Question about SanDisk 2GB Memory Stick Micro M2 Memory Card w/Memory Stick PRO Duo Memory Card Adapter
My usb memory stick is write protected,how do i remove that?
  • 1,591 Answers
The adapter has a tiny switch on the side opposite the notch near the pins.
The switch needs to be towards the pins, not away from them.
Posted on Apr 06, 2011
My memory stick is showing write protected, how do i remove it, does not even wamt to format
hi thembi.
Go to My Computer and under Devices with Removable Storage look for your cardreader; right-click on it and click Properties. In the pop-up box, sometimes there's an option to Remove write-protection. Change the status of this option and try again. Remove your memory stick from the drive.
How to Format A Write-protected SD Card/USB Drive/Pen Drive ...
or go to this link and have a read up.
memory stick is showing write protected Google Search
Nov 17, 2017 | Electronics - Others
How to remove write protection from sony memory stick pro duo
There should be a small plastic catch on the side of the card which allows you to write protect the memory stick pro duo. It should have an image of a lock or say locked next to it, if it is locked you won't be able to write to it. Slide it to the unlocked position using a fingernail or a paperclip.
Apr 29, 2015 | Sony Electronics - Others
Hii sir pls help me mine kingstone data traveler 2gb is write protected so how shall i remove write protected?
Copy all the files onto your 'C:' drive.
Spend $9 to buy a new 2GB USB memory-stick.
Copy the files to the new memory-stick.
Take a sledge-hammer to the old memory-stick -- to prevent anybody else from reading your files.
Oct 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
When ever i try to copy a file on to my pendrive ,a file pops up saying that it is a write protected drive .how am i to remove this write protection?
try this one, hope it will work on your memory stick coz i tried this and i was able to format my write protected memory stick smile.gif
use a computer with XP OS.
right click 'my computer'
select 'manage'
then select 'disk management' to format ur memory stick. but sad to say, all data will be lost, am pretty sure you know it
Jun 10, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Hey gurus! my memry stick has a write protect. please remove it.!
There is a little grey button on the side of the stick. Push it up or down.
Oct 03, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
How to remove usb write protection with notebook
Are you having trouble writing to a USB memory stick and you get a message that the USB memory stick is write protected?
Some memory sticks have a small slide switch which you can select to write protect the data on the USB memory stick.
Jun 18, 2009 | Acer Aspire 4720 Notebook
Cant format
you can remove the write protection status by inserting it to your camera and in the preview mode click the button menu, in that scroll down for options and you can see there the option for protection on or off. toggle that option.thanks for using fixya!. please dont forget to rate my solution.
May 28, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
How do i remove write-protection from MemoryStickPRODuo from psp?
1. Remove memory stick from psp
2. Plug in usb cable and start usb connection
3. Insert memory stick and now you should be good
For some reason you might have to repeat these 3 steps everytime you want to access your memory stick
Hope this Helps
Apr 18, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
PSP Sony memory stick has write protection how do I remove this
You should have a small notch on the memory chip itself you just need to switch that off. look closely cos this might be very small.
Feb 22, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
USB Write Protection Hi, I am trying to copy/delet files from/to a USB stick. window says: " The disk cannot be written to because it is write protected. Please remove the write protection from volume USB...
Put the memory card into the SD adaptor and turn the white switch on the left of the card in the opposite direction.
See if that will work.
You may have to turn your phone off and back on again as well after reinserting the card back into the phone.
Nov 19, 2008 | SanDisk 2GB microSD Memory Card
SanDisk 2GB Memory Stick Micro M2 Memory Card w/Memory Stick PRO Duo Memory Card Adapter Logo
224 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
