Question about Sony Handycam CCD-TRV87 Camcorder
I have a Sony CCD-TRV87E camcorder and I have several old tapes (which are probably fragile as two have been ruined through tape being torn). there is quite a lot of family material on the tapes and I wish to rescue what can be rescued to watch in the future. Can the material be copied either on to cassette tapes or DVD?. Thanks, Geoff Horton
  • Sony Master
  • 19,396 Answers
Hi.
To copy the Hi8 tapes you need to connect the camcorder to either a computer or to a recorder.
The easiest way is using an audio/video cable connected to the jack plug on the Sony Hi8 camcorder. The alternative is using the firewire port and a firewire cable.
In both cases you do not need to install software or to do settings. The camcorder output will be sent analog to the yellow video cable or to the firewire cable. If you use a recorder all you have to do is selecting input channel and start recording.
The AV cable you need (most Hi8 do not have firewire) should be like the one in this link. Double check before purchasing.
Regards.
Ginko.
Posted on Apr 06, 2011
Sony CCD FX500E ejects tapes
Mechanical fault. Contact any service technician; or the authorized service centre for Sony. Electro help
Nov 29, 2014 | Sony Video Cameras
HELP, I have borrowed an older camcorder from a friend. A sony Hi8 CCD-TR101 handycam. My child put the tape in backwards and now it wont eject. What should I do??
Tape can not be inserted backward in.It is impossible to to insert cassette inside video wrong way.
If it is not ejecting its eject switch might have got broken by physically pulling its cassette compartment outward before closing last time.
Its mini switch is very fragile in all sony models. so only way is to take to technician to bring it out.If i were you,I would buy used one from ebay at lower price than repairing.
May 07, 2010 | Sony Handycam CCD-TR87 Camcorder
Sony ccd trv43 doesn't play hi8 after placing an old video 8 tape
Try to clean video head with cleaning cassette, if same position than video head need to be change
Mar 28, 2010 | Sony Handycam CCD-TRV43 Camcorder
Moisture symbol on very old sony cam
I have a CCD-F385E with the same problem i kept putting the tape in and out and it started working.
Nov 25, 2009 | Sony Handycam CCD-TRV81 Camcorder
My camcorder can play old tapes but won't record
Your camcorder Sony DCR-HC20E has bad ccd imager problem and that part will be replaced to have live view to record on tape.
I can provide you ccd imager part number info if you want to repair it by yourself.
CCD Imager replacement in this camcorder requires expertise and fair skills of soldering parts in PCB.
Jul 11, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Problems with playing cassettes recorded on a hi8 camera
DCR TRV140E is a Digital8 camera
CCD TRV87E is a Hi8 camera,
(Hi8 is an analog format)
the tapes are the same size, wont help, the recording systems are not compatible
send them to a lab service ?maybe if there are only a few
or ebay a Hi8 camera and transcode them yourself
its not a solution, at least it clarifies the problem
Oct 23, 2008 | Sony Handycam DCR-TRV140E Digital...
Sony Handycam CCD-TRV87E
Its analog model of Sony camera series and you can not download its video in PC directly. You can connect Digital Model camera with PC.
Aug 06, 2008 | Sony Handycam CCD-TRV87 Camcorder
I have an 8mm high digital camcorder tape which got tangled in the camcorder. when i wound the tape back in the case and returned it to the camcorder it would only play a high pitched sound with no...
I've had to fix this problem several times. You need to open the 8mm cassette, and manually rewind to where the tape got twisted around. Then untwist it, and manually wind the tape back on the reels. and then put the cassette back together. If the tape isn't torn you should be fine. There might be creases in the tape- but they will only give you a slight picture glitch or drop out. You need to run a head cleaning tape through your camcorder before you try taping again. It might hose up the next tape if you don't.
Jul 24, 2008 | Cameras
SONY CCD-TRV138 8MM CAMCORDER
CCD-TRV138 Attempted to record or play. Not operating.
Dec 20, 2007 | Sony Handycam DCR-TRV140 Digital Camcorder
Old tapes don't play
I have the same problems. Makes me mad. I have a years worth of tapes that I can no longer view. My dog at peed on my old camera which was a digital one.
Mar 03, 2007 | Sony Hi8 CCD-TRV138 Camcorder
Open Questions:
See all Sony Handycam CCD-TRV87 Camcorder Questions
Sony Handycam CCD-TRV87 Camcorder Logo
106 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
