How do I install my wireless mouse. I have already pluged it into the usb, but nothing is happening.
  • 73 Answers
Make sure the batteries are installed
see if there is a button on the bottom of the mouse or the usb dongle, it may need to be synchronized
check for a power switch on the mouse.
Windows may just need time to install the mouse driver.
Posted on Apr 06, 2011
I cannot get my new optical mouse to work. GE98548. I have the USB receiver plugged into the USB port, pressed the button and the red light came on. I pressed the Connect button on the mouse and nothing...
Hi
Basics first (some or all of which you may already have considered).
I assume you have batteries in the mouse.
Check the manual for the correct sequence and procedure for introducing the mouse to the transdponder for the first time. Sometimes the buttons on the wireless transponder and mouse need to be pressed and held for a certain amount of time.
Sometimes there needs to be clear line of sight between the mouse and the transponder, depending on if the signalling is Infra Red or RF. Consider a Male to Female USB extension cable that allows you to plug the male end of the extension cable into the PC's USB socket and the transponder into the female end of the extension cable, enabling you to place the transponder in clear line of sight of the mouse.
You will know when the mouse is properly connected to the transponder because when you press the Connect button the transponder should blink in response.
Leaving the transponder connected to the PC, try connecting a wired USB mouse to different USB port to see if you can get a moving cursor with it. If the Hardware Wizard appears, you may need use it to install USB drivers that are already in windows but not yet installed and active. After this, disconnect the wired mouse and test the wireless mouse again.
Also check in your BIOS (see which key to press - often DEL or F2 -during boot from the menu at the foot of the first boot screen to enter BIOS Setup and check if Legacy USB function is on or off. If off, use the + or - (or sometimes page Up or Page Down) keys to toggle it to on > F10 > Enter > boot into windows and test USB wireless mouse again.
If none of these ideas solve the problem, the device may be faulty and should be returned under warranty.
I hope this helps.
Aug 24, 2011 | GE Wireless Optical Mouse
Toshiba Wireless Mouse (PA3706E) not working
just install new battery and press the conncet button in mouse .
Dec 18, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Microsoft wireless mouse 3000; put in new battery, still nothing
nikcorra2488,
try this: plug in the USB key & check for the green light. Then go to start, control panel, & double click mouse (with whatever mouse works). Check the hardware tab and see it the computer is recognizing that the mouse is there. If it is there, it should be working fine. If not, then perhaps you need to reinstall the USB port drivers. Sometimes this will happen when you've upgraded from 1.0 to 2.0 USB ports.
Hope this helps.
-samson39
Jul 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
Wireless mouse doesn't work
This problem was happening on my system but i managed to fix it easily! What has happened is your itouch software has become corrupt so it will only recognise your keyboard thus the usb connection. You will need to download/install off disc onto your computer again but do NOT go to uninstall program manager on windows as it will not appear there because even though you can access the itouch configuration panel, the database is corrupt and the administrative system will not recognise this. Just download/install via disc and it will just install with no alerts unlike most programs which will recognise the program is already installed onto the system. Once the setup is 92% it will freeze for a second then the found new hardware window will appear on screen go through that process and your mouse is back to normal and your keyboard will work via itouch software.
(Please note that this will only work on windows)
Nov 26, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Nothin works and nothin is detected
doesnt need batteries does it dl latest driverers form website maker try ohter ports
Oct 09, 2008 | Microsoft Wireless Optical Desktop Comfort...
Wireless mouse
INSTALLING THE MOUSE
STEP 1 - Battery Installation:
The first step in installing your Wireless Wheel Mouse is to install the batteries.
1 - Locate the two AAA sized 1.5 Volt batteries that came in your Wireless Wheel Mouse package.
2 - Remove the battery compartment cover located on top of your mouse by pressing the cover release button and sliding the cover backwards.
3 - Install the two batteries into the compartment paying close attention to proper polarities.
4 - Replace the battery compartment cover.
STEP 2 - Connecting the Receiver:
If you are connecting the mouse to a notebook that has an onboard pointing device or if you are using a keyboard with an onboard pointing device, you may need to
disable that device before installing and using the mouse.
Sep 14, 2008 | Computers & Internet
Problems with Micro Innovations Keypad and mouse wireless
I don't have the manual or the cd and I have replaced the batteries in both the keyboard and the mouse, but they will not work. when i go to control panel and look at mouse and keyboard settings, it says they are both installed and working properly. Any suggestions?
Apr 25, 2008 | Micro Innovations PD7250LSR Wireless RF...
Usb problems
mmmm you need the via chipset for that. Emachines website will help you with this problem. their tech site is real good also the tech chat. they can online fix it for you
Apr 25, 2008 | E-Machines T6528 PC Desktop
Wireless mouse and keyboard
Push the connect button on the wireless base, then push the connect button on the keyboard or mouse, that is supposed to reconnect the device. Make sure the wireless base is close enough to the keyboard.mouse, and nothing metal is blocking the path between the keyboard/mouse and the base.
Jan 25, 2008 | Labtec Wireless Desktop Keyboard/Mouse...
k24674
jasbo
jasbo
