Question about Sony STR-DG520 Receiver
On occasion, my Sony audio receiver model DG520 will begin making a clicking sound that is like a morris code signal but with no pattern and is not constant or consistent. It does not affect the sound or the picture of what I am watching but is very annoying. If I turn it off for a few minutes, it will usually be okay for the rest of the evening, but sometimes it starts up again almost immediately after turning it back on. Can you help me? Thanks.
  • 643 Answers
That usually indicates the powersupply board is going bad.
Posted on Apr 06, 2011
Testimonial: "Thanks very much for the fast and informative reply. I spoke with a Sony dealer and he had no idea what was wrong. Thanks again. "
Having trouble syncing audio with my new led tv. I run audio thru a sony receiver model str-dg520. Where do I find the settings to make it sync?
Normally you would to the TV settings under audio you would have to disable the tv audio and point it to your receiver I assume you have a surround sound. Make sure you are also using the right audio cable RCA or digital optic cable
Oct 24, 2013 | Yamaha Rx-v465/rxv465 Home Theater...
Im having a hard time getting audio useing the hdmi ports on my sony str-dg520
The HDMI on this receiver is for video pass through only. It basically only serves the same purpose as an extension cord for an HDMI cable that's too short.
For audio you need to connect either a digital coax, an optical or composite cables.
Aug 25, 2010 | Sony STR-DG520 Receiver
I have a Sony STR-DG520 5.1 receiver. My problem is that I can hear a high pitched background whine from all the speakers, even if the volume is set to zero or muted! If I switch the audio source off, the...
do u have the unit earth grounded? sounds like AC hum, most amps have a ground lug, make sure that is grouned and the power plug to o the amp has a good ground.
Jun 15, 2010 | Sony STR-DG520 Receiver
STR-DG520 receiver will not power up
hello it sounds like it could be a capacitor problem or a leaking transistor
regards
shaun
May 27, 2010 | Sony STR-DG520 Receiver
Video but no audio
This receiver does not support audio via HDMI. You need to connect BD player via spdif cable. Use optical or coax depending on what does the BD player support - receiver supports both.
Dec 24, 2009 | Sony STR-DG520 Receiver
How can i use Sony 5.1 Receiver STR-DG520 in India (120V to 230V)
Sorry, but according to Sony this set operates only on 120 volts at 60 hertz. As we have no real need for up converters here in the USA, I cannot recommend one for your application. The best course would be for you to visit one of your local electronics stores and provide them with the specific current requirements. I'm certain that an appropriate converter is available in your area.
Bill
Aug 21, 2009 | Sony STR-DG520 Receiver
I connected my STR-DG520 5.1 to my TV Toshiba
In your str-dg520 menu you have the option to have the sound routed to your tv or out your stereo system. select which one you want.
Jul 12, 2009 | Sony STR-DG520 Receiver
Goes into protect mode..
you probly have speaker wires arching. unplug them and replug thm in making sure no bare wire is showing
May 17, 2009 | Sony STR-DG520 Receiver
Need unlock code for sony str-dg520 5.1
The HDMI inputs are pass through inputs only. The reciever cannot recieve any sound signals through the HDMI's. The reciever acts as a selector switch for the HDMI inputs only. Whatever input you have selected on the reciever is the one that is being sent through the output to your TV. The "unlock" display shows when there is no sound signal sent to the reciever. There is no code to unlock. This is the reciever's way of telling you that there is no sound being sent to it from that input. Since there is no sound being processed from the HDMI's, you need to hook up an additional audio cable from the device to the reciever (preferrably an optical cable). When the reciever recieves an audio signal, it will then "unlock". I know it is confusing. I had to look into this problem myself, so I'm happy to help. Higher end recievers will actually recieve and process sound signals from the HDMI's. When I bought this one I thought it was going to do the same. That's what I got for trying to save a couple bucks on the cheeper model! Although it is still a good reciever.
Dec 25, 2008 | Sony STR-DG520 Receiver
Sony STR-DG520
STRDG520 requires that the audio is from the digital optical or the digital coaxial to have sound. Just add digital audio from blue ray player to the amp and your good to go.
Nov 09, 2008 | Sony STR-DG520 Receiver
Sony STR-DG520 Receiver Logo
144 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
