Question about Panasonic Televison & Video
DVD UNLOCK CODE
Trying to obtain region unlock code - currently Region 4 - Australia want to make region free - help would be greatly appreciated
  • L Jefferson
    L Jefferson May 11, 2010
    What make and model is it?
  • 376 Answers
I've checked and theres no remote input to make it multi region. It could be done with a Pocket pc with infared apparently but this seems tricky. I searched 6 different DVD code sites for a code but the pocket pc one is all it came up with. Its seems to be the same for most DMR versions. You could also use a pre-cracked remote to do it. Sorry i couldn't find anything for you.
Posted on Aug 07, 2008
Panasonic DVD Recorder & VHS Combo unit Model no. DMR E75V.
Your help is greatly appreciated
Regards, mark
SOURCE:
How do you unlock region code on Samsung BD-H6500 smart blue- ray player
The hack for this 3D Blu Ray player is the same as for previous models.
1. Make sure NO disc or usb stick is inserted into the player.
2. Turn on your your blu ray player.
3. When the main menu appears, press the REPEAT button followed by the region code your player is currently locked to - depending on which country
you are in (eg: in Australia press "REPEAT 7 6 8 8 4".
4. In the top right corner you will see your region code flash (eg: 4 for Australia).
5. Press 9.
6. Turn off and on and your BD-E6500 is now region free.
How this differs from the opening post is no need to open and close the disc tray.
So, after pressing REPEAT please enter one of the following codes the matches your current region lock:
1 - 2 9 3 3 4 (US)
2 - 5 7 5 3 8 (Europe)
3 - 5 6 7 3 2 (South East Asia)
4 - 7 6 8 8 4 (Australia / South America)
5 - 5 3 8 1 4 (India, Ukraine, Belarus, Russia, Africa)
6 - 2 4 4 6 2 (China)
9 - Region Free
Then press '9' and your player is region free.
Jan 12, 2016 | Samsung Televison & Video
Philips mini DVD PET702/75 multi region unlock code
To check the software version and change
region code of your DVD Portable
1. Power ON the DVD player and open the DVD
door
2. Press the “SETUP” button on remote control,
then select the “Preference MENU”
3. Press the remote button in the sequence as
9 -> 6 -> 5 -> 3
4. The LCD display showed the existing region
code. Press (navigation up) or
(navigation down) repeatedly to select the
number from 0 to 6.
5. Refer below table for your region code setting
moz-screenshot.jpgmoz-screenshot-1.jpgRegion
1=USA
2=Europe
3=Asia Pacific
4=Australia, New Zealand
5=Russia, India
6=China
Select “0” setting = Region Free (confidential)
Feb 28, 2009 | Philips Televison & Video
Unlock code to unlock dvd player to play dvds from all regions
0082 0015 0089 0004 00F2 0033 0017 0010 0091 0013
make sure you have the disc draw open and enter the above code via your remote.
let me know if it works
Jan 10, 2009 | Televison & Video
Unlock region code for Philips DVP 3256
Region code hack for PHILIPS 3256 x/94
1. Go to Setup. [from remote]
2. Select the Preference Page.
3. Press 1, 3, 8, 9, 3, 1 on the Philips DVD Player remote.
--> It will show current region code [ for example 5 ]
4. Now Press the up/down key to select "0" which makes it region free.
5. Press ok and exit setup.
Probably the same would be applicable for 3258, 3268, 3986.
Good Luck!
Jan 02, 2009 | Philips DVD625 DVD Player
Setting the player to region free
Apologies everyone.......
The instructions for the DVD-P181 are actually correct as described in other posts but can be a bit confusing. Please allow me to clarify using my example;
With your DVD-P181 switched on, follow these instructions using your Remote Control;
1/ Press the <DVD> button
2/ Press <0><0><0><0><0> (this is 0, 5 times)
3/ Press <repeat> (careful not to press the <repeat A-B> button)
4/ Press <7><6><8><8><4> (ONLY if your player is currently region 4 - refer to the table below for other pre-set regions)
5/ The Region window should now appear on screen saying that your current region is Region 4 and asking what region you want to change it to.
6/ Press <0> for the new Region (0 is region-free)
7/ Press <Open/Close> button once (to open the tray)
8/ Press <Open/Close> button again (to close the tray
9/ Press <Power> button to turn the player off
Now, when you turn the player back on, you should be able to play DVD's from any region. Good luck everyone.
_______________________________________________
This table refers to Step 4. You need to choose the Region code which your machine is currently set to, to unlock the Region Menu which allows you to set the device to another region.
In my example, the DVD player was purchased in Australia is by default set to Region 4. The 5 digit number I needed was 76884.
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Dec 28, 2008 | Samsung DVD-M105 DVD Player
I need a region unlock code for a Samsung DVD r-130 Recorder/Player in Australia. Any help would be greatly apriciated. Thank You. Matt. [email protected]
1. Connect the device (without disc tray), expect the message "No Disc" appears on the display;
2. On the remote control press the MENU key;
3. For original equipment in the region 4 * (Brazil) enter 76884;
4. The current code of parts of the appliance should be shown (4), then press 9 and then MENU, to complete press the MENU key again.
5. Turn off the apareho and religue it then.
* NOTE: For appliances natives of other regions use the code for:
Original Region 1, type: 29334
Original Region 2, type: 38767 or 57538
Original Region 3, enter: 56732
Original Region 4, type: 76884
Original Region 5, type: 53814
Original Region 6, type: 24462
Jun 02, 2008 | Televison & Video
Unlock region codes
i fund this by dargan and it worked for me "Def" Camino Real 3, Panama:
icon_minipost.gifRegion code hack posted by dargan, August 23 2008:
Same hack for DVD283 worked for DVD-277
<clipped from other post>
Region code hack posted by mhardial, January 25 2008:
DVD Regional Codes
Code Location
**1** USA (incl. territories), Canada
2 Europe (Germany), Japan, South Africa
3 Southeast Asia
4 Latin America, Australia, New Zealand
5 Russia, rest of Asia and Africa
6 China
0, 255, 9 MULTI REGION
Region Code Change
NOTE: Make sure you DO NOT have a disk in the tray while performing the region code procedure
DVD Players
New DVD283
1. Open DVD Tray
2. Press the “Menu” button
3. Press 8888
4. Press the “Display” button
5. Region Code Number shows up. Use the numeric keypad to select your region code number (0 – 6).
6. Press the “Setup” button to exit.
Mar 07, 2008 | Televison & Video
Televison & Video Logo
342 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
