Question about IBM E74 17" CRT Monitor
Troubleshooting Monitor menu keeps on coming again and again. problem,
REPLACE FRONT SIDE OSD BUTTONS (EXIT,BRIGHTNESS,CONTRAST,MENU) IT IS MOISTURE PROBLEM
Posted on Aug 15, 2008
Auto adjust in progress
1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor.
2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu.
3. Use the down arrow button on your monitor to select "Factory Reset."
4. Push the menu button.
5. Use the down arrow button to select "All Settings." Press the menu button to save changes.
6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
Oct 10, 2014 | Dell E171FPb 17" TFT LCD Flat Panel...
How to stop monitor menu pop up in my Desktop's CRT Monitor ? The menu pop up keeps coming back and I have to keep exiting manually using monitor menu buttons.
r u sure about model number.bcoz 55v does't come with menu.
replace regulator 7805 near microcontroller if it is model 56v.
Aug 22, 2010 | SAMTRON 55V 15" CRT Monitor
How do u get to the menu on my aoc lcd monitor
hi
Depending on the brand and model of your monitor, there may be extra features that require special troubleshooting tips, or there may even be alternate ways of troubleshooting basic problems. For this reason, it is important to keep your user manual.
If you have come across an issue with your LCD monitor that cannot be corrected through the basic settings, you should consult the user manual to determine troubleshooting solutions for your specific monitor.
For example, The AOC 175F LCD monitor features a 90-degree rotating display, which, in order to rotate correctly within Windows XP, must have AOC's third-party software installed. This is not something required of all LCD monitors, as not all LCD monitors offer a rotating display.
If the troubleshooting section of your user manual still does not solve the problem, it may be necessary to contact the manufacturer's support team (via phone or web) to discuss what is wrong with your monitor
Jun 26, 2010 | AOC LM729 17" LCD Monitor
Sony SDM-HS75 Troubleshooting
Try this:
Under the menu options, there's Menu Lock. Switch it to "On". It worked for me.
My menu button wasn't working, so to access the menu, I had to hold down the arrow up button and push the arrow down button till I got to the Menu Lock Option.
May 05, 2010 | Nikon LS5000 Film Scanner
OSD Lockout bananas
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
May 23, 2009 | HP w1907 LCD Monitor
Monitor Menu Poping up again & again
1. First U can change Microswitches on front pannle (Menu,select,+,-)
2.check dry points in MICOM&EEPROM IC,HV IC and It's related.
3.check 5V supply and replace 5V Regulator.
Oct 05, 2008 | IBM E74 17" CRT Monitor
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Monitor keeps going off.
try while it''s on to press the menu button and in the top right is the model number.
Jan 20, 2008 | Dell E173FP 17" LCD Monitor
Menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Nov 04, 2007 | Acer AL1912 19" LCD Monitor
IBM E74 17" CRT Monitor Logo
123 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
