Question about Liquid Video E15LCD1 15"
The monitor does not come on when the computer is turned on. I get an amber light, then it turns to green, then it says "NO SIGNAL" on the screen and the green light goes back to the amber color. Nothing else comes on the screen.
  • 1,179 Answers
Your computer system has failed the Power On Self Test or simply known as POST.
You need to ensure that all connections are making contact and clean your computer system. You may also go through my published guides entitled:
My Computer is not turning on!!! Is it dead!!! No POST!!!
How to Remove the Side Panels of My Computer Chassis!!!
How do I reset my BIOS/CMOS to defaults?
So your problem will most likely be due to a loose connection, fried mainboard or CPU.
damnor01
Posted on Apr 06, 2011
  • Mary Lou DeMott
    Mary Lou DeMott Apr 06, 2011
    I had my computer hooked up to another monitor to test it and the computer is fine - it's the monitor that's unresponsive.
  • damnor01
    damnor01 Apr 09, 2011
    Thats excellent, now that you have worked out that it is indeed the monitor you can begin to repair the problem.
    Claim warranty support if you can, it's possible that the inducer or the capasitors are fualty. However it is possible that some-thing else to causing the problems. Be sure by trying this monitor on another computer/laptop. Maybe the connector in the monitor is loose.
    damnor01
5 Suggested Answers
SOURCE: Dell 1901FP monitor
It is probably either a CCFL back light issue inside the LCD or a set of capacitors on the inverter/power supply board.
Would you be willing to part with it ?
Posted on Nov 14, 2007
Nitrotrike
  • 589 Answers
SOURCE: No Signal
You have to use the FN key and F5 to change between the LCD screen and the external monitor. It may be F8 also, depending on the laptop model.
Look on the F keys for a little picture of a monitor.
Once you have found it, hold the FN key and tap the F key and it should switch to the external monitor.
Posted on Jan 18, 2008
  • 96 Answers
SOURCE: No display (black) - power light is amber color
The video signal is not reaching your monitor, check the pins on the connector from the monitor to the computer, then check the video card:
Turn off your computer, unplg the power, and then take out the video card. Wait 5 minutes and then put the card back into the computer and turn it on. For onboard video; turn off the computer, unplug the power, then hold down the power button on the front for 5-10 seconds, then plug back in and turn on.
Make sure the video card is snug in the AGP/PCI slot. If this is built-in video, try borrowing a video card from another computer and install it in this one. If the borrowed card works, then replace you card. If video is built in, then you can disble the onboard video and use the new card without having to replace your motherboard.
Posted on Jul 14, 2008
budmrtn
  • 11361 Answers
SOURCE: when computer powers up, FPD1730 monitor green LED
Your PC video resolution is too high, please see link below:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
Posted on Nov 08, 2010
I switched my 23" hannspree monitor off using the on screen off switch, now when I switch it on the light at the bottom of the monitor shows green then turns amber and the monitor won't come on. This is a...
Normally, monitors will show green (or other color) when there is a video signal available.
Amber is fairly common to announce 'I'm here if you need me.'
Jan 12, 2015 | Hannspree Computers & Internet
Dell monitor starts well goes on a green light shows then it blacks out and the light on the front turns to amber(yelow)
The lamp goes "orange" when no "signal" is detected.
Check that the "video" cable is tightly-connected to both
the computer and the monitor.
Try the monitor on a different computer.
Try a borrowed monitor on your computer.
Try a different video-card inside your computer.
Mar 09, 2014 | Computers & Internet
When my Computer turn on the system Giving message "Monitor is going to sleep mode" and then I am not getting any display, but the system is on.
Monitor is not getting a signal from the computer. Ensure the cable connections are correct. If the monitor has a input select option, ensure it is set for the cable option selected.
If tower is a Dell, ensure the power LED on the Tower is Green/Blue If flashing Amber, power supply may have failed, solid amber, motherboard or a device connected to it may have failed.
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Dec 29, 2010 | Computers & Internet
The on/off of pc monitor (LCD) is blinking.
Most LCD monitor (depends on the brand) power indicator light will either turn from Green to Amber, or flashing Amber, or flashing green, when it does not detect video signal feeding it. So it may be normal with your monitor. Are you haivng problem with the display? If it displays he pictue OK then there is nothing to worry about.
Apr 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
The monitor will not turn on. When power button
First--was it working?
Did it suddenly stop?
When you see the LG logo, then it goes away, does the power light turn from green to amber? Sounds like that doesn't happen.
So--if you are getting a signal, you should see something.
If there is no signal, then the power light should change from green to orange.
With no lights at all, I suspect a faulty monitor.
Feb 22, 2010 | Computers & Internet
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Jul 14, 2008 | ViewSonic VX910 19" LCD Monitor
Liquid Video E15LCD1 15" Logo
90 people viewed this question
Top Liquid Video Computers & Internet Experts
Rommel Balcita
Marcin
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
