Question about NetGear DG834G Router
Is netgear dg 834 g support daynamic ip and static ip in same time
    Genius:
  • 1,447 Answers
Hi!
You cannot. Only one configuration can be set to it but workaround is you can use 2 routers, and set the other for static and the other to dynamic to serve its purpose.
Hope this helps.
Posted on Apr 06, 2011
Slow for donlwad for netgear dg 834 g
open the netgear smart wizard page(www.routerlogin.com).The username-admin and password-password(default).In the netgear page at the left side blue screen click on wan setup under advanced menu . 1.check mark the disable spi firewall box 2.change the mtu size to 1350. 3.If these steps doesnt show any improvement then your firmware version might be older version so upgrade the new firmware in router upgrade. This will solve your issue if not it can be browser try new browser.hope i have helped you. Rate me if my solution was helpful.Have a good day
Oct 04, 2009 | NetGear DG834G Router
Tip
Show Routing Table button will open a chart displaying how data is routed...
Show Routing Table button will open a chart displaying how data is routed through your LAN. Use the example below on how to configure a static routing:
STATIC ROUTING:
192.168.2.2 192.168.1.2
ROUTER C ----------------- ROUTER B ----------------- ROUTER A--------------PUBLIC IP ADDRESS
192.168.3.1 192.168.2.1 192.168.1.1
ROUTER A: Gateway Mode ROUTER C: Router Mode
1STENTRY 1ST ENTRY
DESIP: 192.168.2.0 DES IP: 192.168.2.0
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.2.2
HOP COUNT: 2 HOP COUNT: 3
INTERFACE: LAN INTERFACE: WAN
2NDENTRY 2ND ENTRY
DESIP: 192.168.3.0 DES IP: 192.168.1.0
SM: 24 SM: 24
HOP COUNT: 3 HOP COUNT: 2
ROUTER B: Router Mode
1STENTRY
DESIP: 192.168.1.0 WAN IP: 192.168.1.2
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.1.1
HOP COUNT: 2 DNS: DNS of 1st router
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
1stRouter must be set on Gateway Mode
2ndRouter must be on Router Mode
Use Static Routing
Select Entry
Destination IP = IP Subnet of the 1st Router
Subnet Mask = Subnet Mask of the 1st Router
Default Gateway = Interface IP
Hop Count = 1 + n
Interface= Connection to the 1st Router
Hope this help everyone.
on Apr 22, 2010 | Computers & Internet
Tip
HOW TO CONFIGURE STATIC ROUTING ON LINKSYS ROUTER
STATIC ROUTING:
1STENTRY 1ST ENTRY
SM: 24 SM: 24
2NDENTRY 2ND ENTRY
SM: 24 SM: 24
1STENTRY
SM: 24 SM: 24
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
Use Static Routing
Select Entry
Hop Count = 1 + n
on Jan 26, 2010 | Linksys Wireless-G WRT54G Router
THERE IS AN IP ADDRESS CONFLICT WITH ANITHER
Identify the peripheral conflicting with the router and change the network address on one of the two. Their setup programs should give you the possibility to do so. The address should look like: 192.168.2.x
x ranging from 0 to 9
Aug 02, 2009 | NetGear WGT624 Wireless Router
Router will not work only the power light is lit up
1. physical connections
2. hard reset
3. check ip. (if 169, assign static ip)
4. assign static ip
5. ping router (if getting replies, access webui, reload firmware. if not getting replies, the router may already be faulty, advise to phone netgear)
Jul 09, 2009 | NetGear WGR614 Wireless Router
My PS3 cant find IP address from Netgear router DG 834,what I have to do
make sure you are putting the network key correctly...if you dont know tha network key.. try the following.. . Connect a computer to the router using any one of the 4 available ports.
2. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
Click on wireless settings (under setup) from left menu.
Change the channel to 11
*-security option > select wep.. in KEY 1 put a ten digit number .... nothing under passphrase ..
Apply settings to save the changes.
*-then try to connect your PS 3
I hope the steps above will help resolve the issue. If you need any further help, please email us back so that we can continue to work on a solution.
I hope this information allows you to resolve this issue.
Jun 14, 2009 | NetGear DG834G Router
Can't get connection through router to internet
Hi,i beleive you have checked with your service providor as to what type of IP configurations is required.That is if you have a static Public IP or multiple IPs.If you have already checked the router configurations make sure your PC or laptop is configured accordingly.That is you have to configure your PC or laptop in a DHCP way.You can go to control panel from Start option and then go to network wizard,you will have 2 options,the 1st one would be assigning a static IP and then the next one would be Obtain an IP automatically.Click on the radio button there.Restart your comp and the router.You should be good to go.
For any further assistance please revert.
Apr 09, 2009 | NetGear WGR614 Wireless Router
Wireless INstallation
you need to ring your ISP to get a network user ID and password, when you enter these in to the router settings the Internet light will light up green.
Jun 08, 2008 | NetGear DG834G Router
Hi i losted my antenna of netgar dg 834 g v3
You'll need to either obtain one from the same model of router, or contact Netgear for a replacement (they're not all interchangable, alot of them require replacements that were made by the same manufacturer for the same model).
May 07, 2008 | NetGear DG834G Router
NETGEAR DG 834G ROUTER
Could you give me some overview of the topology of the network your trying to install the router on? (How it's all connected, and the ip addresses of the machines and other routers on the network (if any)) ?
Nov 29, 2007 | NetGear DG834G Router
NetGear DG834G Router Logo
51 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
