Error Code K 32 TVCRW 11111 on Sharp lc-32le600s showing on screen. Using HDMI port 2 connected to pc. Also TV only turns on if input select and volume (-) is pressed together and power is turned on. Help...
  • 208 Answers
SOURCE: HDTV Sharp- Input select to watch Cable tv
On the sharp remote you will find an input button. You depress the input button and a menu will appear and highlight the input you are presently on. Hit the input button again to select the next input. If you wait to long to depress the input button it will not work and you have to begin again. This unit will only hightlight inputs have a component hooked to that input.
Posted on Feb 05, 2008
  • 49 Answers
SOURCE: Show Microsoft Power point on Sharp Aquos hdtv
try to right click the desktop and choose graphics options, you will have to select the correct output for your setup. i.e. laptop to monitor, etc etc see if that works,...sounds like you have a connection, you will have to play with these settings until it pops up. worked with a similar scenario, sometimes you have to do stufff twice and it works on the second time not the first, electronics are weird.
keep changing the settings in the graphics options until it comes up the way you want it.
Posted on Nov 13, 2008
ccmg60
SOURCE: Sharp Aquos LC-37D64U Skips HDMI
The problem was caused by ME not setting up my Harmony Remote correctly after buying the new TV. The remote was programmed to turn on SA8300>turn on Receiver>Turn on TV>Select channel 3.
Simple change from select channel 3 to select Input 4.
Posted on Mar 26, 2009
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
SOURCE: Auto Switch does not work for HDMI inputs
Try this:
http://www.avforums.com/forums/6539544-post3094.html
Posted on May 17, 2009
Where is the HDMI connection on my Sharp LC-46SB57? I installed X1 and cannot get picture. Sharp Input 1,2&3 are grayed out but Inputs 5Roku & 6blue ray work.
The X1 box acts like a set-top cable box. The HDMI output can be connected to any HDMI connector. There are three HDMI connections on the rear of the set. You have the Blu-Ray connected to one of them, Input 6. You should have no issues with connecting the X1 to either Input 7 or Input 8. There is no specific "TV" HDMI connection. You simply use the remote to select the HDMI port that the X1 is connected to.
Nov 18, 2015 | Sharp Televison & Video
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
I have a Sharp LC-42D62U and have our DVR from cable connected to HDMI #4. I want to hook up a Roku via HDMI to HDMI #5 but the input source shows unavailable sign. Is there a way to get both HDMI...
If your Tv has this many HDMI ports it will have a menu to access each one separate. Go to your Tv's settings menu and look for your HDMI ports to use.
Jul 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp lcd tv 32 400m. pc input problem, can't fungtions input 5 (blur)
i connect tv cable but vedio is not working only audio is working in top K letter it is showing in screen
plz send solution
chakradhar
9440176800
india
Feb 01, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Flickering screen (LC-52SB55u) with HDMI cable input from Sharp Aquos Blue Ray. HDMI working well from other inputs
Do a quick google for this on the AVForums site where you'll find numerous threads covering this problem. First, select the HDMI input before turning on the blu ray player. The handshake over HDMI is the problem. I have the same problem with a Technika blu ray which is fine on my other TVs.
If this doesn't solve it then you ned a firmware update which can be downloaded from Sharp's website and installed using a USB pendrive or by PCMCIA card from Sharp if you have an older model with a rocker on off switch and no USB update port on the back of the TV.
Nov 28, 2010 | Sharp LC52SB55U LCD TV
I try to connect my hdmi cable to my laptop with a vizio hdmi cable and the tv says not format... how do i address this issue
The input which you are using sounds like a USB port (which is looking for a virtual drive that needs to be formatted). Double check to make sure your laptop actually has an HDMI input (most laptops do NOT). The USB ports are different than HDMI.
Jan 04, 2010 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Mar 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
