Question about HP Officejet Pro L7380 Laser Printer
The message 'Door is open' is displayed even though all doors are closed.
    Genius:
  • 1,196 Answers
I will suggest you try reset the printer, follow the instruction below to reset your printer, if the problem still persist, replace the cable that connects the printer to the power outlet. If that did not still fix the problem, you will need to reinstall the driver of the printer, you can get it at HP web site.
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold ?# and 6? keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
If that did not fix the problem, try this,
  1. Unplug the power cable from printer while the printer is powered on.
  2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
  3. Just turn on the printer and configure your printer new.
Posted on Apr 06, 2011
Will not run - display 'door open' even though it is closed.
Hi Carole, I understand that you are having problems with your Frigidaire Dryer door. It does appear the message "door open" indicates there is a communication error with the door latch assembly. This can sometimes be reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem is not corrected, consider replacing the Door Latch Assembly. Hope this helps! -JK
Oct 11, 2015 | Frigidaire Dryers
HP PhotoSmart computer indicates "open door"
Open "Devices and Printers" in start menu.
Right click printer with green arrow - click see whats printing.
Delete all documents.
Restart computer - then restart printer
See if that clears your error messages.
Mar 12, 2014 | HP PhotoSmart C4345 AllInOne InkJet...
Affinity Dryer code E66
It could be the door is coming open just enough to trigger the switch to the off position. Even though the door looks closed it could be partially open. Most likely the clips that hold the door shut are not tight enough that when the clothes hit the door it pops open a little bit. These clips are basically springs and over time they loosen up.
Aug 24, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Hi there, My Dell 1815dn printer makes a clicking sound when I turn it on, and displays an error message "fuser door open", even when the door is closed. I have removed the fuser and turned...
There is a switch that should "close" when the door closes.
But, that switch either is damaged, or it is not sending the "now closed" signal to the printer.
Check that there is no obstruction blocking that switch, nor any dust plugging it up.
Jun 08, 2011 | Office Equipment & Supplies
Display shows flashing 'door' warning,even though door is closed.....then when door is opened/closed a couple of times display will dissapear and re-appear every 3 seconds or so. Help!
The symbol indicates there is a problem with the door lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention. Sorry- Service call!
John C
Mar 09, 2011 | Washing Machines
I have a Maytag front load washer. Even though the door is properly closed, the display panel displays the message "door is still open, please close". I have even tried disconnecting the...
sounds like you got a bad door switch.... make sure the door switch is actually latching and the wires are still connected.... if all is good there then the pcb controller which is the main board is bad.....
Dec 31, 2010 | Maytag Washing Machines
How to take out the cartridge
Manually slide cartridge to middle of access door, then lift front part of cartridge up and then lift up straight to remove rest of cartridge
Aug 24, 2009 | Office Equipment & Supplies
Close door read out appears
You have a problem with the door alignment and the door switch.. The slightest movement triggers the door switch. You should have someone look at what is causing this issue.
For service on your saeco espresso machine in the New York area: www.cerinicoffee.com
May 24, 2008 | Saeco Incanto Classic Espresso Machine
HP Officejet Pro L7380 Laser Printer Logo
80 people viewed this question
Seeker5211
Seeker5211
