K2850T tv - there's a vision but I have no sound. Tried with external speakers - still doesn't work. Any ideas?
    Scholar:
  • 146 Answers
Is there any chance you switched your tv to receive SAP audio - check that out because if what you are watching isnt broadcasting an SAP feed you will get no audio
also dont know what the source you are using but you might want to check audio cables going into set and make sure audio is set to go out of source from output you are using
hope this helps - if not write back wityh as many details you can give me ( source, wiring, etc)
good luck!!
Posted on Apr 06, 2011
No sound coming from internal speakers Toshiba Projection television Model 50h82.
Some TVs have a set up option to disconnect internal speakers when an external audio amplifier will be used.
Dec 29, 2016 | Samsung Audio Players & Recorders
I have a Zenith P60W26P 60" Plasma TV that the sound went out. Any ideas? and yes, I tried the mute
Check the audio settings and make sure that you did not set it to external speakers only.
Jan 14, 2015 | Zenith monitor P60W26P User Manual
This t.v. doesn't have an audio output. How can I connect external/ sound speakers to it?
Hello!
you can use the Digital Coaxial port on the back of the tv.
use a mono RCA and connect it to a digital receiver eg:surround to get external sound.
(this only works with receivers with a digital input and will not give any sound
if connected do a analog input)
Sep 05, 2011 | Coby TFTV3227 32 in. LCD TV
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
I have a panasonic TX-37LZD70 lcd tv the sound has suddenly gone -tried all the obvious ie mute and volume any suggestions
Have you tried connecting some external speakers to the audio out ports? Most modern TVs at minimum should have analog RCA outputs. See if you can connect external speakers to verify functionality of the sound processor. If you get sound, that probably means one of the mosfets or speakers have failed. Either way, a DIY repair would be next to impossible. Your best bet would be to contact a repair shop and see if this is a common problem with your TV. Allthough inconvenient, you may find it acceptable to use the external speakers if they work. Good luck.
Jul 06, 2009 | Panasonic Televison & Video
Sound Problems with JVC AV-35BP4 TV
The audio output stage for the speakers may have failed in the TV set. If the set has an earphone jack, it is also possible that the jack has a fault (very rare, but I have seen this).
Are there external speaker outputs to try other speakers?
Jerry G.
Apr 29, 2008 | Televison & Video
No Audio, picture fine
this is a very common problem just unplug tv for 5 minutes it
should fix it . simple fix most of the time with rca and proscan.
If that does not do it go into menu scroll down to audio and then press on .
thanks doctor video leading edge electronics
Apr 28, 2008 | Proscan PS36800HR 36" TV
Hi there!
The amplifier section may be at fault. Could also be IF or dry joints in that area. Also check the speakers(Highly unlikely though) Good Luck,JUS004
Feb 24, 2008 | Televison & Video
Surround Sound gets static
I'm trying to understand if the speakers are connected directly to the TV, or via an amp. If you have an option try connecting them through an amp so that the TV doesnt have to amp them, you'll get better results. even if there was no static in the first place its a better idea. Good luck!
Jan 02, 2006 | RCA MM52110 52" Rear Projection HDTV-Ready...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
