Question about Zanussi Washing Machines
My washer is emptying [its a zwf1430s]but its not spinning and the drum is also not going round! Help! Thankyou
    Brigadier General:
  • 6,277 Answers
If your washer is a front loader and not 'direct drive' it sounds very much like the belt is broken or the motor is malfunctioning.
Belt first.
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed although financially very attractive. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished at the same time. It depends on how old the motor is and how much wear the commutator has had. New motors are not cheap, though. It's your choice!
Hope this is your problem solved.
Good luck,
John C
Posted on Apr 06, 2011
Controller clicking around water going in but not tumbling and not spinning
if you push on the drum to turn it round is it hard to move, try this for me and get back thankyou.
Apr 05, 2014 | Maytag Neptune Washer Door Mah3000aww
My washer wont spin,
If you had to empty the water manually, i.e the outlet pump did not drain the water out then I would suggest the pump is either blocked or has failed. This will normally prevent the spin cycle from occurring. Try checking and cleaning the pump filter out.
Dec 31, 2013 | Frigidaire ATF6000ES Front Load Washer
E52 fault code displays on ZWF1430S Zanussi and drum does not turn in wash or spin cycle. Can you advice?
Zanussi 'E52' decodes as 'no signal from the motor tachometer' which ties in with the fact that the drum does not turn. Sorry but it looks like an engineer call-out, either for the motor or the control ;-0(
Good luck,
John C
Mar 25, 2011 | Zanussi ZWF1430W Front Load Washer
My washing machine wont spin or empty
You need to clean the filter.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Please rate my solution.
Thankyou.
Jan 30, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Drum filled during wash wont empty or go onto spin
Probably blocked filter.
Locate and remove large black hose fastended to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Please leave feedback for my suggested solution.
Thankyou.
Jan 08, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Wont go into spin cycle
will the drum go round when on a wash. and is it drianing water out if the drum goes round its not your brushes. if it not emptying water you pump as gone and will not spin if there is water in the drum
Jun 28, 2009 | Kenmore Washing Machines
WFC 2260 - Machine Fills and empties, but drum doesn't rotate
You probably need to replace the brushes in the motor.
Remove rear panel, remove belt from drum, undo 2 screws securing motor, unplug lead to motor, lever motor back with a screw driver, keeping hold of it, and remove motor.
You will find the brushes located at the opposite end to the motor pulley.
Please leave a fixya rating for my proposed solution.
Thankyou.
Feb 03, 2009 | Bosch Axxis WFL 2060 Front Load Washer
I have a hotpoint aquarius 1100 washer dryer wd51 was making a grinding noise we turned it off and a under wire from a bra was sticking through a hole in the drum pulled it out and it is complete but now...
The bra wire bears no relation to your present problem.
Remove top cover, screws at rear, and push top cover back.
See if the belt is still on, if it is, then select final spin and see if the motor and drum go round, if it does not, then the brushes in the motor probably need replacing.
Unplug washer, and disconnect the motor. you will find the brushes at the motor plug end, depress plastic lugs, and slide brushes out, if they are less than 5mm long, then replace them
If it is the belt that has come off, you will have to remove the rear panel to refit it.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Hotpoint Aquarius WD63 Front Load...
Zanussi washing machine
Filter can be clogged, pump can be dead or water outlet clogged.
Apr 11, 2008 | Zanussi ZWF1430W Front Load Washer
Washing machine not spinning
check for a capacitor on the motor if it has one, replace that to start with, that what it sounds like
Oct 10, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
