Question about HP LaserJet 2300 Printer
How do I reset the default paper tray for an HP laserject 2300n?
  • 85 Answers
In the ,,paper handling " menu you can select the tray
Posted on Apr 06, 2011
How do I change the default on my HP P30005dn to Tray 2?
Normal default on HP is tray 2, however if you do not have that tray set for plain paper letter size the printer will default to whichever tray has letter plain paper installed. You should also check your print driver default settings to ensure that tray 2 is set as default tray.
Aug 14, 2014 | HP LaserJet P3005dn Printer
Mx2300n try to print envelope from bypass tray but error says
Try putting the paper in the 2nd paper tray and then go to system settings then paper tray settings and change to paper for that drawer to envelope and maybe COM10. Then try to print on the envelopes.
Dec 11, 2011 | Sharp MX-2300N Color Copier
We have a HP laserjet 2420 and when I try to print anything, it shows "load tray #1, and so I have to press the check mark button twice for it to print from tray #2. I want it to default and to print...
Becouse the tray configured in the printer is tray #1 so it serching the paper on tray 1 first you can set it the default tray by the menu on top of the printer.
Dec 13, 2010 | HP LaserJet 2420 Printer
My MX-2300N Printer/Copier/Scanner is having a copying error. The main screen constantly says "Remove paper from center tray, yet there appears to be no paper in the ccenter" tray. I have reset the machine...
Please verify that no printer paper is jammed or partially fed into the printer. If you have one or more pieces of paper stuck in the printer these will need to be manually removed before the printer will print again.
Aug 06, 2010 | Office Equipment & Supplies
HP LaserJet 4200 - need help resetting default tray selections
Are you using Window 7 64 bit or 32 bit? Re-install drivers appropriate for that version of your operating system. Also look at the "Paper Handling" section in the printer menu. Be sure both trays are set for "Plain" paper.
Jul 20, 2010 | HP LaserJet 4200 Printer
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
Hp P4515n - Paper Handling for tray-2 only, gives
I just ran into this same issue with an HP LaserJet P4015n. Worked with HP and the resolution ended up being the following.
Hopefully this will work with the P4515n printer as well.
1. Open EWS page (printer page) in Internet Explorer.
2. Log into printer as administrator
2. Click on Settings tab, Configure device, System Setup
3. You will find Tray Behavior
4. Change tray 2 model to Standard Tray.
This should give you the standard options for the Tray 2 size or default to the size detected.
Aug 20, 2009 | HP P4515n LaserJet Printer
HP Laserject Printer/Copier
first u must diagnostic the problem to see if the problem from the drum unit or the fusser unit by stop the printer in the middle of print and remove the paper then u can see if the smudge appear it well be from the toner if not then the fusser faulty
Mar 26, 2008 | HP LaserJet 1200 Printer
HP LaserJet 2300 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
