Question about Hotpoint Washing Machines
Tripped out,no power,bang and flash at rear - Hotpoint Washing Machines
    Brigadier General:
  • 6,277 Answers
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
It could be any of the following: internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid, main motor (main suspect!), drain motor etc. etc. ;-0(
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Apr 06, 2011
Fire basically went bang I changed light bulbs and fuses but every time I plug it in it goes bang and trips the switch???
You have a short circuit in there. The bang is the short-time heavy current causing trip-out.
Jul 29, 2015 | Cars & Trucks
My Belling Synergie 482BL grill blew out yesterday
It's hard to say without actually seeing it, was it shorting out on the bracket that was supporting it? If so, this would be a weak point on the element and as it broke down it could have shorted out to earth through the bracket causing the bang/flash and tripping the breaker. If an element is just touching another metal part it won't short out because the filament is insulated from the casing. You should be able to find the element code on the casing near the terminals. Hope this helps.
Nov 11, 2013 | Ovens
Hi, my Blanco freestanding electric oven-FD9045WX-(gas cooktop) went out with a flash & a bang. The fan element was in pieces and the thermostat totally fried. The clock/timer does not go nor do the sparks...
Check for power at the supply terminals, follow it up to the high temp cutout > timer > multifunction switch > thermostat > element
Careful, don't electrocute yourself!
Oct 13, 2013 | Ovens
What is the cause if engine hard starting
Is the theft light flashing fast when you turn the key to the ON position? If you hold your foot on the gas will the engine start and run?
The problem you are having is usually caused by one of the following:
1. Fuel pump. When the problem is happening listen for a whine in the tank behind the rear axle. Try banging on the fuel tank with a rubber mallet.
2. Fuel pump and PCM/EEC power relay. Tap on those relays in the relay box next to the fuse box under the hood.
3. Crank sensor. Wiggle the connector on the sensor located next tp thecrank pulley behind the a/c compressor.
4. Idle air control valve. Tap on the IAC located on the back of the intake.
And re-check to make sure that the inertia switch in the trunk did not trip. Also make sure that the theft warning light is not flashing rapidly when you turn the key to the ON position.
Hope this helps; keep us updated.
Feb 16, 2011 | 1993 Ford Crown Victoria
Yesterday i was running the oven with 3 burners running. All of a sudden there was a large bang and a flash of light. It also knocked the power out to the house, thank goodness it was just a breaker. I...
If it was a large bang and flash of light as you described this would have been a short circuit, and this is why the circuit breaker tripped. A fuse wouldn't make as much noise and if the fuse blew the breaker wouldn't normally trip. Looking at the picture of the range it looks like the heating elements are under the glass top. This will have to be dismantled and if the short circuit isn't obvious, the elements will have to be tested to find the faulty one.
Feb 14, 2011 | Kenmore 90154 / 90152 Electric Kitchen...
Tv will come on for a couple of mins then go off the power and the lamp flash...just put a new bulb in it
Check it again,see if u put the cover back on correctly after u slide in the bulb housing.Sometime u trip the switch that why it resetting,lamp is flashing.If u do it right,didn't trip the switch.Ur ballast is dead,that why is still flashing,after a new bulb put in it.
Apr 06, 2010 | JVC HD-52G786 52" Rear Projection HDTV
Right front turn signal doesnt work but rear flashes fast. put new bulb in and does not fix the problem
Test the power & ground to the bulb socket with a multimeter. You have a bad connection or wire. The rear flashes faster because all of the power is going to one bulb and tripping the flasher quicker.
Mar 27, 2010 | 1999 Ford Explorer
Beko wma 1510s keeps tripping eletric sockets
I once had a machine that would trip the power if it had an unbalanced load when it went to spin. Whirrr.... bang bang bang bang... click! Lights out.
HOWEVER, this is highly unusual. If the machine is tripping the power then you should take great care. either you have an electrical fault (The motor may be failing and burning out, or another component may be failing unsafe) or you may have a water leak from a defective hose somewhere that is getting electrical equipment wet. Just remember that water and electricity are a very un-funny mix and your trips are there for a good reason.
Does the machine trip the power as soon as it is powered on, even after standing for days (Probably an electrical fault)? Does it trip as a particular thing happens, such as moments after the water coming into the machine or as the drum starts to agitate or the spin cycle starts or as the water empties.
Here are a few suggestions. Having thought about when the fault trips the power, do the following:
TURN OFF THE POWER AND UNPLUG THE MACHINE FROM THE WALL. Isolate the water supply. Make sure that the machine is drained of water. Now it's safe, look for water leaks.
Take the top off the machine (Usually a couple of screws in the back and then the lid will tap forward or pull back depending on the model). Look for signs of water inside the chassis, where the water pipes run from the inlet valve to the soap tray. The rubber gasket around the door may also be cracked and leaking. A classic point for the start of a leak is the rear bearing of the drum (This is the centre of the big wheel of the drum), you may see water marks or limescale buildup that has dripped from the bearing if it is leaking.
If you are looking underneath for leaks, never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, so the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend putting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
While the machine is on its back, look at the motor, If you can, have a good sniff at it (Do you smell burned electrical equipment?) Look around for other components such as printed circuit boards, visually inspect and sniff them too.
The golden rule here is if you can see a leak and you can replace the part, then that's great, go ahead and Do It Yourself. BUT be sure that when you have finished everything is absolutely dry inside (Use a hairdryer if needs be). When you are absolutely sure it is all safe then prepare to test. With everything connected up turn on the mains and start the machine. ONLY TOUCH THE PLASTICS until you are sure it is working exactly as it should. Even then you should of course check to ensure that there is no electrical power leakage. If in doubt, it the power trips, if you have the slightest concern, get a professional in, Your family will prefer to pay for his visit rather than your funeral.
Feb 01, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
