Question about IBM X236 Server
Hard disk not detected - IBM X236 Server
  • 73 Answers
Check to see if hard drive is fully plugged in/reseat cables/harddrive. see if this fixes the problem
if not listen to see if the drive spins up, if it fails to spin up then the hard drive is bad
if hard drive spins up but clicks at regular intervals, it is bad
Try a different drive cable
Try to replace with a known good hard drive, if it still is not detected check the bios to see if the drive controller is enabled.
If the controller is enabled and cannot detect a hard drive the controller may have failed.
Posted on Apr 06, 2011
My Computer use windows XP Operation System. hp 540 laptop when I turn on windows, it show black screen with cursor. It cannot continue log to windows. I check in bios cannot detect hard disk. How to solve...
Open your laptop and and fix the hard disk cable.After this start laptop and check the bios if HDD detected then select boot device and select first boot device is Hard disk.Save the setting and restart the window.You are able to open your window. But If Hard disk drive is not detected change data cable,power cable of Hard disk.If hard disk is detected in bios follow upper rules. And if it is not detected again you should walk into Hard disk repairing center and check hard disk there.
Jun 07, 2011 | Computers & Internet
I have a laptop which it does'nt detect the hard drive what is the problem?
The problem could be one of these -
The hard disk needs reseating to make proper electrical connection.
or
The hard disk is faulty.
or
The BIOS has not detected the hard disk.
or
The hard disk controller is faulty
To determine the fault -
Reseat the hard disk and boot up the laptop.
Check the BIOS configuration - does it detect the hard disk. The BIOS may have a hard disk diagnostic, if so then run the diagnostic.
For a further hard disk test - remove the hard disk and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If the hard disk is OK then this computer will detect it as an external hard drive and you can open the folders and files.
If not then the hard disk is confirmed faulty.
To get the Gateway working, install a new hard drive and install Windows, the laptop's device drivers and your programs.
Sep 05, 2010 | Gateway 450ROG Notebook
Not detecting hard disk
first thing to do is to remove and reconnect the hard disk to the system. devices like hard disk not detected often is just a result of loose connections. if this will not work, may be a good idea to test another hard disk with your computer or test the hard disk on another computer to isolate if the hard disk will need to be replaced.
Sep 04, 2010 | Computers & Internet
P4pe x cannot detect hhd drive
If the BIOS cannot detect the hard drive then :-
1. The hard drive data cable or power connector may not be inserted properly.
2. The motherboard disk controller is faulty.
3 The hard disk is faulty.
To test the motherboard disk controller, connect another hard disk to the motherboard and go into the BIOS to see if it detects the hard drive.
If it detects the hard drive, then the other hard drive is faulty and need to be replaced.
Another way to test the "faulty" hard drive, connect the hard drive to an USB hard drive adapter and plug it into a working computer's USB port. If this computer sees it as an external hard drive and you can open the folders and files the the hard disk is OK, and the fault is a faulty disk controller on the motherboard.
Jun 14, 2010 | ASUS P4PE-X Motherboard
A disk read error occured and keep on re-start
Please check that the hard disk is connected properly. If you know that the hard disk is working, check whether it is detected or not. If it's not detected, you'll need to recheck it again with the power supply. If possible, try it to another Laptop so that you can make sure that Hdd isn't the culprit. In case it's detected and the problem still persists, repair the operating system installation, this will definitely solve your problem. Good luck.
May 26, 2010 | Dell Latitude D600 Notebook
My computer worked properly. but at once my IDE devices started giving troubles. my 2 IDE devices are not detected at the start up.
The BIOS will have trouble detecting faulty IDE devices, eg the hard disk etc.
To check if the IDE devices are faulty, connect the hard disk to an USB hard disk adapter and plug it into a working computer's USB port, if the computer detects it as an external hard drive and you can open the folders and files then the hard drive is OK and the fault is the disk controller. If the hard disk is not detected then it is faulty and a new hard disk is needed, Windows installed on the new hard drive together with the device drivers and your programs to get an fully functioning computer again.
Sep 01, 2009 | Intel D865GBF Motherboard
Acer aspire one hard disk cannot read
Check the BIOS configuration for the hard disk, if the BIOS does not detect the hard drive then the hard drive is faulty or the disk controller is faulty.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. This computer should detect the hard drive as an external disk drive. If this computer cannot detect it and/or cannot open the folders etc. the the hard drive is faulty.
Then you need to install a new hard drive in the Acer and install Windows, the device drivers and your programs to get the laptop operational again.
Aug 19, 2009 | Acer Aspire One D150-1587 Netbook
Bios not find hard disk
If the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 24, 2009 | Acer TravelMate 2303LCi Notebook
System not detecting hard disk
is that a sata drive or ata?...if ata, try to change the IDE Cable that connected to your Hard drive?..
Feb 26, 2008 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Ibm hard disk not detected
do u want to install the hard disk or do u want to setup raid? getting the hard drive to be detected has nothing to do with setting up RAID.
Dec 24, 2007 | ASUS Intel 440BX Chipset CUBX-L...
IBM X236 Server Logo
312 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
