Question about Amana Washing Machines
The washer is not level.How do I adjust the machine so it doesn't move around?
    Brigadier General:
  • 6,277 Answers
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
Good luck,
John C
Posted on Apr 06, 2011
Amana washer shakes
I know this is a daft question but can you rock the washer when it is empty just try from right hand corner then the left hand corner if you can move it back and forth the washer is not level and needs the legs under the washer adjusting to level it and stop it jumping about other then that if it is an old machine their are two shock absorbers in the machine that can leak and let it bounce around if one side has gone and not the other both are easy to fix once you know with one is the problem
Apr 12, 2014 | Washing Machines
Where is the balance sensor located on my Kenmore Elite Oasis washer
Hello.
Top loading washing machines can emit loud noises and vibrations if they are not properly balanced. Imbalanced machines are the result of large loads of clothing that rock the machine causing one or more of the feet to rise off of the floor. Front loading washing machines do not have this problem because there is no side-to-side motion. Kenmore top loading washing machines have self-leveling feet on the rear of the machine and adjustable feet on the front of the machine.
1 plug the washing machine's power cord from the electrical socket. Pull the washer away from the wall, or out of the laundry closet, so that it is easily accessible.
2 rasp the top back of the washer on both sides and tilt it forward until the back feet are off of the ground by 4 inches. Lower the washer gently back to the ground. This maneuver, adjusts the self-leveling rear washer feet so that they are fully extended. You may need the assistance of another person to do this.
3 lace a level on top of the washer near the front edge. Look for the air bubble in the level to determine which side of the washer is out of balance. The side that the bubble leans toward is the side the needs to be raised.
4 Move the level so that it is positioned along the side edge of the washer and check to see if it is level from front to back. If it is level, move it to the other side of the washer and see if it is level.
5 Lift up on the front of the washer and insert a wooden block or brick under the front bottom edge.
6 Crouch down on the floor near the front foot that needs to be raised. Use your fingers to twist the threaded foot clockwise to retract the foot and counterclockwise to extend the foot further. If necessary, adjust the other front foot as well using the same method.
7 Lift up on the top of the washer and slide the block out from under it. Place the level on top of the washer to check that it is level. If the washer is not level, replace the block and continue adjusting the feet until the air bubble is centered in the level.
8 Crouch down on the floor near the front of the washer and use a 14 mm wrench to twist the metal nut on each front foot counterclockwise. Twist each nut until each is tight against the washer and will no longer move.
9 Plug the washer's electrical cord back into the wall.
And the problem will be solve.
Thanks.
Nov 13, 2011 | Washing Machines
The washer gets unbalanced on small loads that never happaned before a couple of weeks ago. The machine has a unbalance spin load compensator but makes ungodly banging now, that's never happen until...
the problem with small loads is that the tub gets unbalanced very easy,if it spins correctly with a larger load there's nothing wrong with the washer,it's just unbalanced,you can open the lid and move the clothes around by hand to try to balance out the load,very common,also has the washer been moved?check for level,if it was moved one of the legs could have moved to put the washer unlevel,
Mar 08, 2011 | Maytag MAV5920E Top Load Washer
My front load washer keeps going off balance. Even with small loads. I have leveled the washer but I'm not sure what else to try.
Material needed to carry out the function.
  • Level,Another person,Wooden block or brick,14 mm wrench
  1. Unplug the washing machine's power cord from the electrical socket. Pull the washer away from the wall, or out of the laundry closet, so that it is easily accessible.
  2. Grasp the top back of the washer on both sides and tilt it forward until the back feet are off of the ground by 4 inches. Lower the washer gently back to the ground. This maneuver, adjusts the self-leveling rear washer feet so that they are fully extended. You may need the assistance of another person to do this.
  3. Place a level on top of the washer near the front edge. Look for the air bubble in the level to determine which side of the washer is out of balance. The side that the bubble leans toward is the side the needs to be raised.
  4. Move the level so that it is positioned along the side edge of the washer and check to see if it is level from front to back. If it is level, move it to the other side of the washer and see if it is level.
  5. Lift up on the front of the washer and insert a wooden block or brick under the front bottom edge.
  6. Crouch down on the floor near the front foot that needs to be raised. Use your fingers to twist the threaded foot clockwise to retract the foot and counterclockwise to extend the foot further. If necessary, adjust the other front foot as well using the same method.
  7. Lift up on the top of the washer and slide the block out from under it. Place the level on top of the washer to check that it is level. If the washer is not level, replace the block and continue adjusting the feet until the air bubble is centered in the level.
  8. Crouch down on the floor near the front of the washer and use a 14 mm wrench to twist the metal nut on each front foot counterclockwise. Twist each nut until each is tight against the washer and will no longer move.
  9. Plug the washer's electrical cord back into the wall.
Hope this help?.
Thanks for visiting.
Oct 17, 2010 | General Electric WCVH6800J Front Load...
My frigidaire top load washer moves around when it spins
The tub has what is called "dogs". They are little brackets that keep the tub aligned so it doesn't flop around.
Another thing to do is adjust the feet on the bottom of the washer. It works best when you use a level on top of the washer and then adjust the feet so it is completely steady.
Sep 01, 2010 | Washing Machines
Washer is shaking around when washing it moves around about 6 inches every wash
You will need to adjust the feet on the bottom of the Washer so that they sit level on the ground. If you lift up the ends of the Washer you can either screw the feet in or out to level the Washer, and then tighten the nut down on the feet to keep it tightened.
Aug 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My machine vibrates so much that it moves around and the drawer with detergents opens in the middle of a cycle. What is the problem? How can this be fixed?
make sure it's sitting on a solid floor, next you need to use a level tool to level front, side and across, to level the machine, do not use wooden blocks, you need to adjust the legs, that come with it, an adjustable wrench can work.
Jan 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
It moves from its place while on
If you mean your washer is dancing around while in use, this is usually only due to it not being level on the floor its sat on. adjust your washing machin legs till yout washing machine is level with equal pressure on its legs.
should fix the problem if its a levelling issue.
Jan 03, 2010 | Washing Machines
LG Front Load Washer Problem
The washer is not leveled correctly.  You will need to adjust the front feet to level the machine.  Run a load of clothes in the washer.  When it gets to the spin mode, check the level of the machine by pushing the front left corner and the front right corner.  If the noise quiets down on either corner of the machine, adjust the legs on that side.
Jul 22, 2008 | LG WM-1832C Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
