CANT TELL IF MY CAP LOCKS ARE ON OR OFF WHAT DO I NEED TO SELECT TO KEEP THIS FEATURE
  • Daniel Wakefield
    Daniel Wakefield Apr 06, 2011
    I am assuming you mean the caps lock on the keyboard, correct? The light does not work? Do you have a word processor program like MS Word?
  • Ryan
    Ryan Apr 06, 2011
    are you on a mobile phone or a computer? if it's a computer, should be to the left of the keyboard, often next to the 'A' button.
  • 27,725 Answers
If your caps light is on a light will/should show on your keyboard
hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/numcapsscroll-indicator/3000-2072_4-10604212.html
On-screen real-time indicator showing the status of the Num, Caps and Scroll Lock buttons on the keyboard. NumCapsScroll Indicator monitors their status and indicates it in the System Tray with its icon, with a tool-tip when you mouse-over its System Tray icon, with a small On-screen Keyboard-like panel and a sound indicator. It's also an identical utility for laptops that are not supported with Num, Caps and Scroll Lock LEDs on their Keyboards.
What's new in this version: Version 7.0 is compatible with Windows 7.
Posted on Apr 06, 2011
Turning off parental controls on Toshiba tv lcd 42hl800A
Press the "Menu" button on the remote control, and scroll until you come to the "Preferences" menu. Select "Parental Control and Locks," then press "OK." If your TV does not have a "Preferences" menu, go directly to the "Locks" menu. Enter the four-digit PIN that you selected when you turned the Panel Lock feature on. You may have to scroll up or down to access this area
Press the "Up" or "Down" buttons on the remote until you reach the Panel Lock feature. Move the cursor to select "Off," and press "OK."
Jan 05, 2017 | Toshiba Televison & Video
How do you keep the door locked so you can use t self cleaning feature
Good Morning Friend,
I understand you want to know how to keep the door locked on your Frigidaire oven, model# FEB24S2AS, so you can use the self-clean feature. The "Door Locked" light will flash until the door locks when the self-clean cycle is in use. It glows constantly after the door locks. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Gas cap
Carolyn
You may need to press down and twist the gas cap at the same time..similar to a "child safe" bottle of asprin or medicine. Usually you remove it counterclockwise
Then when you put gas cap back on press down and turn it clockwise to seall the vacuum in the gas tank.
Many newer cars have this gas cap feature
Mar 31, 2014 | 2004 Pontiac Grand Prix
Locks keep activating on renault kangoo whan parked
check relay for the locks and also wiring in the doors there is generally one module that runs the system also check the switch in the door it may be bad
Jan 28, 2014 | 2008 Toyota RAV4
Online chat
Go into ur phone settings, security settings, phone and sim. Scroll down to lock code.
To change the code to ur own, select it, and it will ask for the default lock code which is 12345. Once confirmed, it will ask u for ur new code which can be
4 or 5 digits. Pick something u wont forget. Then it will ask u to confirm it.
Done.
Now if ur phone has an autolock feature, u can set it by selecting it and selecting user defined and set a time, like 10 or 15 minutes, up to u. Ur phone will lock after
that set time of inactivity. U will still be able to take calls, but need to put the code in to do anything else. Code will be requested each time u turn ur phone on.
Depending on ur nokia, u may have remote lock feature. With this, u set a password, and if ur phone is stolen and ur worried that it hasnt autolocked, u can send that
password to ur phone from any other phone by sms and it locks it.
U may also have the feature to have the phone lock if the simcard is changed and u can enable that too.
Finally, u have pin lock. This locks ur sim card, even if a theif takes it out and puts it in another phone, the code will be required to use ur sim.
To change the pin code, its the same as the lock code change, but the default code u need to put in first is different. Its usually 00000 but if that doesnt work, select
cancel, and call ur service provider, they will give u their sim pin default code, and after uv done that, select pin request on, and it will ask for a code every time u
turn ur phone on.
Its a good idea to make ur pin and lock code the same so u just enter them consecutively on start up
Hope this helps. [answer taken from Yahoo.answers]
Jan 22, 2014 | Nokia Cell Phones
How to remove the fuel filler neck on my 1999 Dodge Grand Caravan 3.8 ltr. engine
OPEN GAS CAP FLAP THEN YOU NEED TO DRAIN GAS BELOW FILLER NECK.THEN LOOSEN REMOVE SCREWS IN THE GAS CAP FLAP AREA WHERE FILLER TUBE CONNECTS THEN GO UNDERNEATH VAN LOOSEN REMOVE HOSE CLAMPS AND REMOVE THE HOSE AT THE FILLER NECK BELOW THE GAS TANK.SPRAY WD40 AROUND HOSE AREA AT METAL FILLER TUBE STICK OUT GAS TANK.CAREFULLY USE LARGE PAIR OF CHANNEL LOCK PLIERS TO REMOVE WORK HOSE OFF METAL TUBE FROM GAS TANK. IF YOU CANT REMOVE HOSE WITH HANDS.BECAREFUL NOT TO MAKE ANY SPARKS.PLACE RAGS AROUND ANY METAL PARTS TO KEEP CHANNEL LOCKS FROM HITTING METAL MAKING SPARKS.
Jun 23, 2011 | 1999 Dodge Grand Caravan
Is there supposed to be a caps lock indicator on HPw2207 keyboard,? If there is, I must be missing something I can never tell if I am in upper or lower case letters ( not too good when entering a password)
That model goes to a LCD monitor, not keyboard. Windows can make a tone when you hit the cap locks, so you can use that as indicator or you can use the on-screen keyboard which should visually show the cap locks being pressed.
How to tell when you hit the cap locks key
Windows On-screen keyboard
Mar 25, 2011 | Computers & Internet
My ECCO tv is locked<
Hello
Toshiba's Panel Lock feature allows you to save your settings on your television so that no one else may change them and only the On/Off switch may be utilized from the TV's front panel. Parents may find this option useful to prevent children from accessing programs containing violence and other inappropriate content. Once you turn this feature on, certain steps must be followed to turn it off again.
1. Press the "Menu" button on the remote control, and scroll until you come to the "Preferences" menu. Select "Parental Control and Locks," then press "OK." If your TV does not have a "Preferences" menu, go directly to the "Locks" menu.
2. Enter the four-digit PIN that you selected when you turned the Panel Lock feature on. You may have to scroll up or down to access this area.
3. Press the "Up" or "Down" buttons on the remote until you reach the Panel Lock feature. Move the cursor to select "Off," and press "OK."
Feb 17, 2011 | Toshiba 32A33 32" TV
Can't disable lock feature on LG rumor touch
hi, it is very possible to unlock it permanently or increase the time..all you need to do is to go to setting on your phone...check your phone setting, then try to locate your automatic key guard....you could increase the time or you select off..
Jul 14, 2010 | LG Rumor LX260 Cellular Phone
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
