Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hello, my Aquarious Hotpoint washing machine stopped working during the final spin, the door is locked and the machine is full of water.what should I do?
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 06, 2011
Why does a kennmore washing machine work during the final spin and the water input does not stop?
does it only final spin? would say bad water inlet valve but should do the same in wash cycle also??
Mar 07, 2015 | Washing Machines
Hotpoint wf540
It's not pumped water out,,,so it won't spin
Jun 22, 2013 | Washing Machines
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
My machine will not pump out the water
The possible problems here are blockages or pump failure. Blockages are the more likely explanation but pumps can fail. If the washing machine will not empty the water out you may also not be able to open the door on some washing machines although these days it's much rarer to have a pneumatic lock on the door due to cost cutting (if a washing machine has a pneumatic door safety lock a rubber hose is connected to the door interlock from the pressure chamber bottle on the tub - water in the tub forces air up this tube and locks the door, which is released when the water is pumped out and the air pressure drops).
Some washing machines have a filter at the front of the machine that can be checked for blockages. Sometimes the filter is hidden behind a removable trim or panel at the base of the front. (Some Hoover & Hotpoint washing machines do not have any customer accessible pump filters - if in doubt it will tell you in the instruction book).
If your washing machine has a water pump filter and a filter drain hose you should be able to drain the water from the washing machine into a bowl without moving the washing machine. Open the pump filter flap and pull the small drain hose forward. Take the bung out and drain into a bowl. It's likely to be painstakingly slow but at least you don't have to try and pull out a heavy washing machine full of washing and water.
If your washing machine doesn't have a pump filter, or it has a pump filter but no draining hose then it's a bit trickier. To drain the washing machine, you will need to remove the drain hose from the drain pipe at the back of the washing machine, and lower it into a bowl or bucket. Many plumbers now plumb the drain hose into the U bend directly under the sink instead of a separate waste pipe at the back of the washer. If yours is connected directly to the u-bend, you can usually unscrew it easily. Remember though, that with the pipe disconnected from the U bend, any water poured down the sink will flood out into the cupboard until the hose is reconnected.
Once you have drained the water, you need to check for blockages in the pump by unscrewing the pump filter. If none is found, sometimes a blockage can occur in the plastic connector that the drain hose is connected to at the sink end (if connected this way)
Once you have the drain hose disconnected and lowered into a bowl or bucket the water should siphon out as long as the pipe is low enough. You are likely to get several bowls full of water from the washing machine. If little or no water comes out then it may be blocked by an item of clothing like a sock and it won't be possible to empty the machine this way or it is going to be a long process.
Once the last bit of water has drained out, the washing machine may now spin as the safety system for preventing a spin while water is in the machine will now recognize the water has gone and allow a spin. Keep the pipe low down and in the bowl or bucket and put the washing machine on a spin only program. Note, this last step is not strictly necessary as once drained, the door should open. However, you might prefer to try to spin a few more bowls of water out.
Clearly if you put more water into the machine it is likely to fail again until the fault is rectified but these instructions should at least get the clothes out.
Other possible obstructions could be inside the sump hose leading to the water pump. Many Hotpoint washing machines have a filter inside the sump hose which gets blocked. Finally, the pump itself can be faulty.
Jul 01, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
WMA46
check that the outflow pipe is not blocked. Turn off power supply get a bucket ready, disconnect the outflow pipe from the u-bend under the sink and check that it is not blocked.
Mar 15, 2008 | Hotpoint WMA46 Front Load Washer
WD640 Aquarious supersilent washer/dryer leaking from powder draw
during the rinse the machine uses a higher level of water, therefore check the door seal for holes,if the water is leaking from the soap drawer in the spin then this suggests that you may have a blockage in the outlet hose or in the sump filter, to check the filter remove the sump hose, the filter is hidden in the hose. Regards Engineer
Jul 29, 2007 | Hotpoint Aquarius WD63 Front Load...
Door Lock
door lock blown this sometimes blows tracks off the main pcb behind the control panel. appliance doctor
Jan 29, 2007 | Hotpoint WMA44 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
65 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
