Question about Brother XL-2600
Needle broke & i changed it out now when I push the pedal the motor makes rattling noise & needle does not go. If I move the wheel manually it will sew though.
rizla
  • 1463 Answers
SOURCE: Foot pedal is not working!
sorry no nothing about sewing manchines ,althought this could be a wire loose in the pedal to sewmanchine .
ah you can get a manual from here http://welcome.solutions.brother.com/bsc/public/eu/eu_ot/en/doc/manual_index.html?reg=eu&type2=-1&prod=hf_xl2600i2610euk&c=eu_ot&lang=en&flang=all
if this helps
regrads
riz.
Posted on Nov 20, 2007
SOURCE: needle jam
stuck the whole machine the needle did not move .needle and wheel handle both are stuck
Posted on Feb 28, 2008
bibleman01
  • 334 Answers
SOURCE: Brother CS-8150 Won't Work in Reverse
Look at the feed dogs under the foot see if they are raised high enough to pull the material through.
Posted on Dec 05, 2008
  • 66 Answers
SOURCE: I was given a brother
Hey RM check the bobbin area and see if the hook area has any thead cought in it you might have to remove the bobbin case to see it
Posted on Jan 30, 2009
louislevel_2
  • 374 Answers
SOURCE: brother sewing machine
There is cluch on the handwheel that connect motion,try to tighen this If negative,There are two small bevel gear (hard PVC )connecting to the upper crankshaft where the handwheel was connected.This transmit motion when motor run, most commonly the vertical rod where one bevel gear was connected maybe broken or viceversa at the upper crankshafting that holding the bevel drive gear is broken try to check this.
Posted on Mar 07, 2009
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
In sewing mode the motor turns but needle does not move. I have checked bobbin & upper thread - any help?
1. Try to turn the hand wheel. Does the needle move?
2. Make sure the center wheel on the hand crank is tight.
Try the hand wheel now. If you still don't have luck try this.
3. Loosen the center wheel on the hand wheel. There is a small screw on the center wheel on the front or side. Loosen it until it almost comes out.
4. Now tighten the center wheel. (clockwise) Does the needle move if you move the hand wheel? If it does you can tighten the small screw.
5. If this doesn't do the job you will have to take the cover to the motor off. The motor has a bolt to loosen. As you loosen the bolt you can move the motor until it tightens the belt and makes it aligned as well. Run the motor slowly with the foot pedal and adjust the motor until it operates at it's highest speed. Now tighten. Replace all covers.
6. The belt is sometimes in need of replacing but not usual. You will know when you take the panel off.
Apr 16, 2015 | Sewing Machines
Turning wheel disconnected from motor?
I would try replacing the needle, as it may have got bent. I have had this happen and I was sure needle wasnt effected. when I changed needle it was fixed. The very tip of my old needle had a slight curve and wasnt connecting to correct spot on throat plate. make sure you have needle in highest position and that stitch selection in turned back to straight stitch.
Nov 08, 2013 | Brother Limited Edition LS2250PRW Project...
The needle does not move when the foot pedal is used.
Make sure that you pushed the bobbin winder all the way to the left.
Jimmy
Apr 01, 2012 | Singer 7444 Mechanical Sewing Machine
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
My Pfaf 1222 made a rattling noise, but was sewing. Now it jams with thread after two revolutions, need to hand turn the wheel to get it to turn those 2 turns. I broke one needle. I bent another. When I...
Check the manual for maintenance infromation.
Noise can be from lint in the bobbin area.
After cleaning, re-thread the machine with the presser foot up to see the combination of cleaning and "presser foot up" threading helps.
Mar 29, 2010 | PfaFF Tiptronic 2030
The needle is stuck,not moving.its very hard and the motor makes a sound but needle does not move.
Refer to your manual and make sure the bobbin winding feature is disengaged.
Turn off the power and remove the needle and if there is fabric, remove it also.
Open the needle plate look for thread tangles.
After cleaning, turn the hand-wheel by hand to see if it moves the needle up and down.
If it does, press on the foot pedal to see if it is working.
Any of the above could be the problem.
Mar 01, 2010 | Kenmore Sewing Machines
Kenmore 10 stitch needle won't move
hi there,
push or pull hand wheel clutch to engage
motion of needle and shutter.
if not check belt on downside of hand
wheel open cover motor,loosen bolt cover
see belt check if engage on pulley by
holding hand wheel move belt if
hand wheel move,if not tighten screw on
pulley from hand wheel and moter.
have a nice day and thanks
Apr 03, 2009 | Sewing Machines
Needle will not move
Tighten the inner knob on hand wheel to make the needle move up and down.
Jun 28, 2017 | Yamata FY920
Brother XL-2600 Logo
78 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
