Question about Cell Phones
My back ground light keeps turning off i have had my phone for 7 months why is this doing it
    Problem Solver:
  • 10 Answers
Hardware fault. consult the mobile technician nearby.
Posted on Aug 06, 2008
My jenesen uv8020 wont power up i hit the rest buton and the blue buton lights turn on but turn right back off i replaced my front broken screen it powered up it worked for a 7 months when i would tu
I need more info. Did you check the ground wire to make sure you have a good ground? Some installers try to rely on the antenna for a ground when hooking it up due to laziness and it will eventually burn the stereo out from low voltage, or, you could have amps that are killing the battery enough to drop the voltage down and it's killing the stereo. I have also seen ground loops kill stereos, but, I need a bit clearer info as to exactly whats happening to answer the question.
Nov 29, 2014 | Jensen Car Audio & Video
Passenger side reverse light bulb stays lit when lights are turned on. Replaced bulb but didn't solve problem?
Sometimes such a problem is because the ground wire for that light is bad, and so the electricity is feeding to ground through the back-up light.
Try to run a new ground wire from that light socket to the steel body ground.
Be blessed.
Feb 16, 2013 | 2005 Chrysler 300
I have a ground and white wires and a black wire... which do I hook to what... can I put green ground, and black with black, but can't i put my red and white on the white? For 7-Day Digital in-wall timer...
Utilitec 7-day timer will only replace single-pole switch.
Single pole switch has two brass screws and a ground screw.
Links below show wiring for both Utilitec 7-day timers
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
If this is not your timer, then add a comment and specifically state which timer you have and which wires came off which screw on old switch.
The best way to start is to identify exactly which wires came off old switch.
How to wire
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
If the free answer is not right for you, then take advantage of fixya phone service.
Expert helps you via phone for a price.
Dec 30, 2010 | Garden
Head lamp keeps burning out. replaced head lamp at
You either have a bad ground or the bad electrical connection at the light socket is "simulating" a bad ground. This is putting a high resistance on the bulb and it's taking it's toll by burning out the bulb. I would start with a new socket, and CHECK the ground. If you still have the issue, I would run another complete ground wire and not even worry about checking the ground itself. the Stick
Dec 10, 2009 | 2006 Suzuki Grand Vitara
I installed a pioneer Deh P49001B car stereo in a 1997 dodge stratus with wiring adapter from best buy. everything works great until you switch on the lights. all power to stereo is gone.
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
May 13, 2009 | Pioneer DEH-P5200 CD Player
Static red light
i had exactly the same problem but mine was green
i sent it off to sony ericsson and they sent it back. It was fine for about a day and then the green light came on and hasnt gone off.
urgh!! so annoying
Jul 31, 2008 | Sony Ericsson S500i Phone
Motorla Razr V3x wont turn on, and now wont charge.
I had this problem too. Unfortuneately it happens often with that phone as i have been told. Mine got fixed about 10 months ago because it was under warranty and now it has happened again out of warranty and i have to pay for it to get fixed. Why should i when its going to keep happening every few months? It has nothing to do with the battery or the charger. The only way that it can be fixed is to take it to the manufacturer.
Aug 09, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola RAZR V3 - Problem With Buttons
my son's phone is about 7 months old too and today when i turned it on it would not go past verizon welcome screen, no matter what. i don't use this phone, but if your volume controller is on the keyboard it could be that the keypad is going bad, which appears to be common with the razr. if it is the keypad, you can pick up a keypad flex cable for about $12 on ebay, and it's a very easy fix, but if it's just 7 months old, i'd return it under warranty, that's what i'm going to do. Let me know what you find out. I just think it's really strange that our phone suffered no damage of any kind, it just quit.
Jul 29, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
76 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
