Question about HP Laser Jet Printer P3005dn
How do you reset a dimm - HP Laser Jet Printer P3005dn
  • 85 Answers
If you replaced the DIMM is not necessary to reset if you still want to do a reset, "Could reset"or ,,nvram reset"
Posted on Apr 06, 2011
How can i fuush bios
Printer bios, aka firmware dimms, are not flushable. You can, however, often replace either the dimm or the motherboard.
Try a cold reset and a NV RAM reset procedure before replacing parts.
Nov 25, 2014 | Office Equipment & Supplies
Memory stick upgrade 2 512, 2 1GB what order do I put them in
On the motherboard they should be labeled as to which slot is Dimm 1, Dimm 2, Dimm 3 and Dimm 4. Put the larger ones (1GB) in Dimm 1 and Dimm 2. The smaller ones (512MB) in Dimm 3 and Dimm 4.
May 06, 2012 | Sony PCV-RS620G PC Desktop
I removed the DIMM while the motherboard was powered. then i heard a bip sound at an interval but the monitor does not display anything. Which part specifically is my pc affected?
Best Bet is to do a hardware reset, just unplug anything unpluggable from the motherboard, including CMOS Battery, wait 5 minutes and plug it all back, it should work...
Oct 25, 2010 | AOpen MX34 (91.88510.101) Motherboard
I am having Intel Board SE7501BR2, i wanted to know how much RAM does it support and of what speed, because currently it is having 512 mb ram with speed of DDR$266 mhz.
This motherboard can support up to 2Gb of DDR266 RAM modules.
Attached is part of the memory detail from the manual.
If you need a copy of the manual. please click on this link to download :-
ftp://serwery.optimus.pl/Servers/Motherboards/SE7501BR2/Dokumenty/se7501br2tps.pdf
3.1.2.2 Memory Configuration
Memory interface between the MCH and DIMMs is 144 bits wide. This requires that two DIMMs
be populated per bank in order for the system to operate. At least one bank has to be populated
in order for the system to boot. If additional banks have less than two DIMMs, the memory for
that bank(s) will not be available to the system.
There are two banks of DIMMs, labeled Bank1 and Bank2. Bank1 contains DIMM locations
DIMM1A and DIMM1B and Bank2 contains DIMM2A and DIMM2B. DIMM socket identifiers are
marked with silk screen next to each DIMM socket on the baseboard. The sockets associated
with any given bank are located next to each other.
The baseboard's signal integrity is optimized when memory banks are populated in order.
Therefore, DIMM Bank1 must be populated before Bank2.
DIMM and memory configurations must adhere to the following:
• DDR266 DDR registered DIMM modules
• DIMM organization: x72 ECC
• Pin count: 184
• DIMM capacity: 128 MB, 256 MB, 512 MB, 1 GB, 2 GB
• Serial PD: JEDEC Rev 2.0
• Voltage options: 2.5 V (VDD/VDDQ)
• Interface: SSTL2
• Two DIMMs must be populated in a bank for a 144-bit wide memory data path
• One or two memory banks may be populated
Table 2. Memory Bank Labels
Memory DIMM Bank Row
J8D22 (DIMM 1A), J8D15 (DIMM 1B) 1 0, 1
J8D7 (DIMM 2A), J8D1 (DIMM 2B) 2 2, 3
Note: Memory must be installed in pairs; DIMM Bank1 must be populated before DIMM Bank2.
Memory within a DIMM bank must be identical; between banks only the DIMM size may be
different.
Functional Architecture Intel® Server Board SE7501BR2 Technical Product Specification
26 Revision 1.2
Intel Order Number C13977-003
Figure 3. Memory Bank Label Definition
Sep 25, 2010 | Intel Server Board SE7501BR2 Motherboard
XPS M 140 system is reading only one of DIMM A or DIMM B,
It should read both modules without resetting or making changes to the BIOS.
It is likely one of the following is true:
1. One of the modules has an incompatible speed or defective which means it won't work in your system.
2. The two modules are different speeds and won't work together.
Try removing both modules and install the module that you had in DIMM B in DIMM A. If it doesn't work #1 is the situation. If it does work then it is likely that #2 is the situation.
If you need more help go to Crucial.com and chat with one of their experts for free.
If this helps please vote for my solution.
Aug 25, 2009 | Dell Inspiron XPS M140 Notebook
Error message: ROM ERROR, what does this mean?
Error :
ROM Error message
Workaround :
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
In attempting to resolve the issue, reflash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software toit's latest version.
iR 1600/2000 FG6-9978-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
Jun 05, 2009 | Canon imageRUNNER 2000 Copier
Memory synchronization Problem
Did you reset the cmos on board first?
Jan 18, 2009 | MSI K8N Neo3-F Motherboard
Adding More Memory
Reset the BIOS using the motherboard jumper before booting into Windows.
Jul 23, 2008 | ASUS P4S800D-X (610839122325) Motherboard
Ddr and ddr dimm
To answer you there is no difference
DIMM= Dual In Line Memory Modual 64 bit transfer
Dimms replaced Simms when pentium ll came out.
DDR= Double Data Rate
Newer memory modules are DDR2 or DDR3
Older systems are DDR or SDRAM
All the systems use SDRAM DIMMS, DDR DIMMS,DDR2 DIMMS, DDR3 DIMMS.
Apr 17, 2008 | Computers & Internet
HP Laser Jet Printer P3005dn Logo
581 people viewed this question
Seeker5211
Seeker5211
