Question about Precor Exercise & Fitness
Hello, I bought this unit used and without 12 volt corda and adapter. Where can I get the specs on this unit and where could I order one online> Thanks in advance
ginko
  • 19396 Answers
SOURCE: Curtis portable DVD player, Mod #DVD8007B
Yes it si meant to work from 6 to 12 volts
Posted on Mar 19, 2008
SOURCE: Adapter specs
hi..
i've also got one without DC adapter... and looking around. find this link here: http://www.corg.ru/products/Network%20equipment/Compex/TP1008C saying: Power Supply: External power adaptor input 220V-110V, output 7.5v/1A
hope it helps
Posted on Oct 16, 2008
SpotBert
  • 231 Answers
SOURCE: Atari 2600 Console Power Adapter
This place sells replacement adapter (not original) for the Atari 2600.
http://atariace.com/atari/accessories.php
Posted on Dec 24, 2008
Bat1956
  • 585 Answers
SOURCE: No 12 volt power output from my acerpower 1000 motherboard
This seems to have a motherboard none too dissimilar to that of a laptop. It's hard enough to get information on a typical desktop motherboard, and those for laptops are even more obscure. You are not however dead in the water yet. The power supplies usually have fuses on the board, they are usually either blue or green, sometimes have a little "hourglass" on them. You can check them with an ohmmeter. If you're lucky, there's one blown from an earlier fan or drive problem. Hope you can find it and a replacement.
Posted on May 25, 2009
olwork
  • 237 Answers
SOURCE: need a power cord unit has no specs for amps/volts
Adaptec web site returns the following...
The replacement power supply must meet these specifications:
5 Volt DC Output with at least 2.5 Amperes capacity. The DC connector is configured with positive (+) on the internal or center lead and negative (-) on the external.
If you've found this reply to be a solution to your problem then please take time to rate this post. - Thanks.
Posted on Jun 28, 2009
How can i hook up a car stereo in the garage without using a car battery, and get the same juice as far as wattage and power???
Wire a 12 volt AC adapter to it. Connect the power to the positive wire, & the ground to the negative wire. If it's a low power unit a 1 amp adapter will work. If it's a high powered unit you might need a 12 volt 5-10 amp adapter designed for monitors, TVs, monitors, & some laptops. Beware some laptop AC adapters can be 16-36 volts. Make sure you use a 12 volt one, & know which wire is positive, or you'll burn it out.
Jul 08, 2015 | Cars & Trucks
Camper 12 volt system will not recharge.12 volt lights make low voltage alarm sound
most likely cause other than faulty wiring or bad ground is a faulty inverter. the specs should be taped to a panel near the unit or folded up nearby depending on the tech that installed the unit. use a voltmeter to confirm proper operating thresholds (if no spec sheet is present you can get one but contacting the manufactuer and providing a model number)
Oct 15, 2013 | Cars & Trucks
Harley davidson batteries are they 6 or 12 volt?
Hello, my name is Ben. Your battery is 12 volts. Here are the complete battery specs : 12-volt, 19 amp-hour, 270 cca.
Oct 11, 2010 | 2001 Harley Davidson FXST Softail Standard
There is a red blinking light and it is not cleaning.
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing and the unit would stop working. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. However the Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Aug 09, 2009 | Sharper Image Professional Plus Ionic...
Tottom direct power supply
No, it will fry the unit!!!
You need the cigarette lighter adapter to bring the voltage down to 5V. More than 5V will fry the One.
Apr 02, 2009 | Tomtom ONE 3rd Edition GPS
Voltage adapter
NO, it is very under rated and powered. You need an 18 volt and not a 12 VOLT. They should not be that hard to find in an electronics store. Also the amp rating is also important. Make sure you are matching both amps and volts AC or DC to the the label on the woofer or you could end up blowing the out.
Sep 24, 2008 | Altec Lansing AVS 300 Computer Speakers
Plugs for Astra Scanner 1220U
Ran across your request for information about the cables needed for hooking up the Umax Astra 1220U scanner. The scanner require a standard older version USB cable that hooks the scanner to your PC. The second cable is the Power Supply Adapter cable. The information listed on the Power Supply Adapter is listed below. P/N 490081-03 Input 120 Volt @ 60 Hz 0.3 amps Output DC 12 Volts @ 1 Amp Model # RWP481212 You should be able to get the scanner to work as long as you can find any power supply that has the listed Input/Output ratings, an adapter that will plug into the scanner. Hope this help you. disaksen
Apr 07, 2008 | Umax Astra 1220U Flatbed Scanner
Exercise & Fitness Logo
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
