Question about Yamaha RX-V663 Receiver
When i first power it up it only outputs about ten percent of nornal sound if i reboot it it usualy works properly just wondering what might be going on thankyou 663 receiver not 3d
  • 2,098 Answers
Hi whitecloud91,
This was caused by dried filter capacitor in the pre-amplifier stage(where the volume control is connected) and/or in the main sound output circuitry(where the large heat sink located). This capacitor is not totally faulty, need a little warm-up to make itself stable but the symptom will get worst. To isolate the faulty parts, you must have a capacitor checker to determine its condition and pinpoint where the faulty one. A leaky capacitor will do the same symptom, it has a physical indication of defect like bulging/dome at the top.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 06, 2011
Xerox Phaser 8550 error code 07,01043:90804
This fault occurs due to the printhead being stuck in the tilted position. There are many reasons why this fault will occur, too many to mention.
More often than not, your problem will require the printhead and process gear to be re-aligned in order to get a reboot but sometimes it is possible to get a reboot by doing the following;
Turn the printer off, wait ten seconds then turn it back on again. Wait for the printer to start warming up to about 5 or 10 percent. At this point, switch the machine off again by the machine switch NOT your wall/plug switch. Wait ten seconds and switch on again. Now let it run through its normal cycle. The success rate for this method is small, possibly only 1 in 30 machines will recover.
The reason this will sometimes work is that, when you turn the machine off from the warm up, it powers down using its proper head parking routine, you will notice, it takes a while to shut down. If the original fault was due to say a power cut or someone pulling the plug out it is possible for the printer to find its home position and boot ok.
Unfortunately, a lot of the time, the reason for the fault is printer related and such, this method does not work. But it is always worth a try.
Hope this helps.
Jan 19, 2011 | Xerox Office Equipment & Supplies
Xerox phaser 8560 DX error 07 010 43:14011
Hope this helps.
Dec 07, 2010 | Xerox Phaser 8560DN Laser Printer
My screen is broken, how much does it cost to repair? Is it better to just buy a new phone?
New screen costs very low of the original price of new phone. As it will be near of just ten percent of the price of your phone. So you should purchase new screen as it will work properly and just like the original screen.
Jan 22, 2010 | Nokia 6303 Cell Phone
Heating element is going out it work about ten percent of the time? need parts number and ways to get parts. and is it the actual heating element or something smaller electrical since it is intermitent ?
It may be your heating elements, but I would check your circuit breaker to make sure its putting out 110V on each phase as the heating elements are the only part in your dryer that use 220V, so if the circuit breaker is not outputing enough voltage that could be your problem (it's also a less labor intensive fix). NOTE: IF YOU ARE GOING TO REPLACE YOUR CIRCUIT BREAKER TURN OFF THE MAIN BREAKER TO HOUSE TO POWER DOWN THE BUSS BAR THAT THE BREAKER IS PLUGGED INTO.
Nov 03, 2009 | Kenmore 84072 Electric Dryer
Reboot and select proper boot device
Hi, ull need to check the boot device priority in ur BIOS which is accessable usualy by pressing the delete key at the start of the boot process. If everthing is correct there and yet it doesnt boot from ur hard disk, try changing it to boot from cd and check if it boots. If it does then i think either your hard disk is corrupted or your OS.
Jul 08, 2009 | EliteGroup ECS 755-A2 Motherboard
Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
Apr 27, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
My TV
the old ticking sound... yes.. it means your power supply shut down and continously trys to reboot ... hense the tick sound as the voltage rises and fails.
Means you got a short somewhere. Most likely the obvious high power consuming High Voltage Suppy... and as I found in 99.9 percent the Horizontal power Transistor shorted... 80 percent Flyback, 10 percent audio... 10 percent some odd circuits like vertical or yoke as shorted.
you have a short.
Sep 10, 2008 | Sanyo DS24424 24" TV
Samsung max ws750
The following is generic for any of these recievers with the fault you are describing.
The output stage, and also incuding the driver stage on one or both of the sound channels most likely has shorted output devices. This can be either output transistors, or output IC's depending on the design.
When this type of short occures, usualy the driver transistors or driver IC's, and other support components may be damaged.
The cause is usually from driving the amp too hard, or operating in too warm an environment, or using speakers that are not of the correct impedance for the amp.
An experienced tech that works on audio equipment at the component level should be able to service your amp. The cost may be on the expensive side depending on the parts that are damaged.
Jerry G.
Apr 12, 2008 | Audio Players & Recorders
T.v does not make a sound when turned on, and shows black screen
It is very often that the power supply, and or the horizontal output stage have some faiiled components. There are many components in these areas that can cause this problem. This would require proper troubleshooting.
In these sets, if the fuse is blown, there is usualy a much deeper fault that caused the fuse to blow in the first place.
Jerry G.
Oct 25, 2006 | Sanyo DS31590 31" TV
Yamaha RX-V663 Receiver Logo
154 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
