Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Belt broke how to put new belt on i need manual
Replacing belt on brushroll on a Hoover SH40060 canister
Your manual is pretty lacking. Most all brushes have holder guides on both ends, normally the entire brush and guides will lift straight out of the head if the belt is broke, there could be a locking clip, make sure the area is clean so you can see it, but the brush head has to come out somehow or a new belt can't go on, some have the top of the head comes off, the cover, this way you place the belt on the brush, set the brush back in the head, then you set the belt onto the motor shaft from the top.
What ever you do, make sure you watch how the brush comes out and the guides, if you need to take a marker and put a mark on the guides so you know what the top was and how they go back in.
Apr 03, 2013 | Hoover Platinum Cyclonic Bagless Canister...
Belt Reset Button
please go to the next web page and download your free manual from elextrolux:
http://smallappliances.electroluxusa.com/en-US/Customer-Support/Guides-and-Manuals1/
God bless you
Jul 27, 2012 | Electrolux Vacuums
My hoover fusion carpet brush wont revolve
Hello, I hope your having a good day considering your problem.
It sounds like you have done everything and more you can at your end. My opinion based on your detailed description is that is possible you might need to barrings in your roller on both ends. Now sometimes you can take it to a local vac shop (just the roller of course) and they can put the new barrings in as well as maybe it is possible that something is just loose or warn out. Sometimes you are better (for cost of repair reasons) to buy a new roller. I would first personally, take the roller off, and take in to local shop and have them give you a price to replace or repair. That appears to me what has happened. Its also possible, some dirt and debre has got trapped in where there barrings are and it is sticky or just plan stuck. Mike
Dec 02, 2011 | Hoover Fusion Plus Cyclonic Upright Vacuum...
How to replace a belt successfully on a Bissel Powrforce 3522?
How do I replace the belt? I don't know how to get into that area.
May 21, 2008 | Bissell 3522 PowerForce Bagged Upright...
Belts keep breaking
Check the brush roll ends to see if they have melted or frozen. They should turn freely, part #361869-1. Make sure the belt isn't being pinched somewhere.
Apr 15, 2008 | Eureka WhirlWind Litespeed 5844 Upright...
Belts breaking frequently
I had the same problem. Broke 2 belts before I got online and noticed this site! What I found was, the roller ends were not turning freely. I had cleaned the hair (nasty) off the roller, but the ends were still not able to spin around without some force.
What I did was, removed the roller and on the 2 ends there are 2 black plastic caps which fit over the bearing, I removed the plastic caps and put a little WD-40 on the bearing, or any industrial lubricant, even new motor oil will work. After putting on the WD-40, I spun the roller end around a few times and the WD-40 lubricated the bearings and Voila! The roller end spun freely!! I put the black caps back onto the bearings on both sides, reinstalled a new belt, it's been working great since.
It saves the cost of a new roller.
Todd M, Fremont CA
Feb 28, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Need instructions on how to replace the belt on a hoover dirt finder model u5321-930
You can download the manual from the link below: http://www.hoover.com/Media/ModelPDF/U5468900.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 28, 2007 | Hoover 5416-900 WindTunnel Bagged Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
240 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
