies along the top of the keys. If you have an official or better name, please share.
5. Remove the 10 or so large screws and two small screws which hold the keyboard panel down in the unit.The keyboard should now be able to slide a few millimeters toward the back of the unit.
6. Remove 1 screw to take out the power switch panel. The front of it hooks in with a tab, so slide it back and then it will lift out.
7. Careful now. I felt this was the one operation where I had an opportunity to ruin the unit if I would have fumbled: Lift the keyboard up slightly and rest its front 'legs' on the front edge of the case. Careful of small wires to not rip them. Careful of the circuit boards that are underneath the keyboard frame. 1 key does not spring - jeff20112011.jpgThe objective here is to allow the keys to come out toward you so that they can be removed and replaced or swapped. You can kind of see in the cracked key end photo, how the keyboard is up and partially out of the unit.
8. You now can do the actual swapping. To remove a key, pry up very gently in back of the key with a small screwdriver. It will pop up. Then gently work the key around to free it from the return spring without bending that spring. Replace with a new key or swap will a good working key in a little used position. Note that B and E are interchangeable, also C and F. Some other keys also look like they could interchange though I didn't personally try it.
9. Reassemble in reverse order of disassembly.
Posted on Jun 05, 2011
  • Chris Wagner
    Chris Wagner Jul 26, 2015
    thanks for posting! I fixed my YDP-113!
  • Yamaha Master
  • 5,603 Answers
There is a problem with the keyspring seating and POSSIBLY damage where the key hinges.
Here is your service manual:
http://elektrotanya.com/yamaha_ydp-223_223c_parts.pdf/download.html
Scroll down the web page to the "Get Manual" and click on that. The manual shows how to disassemble the unit and how to remove the keys to get at the springs. The springs are a little leaf type that bow to flex. I use a thin butter spreader between the keys to release them. DO NOT force anything as the keys especially at the back hinge point can be broken. The key with resistance MAY have debris under it. One has to remove three curvy brackets and several screws after removing the top and roll-top to allow the keyboard assembly to move to the rear to get clearance as the keys have to come forward to remove them... take your time and capture every screw... you don't want anything floating around in the unit.
Posted on Apr 06, 2011
Middle C on my Model #SGP-151G piano is dead. How can I fix it?
I have taken keyboards apart and reattached springs that hold keys in position, also use electronics contact spray cleaner to free up the key and switch point that activities the sound
hope this helps?
Mar 20, 2015 | Music
How do I put the springs in my dean razorback 255
I'm sure you have solved this by now, but I would recommend hooking the straight pin of the spring into the 1st, 3rd, and 5th holes on the trem, then hook the loop ends to the three center claws. This gives a variable or progressive rate of resistance, letting the trem gargle like Vai or Dimebag, but resists going out of tune.
Apr 22, 2013 | Dean Guitars Dean Razorback Guitar,...
Yamaha PSR-240. Mechanical sound
Deformed metal contact will also add a slight resistance to it. You may have some dirt or grit in there, or a plastic pivot may have broken.
Vaccuum it first while pressing key or affected keys, and then apply something like LPS1 (which makes an excellent contact cleaner) If that does not clear it up, go the opposite direction with compressed air while moving the key or affected keys.
If that does not clear it up, you may need to diassemble the key to find the source of the noise and address it that way.
Oct 27, 2012 | Music
I have an M-Audio ProKeys88. The D above middle C does not work. The key moves fine, but it doesn't trigger anything when it's pressed. I want to know how to get into the unit to examine the keybed, but I...
I would suggest getting a service manual for the unit. I have two of these units. I opened one to restore a key spring once. There are ribbon cables to the upper shell that have to be disconnected or left if the shell top can be placed behind the unit. The key contacts for most of these keyboards are conductive rubber "pills" in silicone rubber domes that get pressed onto traces on a circuit board under the keys. There are two contacts per key with one closing first. This is the way key velocity is measured. These keys have coil springs for return that have a cone at the end of the spring that fits a slot in the back of the key rearward of the pivot point. Clean the pills AND the circuit traces GENTLY with ONLY 99% isoprophyl alcohol and Q Tips. There are a lot of screws to remove to open the unit. Keep track of what length and thread type for re-assembly.
Apr 25, 2011 | M-Audio New M-audio Pro Keys 88 Stage...
On low volume using the clean channel the sound is great but as soon as you get to about three or more the sound gets a bit distorted,the amp is the fender hot rod deluxe, ithort i may had blown the...
try a differrent speaker of suitable wattage and ohmage (displayed with a number next to a ? symbol on the back of the speaker),
or
remove the original amp speaker and gently push in and out on it, checking for uneven resistance or scratching. the speaker should retract and return smoothly, without any scratchiness or uneven resistance from within, and if there is any of this scratchiness or uneven resistance from within, the speaker is likely damaged from too much wattage or distortion.
Mar 09, 2011 | Fender Hot Rod Deluxe Guitar Combo...
The "G" note below Middle
The key contact has gotten contaminated. They are a black conductive rubber pill pressed against circuit traces on a board bellow the keys. Remove that key and maybe others to get at the contacts in silicone strips. Clean ONLY with 99% isoprophyl alcohol and Q tips. Clean both the pills (two per note) and the circuit traces they touch. You have to release the spring at the back of each key to remove the key.
Feb 03, 2011 | M-Audio M Audio Keystation 88es 88 Key USB...
How can i replase the keys for YAMAHA YDP-121
There are step by step instructions under another Fixya thread here: see solution #2
http://www.fixya.com/support/t8881187-1_key_not_spring
Sep 17, 2010 | Music
How to remove key from yamaha p80 electronic piano
This pertains to the white keys. If you need to take out a black one, you MUST remove the white ones alongside the black one first.
You push the back end of the key forward (takes a little bit of force) and then lift the back a bit to dis-engage it from the back rail. There is a flat spring under the key. Note how it sets in place.
When re-installing make SURE you get the front of the key engaged with the little lever before attempting to push it forward and down to re-engage the back in the rail.
Apr 18, 2010 | Yamaha Music
Have ypt 400 first c wont play note
This is likely a dirty contact. MANY of these keys use a conductive rubber "pill" that is pressed across a set of circuit traces on a circuit board.
Dis-assemble and clean both the "pills" and the circuit traces with 99% isoprophyl alcohol.
The pills are often under silicone rubber domes that also serve to spring back the keys.
Oct 15, 2009 | Yamaha YPT400 61 Key Portable Keyboard...
Yamaha YDP223 Digital Piano Logo
2,761 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
