Question about Bosch Washing Machines
Can you help me with a problem on a Bosch Classix 1400 washing m/c please? Fabric conditioner is no longer being used up during the wash cycle
    Brigadier General:
  • 6,277 Answers
This is a common problem with many machines.
I suspect that the conditioner/softener tray needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this does not work, pull out the dispenser drawer far enough to be able to just see the softener tray, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
Good luck,
John C
Posted on Apr 06, 2011
My Bosch classix 1400 smells vile, its a rotting smell. I have tried several machine cleaners. Nothing seems to work.
I'm guessing that you use mainly biological detergents, and low temperature washes?
Just put the machine on its hottest wash, preferably 90 deg C. If you can get it to that temperature on a delicates cycle, then even better (water level is higher in delicates). A little chlorine-based cleaner, e.g. Milton or VWP, will help.
Once a bacterial biofilm has started growing, retail 'machine cleaners' can't properly penetrate it (and why would they ~ the makers want you to keep coming back for more). High temperature will always break down the biofilm.
May 17, 2015 | Bosch Washing Machines
Bosch maxx 1000 - when finished cycle, leaves central fabric conditioner drawer full of water + trace of condtioner.
Check that the hose that connects the drawer to the tub is clean, fabric conditioner normally gunks up especially on colder wash cycles.
Apr 01, 2015 | Bosch Washing Machines
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 20, 2012 | Bosch Washing Machines
Bosch Logixx 8 Fabric conditioner not releasing into wash cycle
This video will show you how to keep your soap draw clear and how to service the parts
Jan 24, 2011 | Bosch Washing Machines
Conditioner is staying in draw when water should be feeding into draw at end of cycle it is going into both other draws but not the conditiner one any ideas
Hi, welcome to Fixya. Immediately what comes to mind, actually two things. Fabric softner can often be too thick to dispense properly in front load dispenser's unless deluted half & half with water before adding. The other thing is this, it could be the water inlet hoses connected backwards, i.e. Hot going to cold and cold to hot at the washer, hence in the rinse cycle when cold water should enter the fabric softner chamber it doean't. Let me know what you find as I will look for your reply. Thanks for visitng "fixya". Please take a moment and rate this info accordingly but also let me know if you need further assistance. Good luck. Macmarkus :)
Jun 22, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My washing machine isnt accepting fabric conditioner
have you lifted up the conditioner flap on the drawer, you would of seen a long plastic tube sticking up, this tube gets blocked from time to time resulting in the softner not going into the machine. if you have cleaned this tube when you took the drawer out, then the only other cause is the solonoid vavle is the fault. this is easily replaced.
if you have any difficulties, you may if you wish, email me at appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 03, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classix 1000 express fabric conditioner won't empty
Get a piece of stiff wire, and make a right angled bend at the end of it, then poke it in all the holes on the top of the soap drawer compartment, this should solve your prob.
Please rate my solution.,
Thanks.
Jul 16, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My bosch classix washing machine is not dispensing the fabric conditioner properly. Often the fabric conditioner is left in the dispenser unused, just now it went in with the washing powder. It has...
The water going in to the dispenser is blocked by sludge.
Remove the dipenser tray.
Look up inside the tray hole, at the 'roof' of the tray hole, and there are four holes (square on my machine) where the water flows in - in the middle of the 'roof'. These will be blocked with sludge. Try to poke them clear with a nylon tie or plastic coated wire - should go in a few inches.
It worked for me.
Aug 06, 2008 | Washing Machines
Bosch Classix 1200 washing machine fab conditioner tray (middle) will not empty
check the water in let valve connections and the current over it when it is in the fab cond. cycle. Replace valve if current is on. Valve price range is 15-35$
Apr 17, 2008 | Washing Machines
Washing Machines Logo
89 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
