Question about Toshiba MK8025GAS 80 GB Hard Drive
Can anyone recommend an enclosure to use HDD as external drive?
    Top Expert:
  • Toshiba Master
  • 14,162 Answers
Posted on May 24, 2016
2 Suggested Answers
  • 214 Answers
SOURCE: my laptop uses toshiba mk3265gsx
I suggest try to isolate the problem, try to check if its going to work to any other machine, see if the enclosure can properly supply power for the HDD, also check if the cable that comes with the enclosure is working, try different cable or try going to any computer local center and have them try your external HDD. Make sure you installed properly the HDD.
Hope It helps. =)
Posted on Apr 20, 2011
How to run diagnostic form a hDD external enclosure
I am not understanding what you are trying to do. Are you trying to install an os on an external drive?
You can only do that on a drive not an enclosure.
Terry
Nov 14, 2014 | Acer Aspire One D270-1375 Atom N2600 1
Computer doesnt pick up a usb
Remove the HDD from the enclosure and slave it inside your PC...if it reads it will be the enclosure is faulty. If still no read is faulty HDD.
Oct 16, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
CPU won't read it im running xp
Ok, here's some step by step instructions.
First is the light on the nexstar coming on when you plug it in, if so what colour? If not try using both USB connectors on the PC end to plug in, it's possible you're not getting enough power if the light is not on as many 2.5" hdd enclosures require 2 USB connections one for power and data and the other for additional power.
Next, if the light is on but no drive in my computer, right-click on my computer, then left-click manage, select disk management from the MCC window that pops up. If your Nexstar HDD shows up here, identify it on the bottom part of the window and report back what is said there.
If it is not there and the light is on, try a different USB port. If the light is not on or you tried the other ports and still no luck the enclosure itself may have failed.
Try moving the HDD into a new enclosure and try again. If this works, Great, if not then the HDD may be damaged and may need a pro to get your files back. If that is the case report back here with your progress and region and I will recommend an appropriate pro.
Hope this helps FixYa,
Chris
May 09, 2009 | Vantec NST-285S2-BK NexStar SX 2.5"...
I turned of my eMac without turning of the 3.5 HDD external enclosure and now the icon does not pop up on my desk top? How do I get the icon back
Boot eMac
Unplug the DATA cable for the external HDD where it enters the computer.
recycle power to external HDD
plug the data cable for the external HDD back into the eMac.
Icon should appear after a small delay.
IF NOT -- Reboot eMac.
Mar 10, 2009 | BYTECC Aluminium 3.5" HDD Smart Drive...
Hard drive interface
Hi nortocd
(01) It will work in your USB hard disk enclosure if the enclosure supports SATA. If the enclosure supports the older style (ATA/EIDE) interface, then you'll just need to get an enclosure that supports SATA for your new hard disk. I like the Nextar external HDD (hard disk drive) enclosures.
You can find many external HDD enclosures made by various manufacturers these days. They're available for 3.5" (laptop-sized) and 5.25" (desktop PC-sized) HDDs supporting ATA/EIDE, SATA and SCSI HDDs and even Optical drives (DVD, etc.) Newegg is a great online source for computer & high tech-related equipment. They're prices are very competitive and their customer service is excellent. You can also find customer reviews of most of the products they sell, too, which can be very helpful.
(02) If you'd like this HDD to be portable, then I recommend you use an external HDD enclosure. They are available w/ USB and w/ eSATA connections (for connecting externally to your computer(s)). I don't recommend using IEEE1394 (firewire) as USB 2.0 is faster. eSATA is faster than USB 2.0 but is not a commonly available external connection on most computers yet.
(03) If a SATA port (connection) is not available inside your computer, you can install a SATA controller (if an expansion card slot is available in your computer) and connect your new HDD to the new controller.
(04) You can find information regarding your Compaq Presario HERE.
(05) I checked your motherboard specifications HERE. Your computer's original equipment does not support SATA. However, if you'd still like the HDD to be installed internally, just install a SATA controller and connect the new HDD to the SATA controller.
** Please, don't assign a rating to any of
** the experts' answeres or recommenda-
** tions until your questions have been answ-
** ered. Once ratings are assigned, the pro-
** blem will be closed and we won't be able to
** continue to assist you. We WILL keep
** working w/ you until your questions are
** answered.
Thank you,
BJ @:)
Apr 11, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
BURNED CKT
If it is the USB adapter that is part of the enclosure, (not the disk itself) you can transfer the HDD that is inside this enclosure into a generic external HDD enclosure. either that or you can use an external HDD adapter to access the data on a disk (like Magic Bridge), this is and adapter without the enclosure, and is fairly handy if you need to get data from HDD in this way.. or to Clone disks
Nov 02, 2007 | Maxtor OneTouch II 300 GB Hard Drive
3.5" Dynex USB 2.0 External Enclosure + Seagate Barracuda 7200 RPM 500 GB HDD problem with computer recognizing the HDD and the enclosure
 If your running XP , go to control panal , Admin tools>Computer Management >Storage > Disk Management . Look for it there . If its there see if it says what file system . If none format it . If it isnt there then chack the jumper on the hard drive it self . It should be set to master or cable select .
Sep 03, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Toshiba MK8025GAS 80 GB Hard Drive Logo
126 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
