Question about Ricoh Aficio 1013F Copier
Can you give me the replacement part no. for the Ricoh 1013F PCU
  • 263 Answers
You can buy the PCU for the AF1515. It is the same.
Part Nrº 411844 - PCU (Genuine parts In Ricoh off course)
Posted on Apr 07, 2011
Very dark copy
dark copies or background on the copies
if back ground on the copies need to replace the PCU unit
Apr 07, 2014 | Ricoh Aficio 1013F Copier
Sc302 after every two days
check the connector on your pcu either that or you have a bad pcu or high voltage control board
Sep 01, 2011 | Ricoh Aficio 1013F Copier
Sc 302 code error
A charge roller current leak signal is detected
- Possible causes -
· Charge roller damaged
· Charge high voltage supply board defective
· Poor connection of the PCU
Dec 24, 2010 | Ricoh Aficio 1013F Copier
Richo 1013f copier problems-grey lines on copies
Most often this problem is coming fro the PCU or Photoconductor Unit. If you open the right side door just look for the long greenish colored cylinder. It should be clean. If you see a toner film or more specifically the same "lines" on the surface of the drum that you see on the copies then you will know. If this is the case you will need a new PCU. Installation is a piece of cake.
Here is a link with pictures, part numbers etc.
http://www.precisionroller.com/search.php?q=ricoh+1013+drum
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Ricoh Aficio 1013F Copier
Hi.when i m switch on the Ricoh 3310L Fax,the message is coming as shown below "time to change PCU"
Order a new PCU from Ricoh. Power off the machine and replace the pcu.
If you try and cheat it it will run for a short while and then lock-up breaking some gears. Cheeper just to order a pcu. Check Ebay, i see alot of Ricoh supplies there.
Jan 23, 2010 | Ricoh 3310Le Fax Machine, FAX3310Le...
Ricoh Aficio 1013F
you need to install printer on computer as network printer from the supplied CD.
Mar 27, 2009 | Ricoh Aficio 1013F Copier
Ricoh aficio cl3500n reads replace colr pcu what is this?
The PCU is the photconductor unit. There is a black pcu and a color pcu. Did you replace these or replace the toner cartridges??
http://www.websitetoolbox.com/mb/copierquestions
Jan 19, 2009 | Ricoh Aficio CL3500N Laser Printer
The PCU Reset procedure needed
switch the machine off at the switch hold down online and escape while switching on the switch , hold the buttons till you see service mode on screen , you need to go to engine , then drum , there you will find the setting to reset the pcu , or under data log is a function pm counter clear if it is giving you replace pcu on the screen
Nov 01, 2007 | Ricoh Aficio AP3800C Laser Printer
161 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
