Question about Maytag Neptune MAH5500B Front Load Washer
No problem w/5+-yr Neptune washer/dryer pair, they have served us well. But - washer currently hinged on the left/latch on right, dryer hinged on right/latch on left. Of course, the washer hook-up is behind the dryer and dryer vent is 4 feet away on other side of washer. Is it possible to reverse the doors on each of these machines? I know, we didn't think this thru and 5 yrs is a little late but since we're remodeling I thought maybe better late than never and just wondered whether this is even something that can be done.
    Brigadier General:
  • 6,277 Answers
If the doors were interchangeable I would expect that to be a selling point (!) and mentioned in the manuals ;-0)
The problem is that the holes for the hinges, the door catches, the electronics/electrics for the door solenoid and close sensors need to be available already on the other side. On top of those requirements the doors need to be the same internal shape upside down, as they would be upside down if swapped over to the other side.
So sorry, all in all it doesn't look good, does it ;-0(
John C
Posted on Apr 06, 2011
Maytag door latch model medz600tw1
Check with a local appliance parts supplier to a replacement.
Jun 17, 2016 | Maytag Dryers
Want to switch the side the door opens on my lg dryer
The directions for reversing the door can be found on page 13 and 14, with pictures of the operation. Open the door to reverse. Check the 10 screws that need to be removed (6 on the left, 4 on the right). Remove 4 dummy screws with a screwdriver. Remove the two screws from, and disassemble, the latch. Hold on to the hinge while removing 4 screws from the hinge (to prevent the door from dropping). Remove the door from the cabinet cover. Move the door to the left side and insert a hinge into a hinge hole. Hold on to the hinge while screwing down the hinge (to prevent the door from dropping). Insert the latch to the right side and install the screws. Screw down the 4 dummy screws to the right side. Check that the door closes and latches properly.
Feb 02, 2013 | LG SteamDryer 7.3 Cu. Ft....
Maytag Neptune problems starting dryer button buzzes but will not start, sometimes start run for 20 min then stops dryer gets hot, might start later and might not start
if i had to guess, not being there and not knowing what you have tried: I would bypass the door switch and see if it starts. You will need to take all eight screws off, four on the hinges and four on the fillers(this is for switch the way the door opens left/right right/left) on the hinges you will need to lift up and out. Here is a website that will explain testing procedures as well as to other causes for a dryer not to start. hope this helps and if I can be of further assistance, just ask Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 27, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Can the door be reversed? ie open from left to right-----hinge on right side If so do you have instructions on how to do it?
Due to the shape of the washer door, and how it seats against the control panel, the door cannot be reversed on the Duet washer. There are no cut outs along the door opening to accommodate the door hinge screws and the door latch on opposite sides. The Duet DRYER, on the other hand, CAN be reversed. This may be an alternative configuration for you. Let me know if you want to know how to reverse the dryer door.
Jun 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag neptune dryer making load noise seems unbalanced
Sounds more like the dryer drum seal is deteriorating.
If the dryer tumbles the belt is intact.
To access the belt.
Open the door.
Remove 4 screws on right and left side of the door opening.
Raise the door on the hinge side and remove it.
Pull the front panel forward and remove it.
From there you can see what to do next.
Mar 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
How do you remove the top of a MAH5500B Front Load Washer
you need to remove the door hinges and the screws opposite the hinges. that will allow you to remove the front panel and the you will see the latch and the top hold down screws. once you have the top up, then you will also need to remove 2 screws that hold the latch to the upper frame. it is hard to pivot the latch out from the frame but it will come out and then you can replace the assembly.
by the way.. why are you wanting to replace the latch?? any failure codes? you might also have to replace the control board as it will fail when the door latch shorts out.
if you look at the control board you might see some of the resistors that have burnt out/ shorted out. sorry but it happens alot.
if it is less then 5 years old, then you might get it fixed under warranty for free part.
Jan 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer door opens with hinges on the left
nope sorry but all front load washers are built with a locking system on the door and that makes them impossible to change the door swing.
the only thing you can do is move the washer and dryer position by getting longer hoses and venting so you can have the washer on the left and the dryer on the right.
Dec 28, 2008 | LG Washing Machines
Maytag Neptune Thermal Fuse Location?
Yes, I just changed thermal fuse on the same model . . . take off the front door, the front panel and there it is; attached to the vent tube with a flimsy bracket
Mar 30, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Need to change door from left hand to right hand open on kenmore HE2
I am looking for the same answer on the washer. You can definitly change the dryer. The holes are on the other side under black tape.
Nov 16, 2007 | Kenmore 43142 Front Load Washer
Front load washer and dryer door change.
nope just swap the hinges, but make sure you turn them the correct way or you'll wonder why the thing won't close
Nov 03, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
95 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
