Question about Grundig GU19WDT 19 in. LCD TV
My grundig lenaro has sound but no picture - Grundig GU19WDT 19 in. LCD TV
  • Grundig Master
  • 2,098 Answers
Hi Mike,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 06, 2011
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: I have a Grundig Lenaro
Hi.
If the flicker is given by backlight, then the problem is either inverter board or power adapter. In some case a defective PC board may also be responsible. A defective inverter is the part that gives this problem more commonly.
Parts for most models can be purchased online entering model number in one of the websites below:
ShopJimmy
PartStore
Here a summary description showing how to test inverter and PSU.
Parts must be tested before replacement. The job must be done by a trained technician.
Call Grundig to check warranty status or to get a quote on repair.
See: Welcome to Grundig
Regards.
Ginko.
Posted on Oct 31, 2010
  • 159 Answers
SOURCE: i have grundig lenaro 32"tv
Sounds like you're only viewing analogue channels.
Go into Menu and find Inputs and select & choose DTV. This will restore reception of Freeview (Digital TV) channels.
Posted on Sep 26, 2011
My Grundig Lenaro TV showing power but no image no sound and when I m using the remote is blinking but still not working pls help
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 22, 2016 | Grundig Televison & Video
Picture blurred
Check and replace its backlight inverter board, or damaged backlight CCFL lamps. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
Nov 02, 2013 | Grundig Lenaro 26 in. LCD TV
Picture break up
There is some loose contacts to the connection wires inside the TV. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 27, 2013 | Grundig Lenaro 26 in. LCD TV
How to manually turn the subtitles off on a grundig lenaro tv
Turn subtitles language to... turk... o another language ...Solved problem!
Dec 03, 2012 | Grundig Lenaro 26 in. LCD TV
Grundig Lenaro tv: White line appearing on the screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 16, 2017 | Televison & Video
My grunig lenaro 32inch screen freezes whilst on channel sometimes in minutes,sometimes after an hour and I have to switch off /on to proceed- what do I need to do to fix it?
Hello
It is due to its mother board fault. Digital signal processing section hangs up. There is no repair other than replacing the main motherboard. OK.
Jul 18, 2011 | Grundig Lenaro 26 in. LCD TV
Hi, My Grundig Lenaro tv keep freezing every time I try to change a channel, I have to turn it off and on with the button on the tele (not remote) to get it going again... any idea what that could be? It...
Hi. I have had the same problem for the last 6 weeks on my Lenaro 32"
Have contacted the Grundig Support and they are balaming it on the Digital Receiver. They say that the receiver component is made by Beko and thay have carried out an Over The Air upgrade which has caused this problem. Grundig contract out their services as this is just a trading name.
Their support is not willing to do anything and say that it is down to Beko.
I am now trying to get hold of Beko. After that I am going to contact trading strandards and Watchdog.
Apr 28, 2011 | Beko 324250WN 28" TV
I have grundig lenaro 32"tv
Mar 30, 2011 | Grundig Televison & Video
Need software upgrade
Contact Grundig directly for available updates. Check their website & download directly if available.
Nov 07, 2009 | Grundig Lenaro 26 in. LCD TV
Grundig GU19WDT 19 in. LCD TV Logo
442 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
