Question about Lite On DH-4O1S Blu-ray Burner
When I installed the Lite on Blu-Ray drive I plugged it into a SATA port on my Motherboard the computer would not boot. I have 4 SATA ports on my MB and I have my HDisk drive in the first port and my Sony DVD drive in the 2nd one, both working fine, I tryed unplugging the Sony, and replacing it with the Lite on...still won't boot, checked the BIOS to make sure of the boot priority it checks out ok. I also have a SATA card in a PCI EXpress slot for a 2TB external drive. I mention this just FYI, I do not think this card is the issue. It seems that as soon as I plug the Lite On into any SATA port the computer will not boot.
  • Lite On Master
  • 27,725 Answers
This might be a driver issue or a registry problem
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 06, 2011
    Guru:
  • 1,705 Answers
Check the jumper setting on your drive the most common format for drive connections in old money was:-
IDE 0 - HDD 1 - Master
HDD 2 - Slave
IDE 1 - DVD1 - Master
- DVD2 - Slave
Not entirely sure if SATA configuration on m/boards are the same as the old PATA but would imagine the jumper principles are.
WD1001fals as slave
SATA Hard Disk as a Slave b> An SATA hard drive is an internal hard drive that connects to your computer's motherboard. It is even possible to connect multiple drives to the same computer; however, only one drive can be the master hard drive; the other(s) must be slave drives. This is because the master drive has the operating system installed and must be used to boot up the system. When installing a new SATA hard drive onto your computer, you must set it as a slave.
Power down your computer and disconnect the cables. Remove the Phillips screws from the exterior of the computer case and slide the case open to expose the interior of your computer. Identify the hard drive at the front of your computer, then slide the new SATA drive in underneath. Insert the smaller power cable into the power port on the side of the SATA hard drive. Follow the power cable running out of the current hard drive and insert it next to it on the motherboard. Pull out the ribbon cable, which has three different connection ports: one on each end of the cable and one in the middle. The connection port on the middle inserts into the slave drive and is slightly different than the other two ends (the pins built into the port are in different locations than the other ends). Insert the middle connection port into the ribbon port on the back end of the SATA hard drive. Plug one of the opposite ends of the cable (doesn't matter which one) into the SATA connection port on the motherboard (your current hard drive is inserted here). Once connected, this completes your slave drive connection. Second SATA 2 Hard Drive as a Slave b> Installing a second hard drive in your desktop PC or notebook is an option used to increase hard disk space without losing or transferring the data from your original hard drive. Using this method not only increases hard disk space, it also increases the virtual memory space for the Windows operating system, increasing operational efficiency. One of the ways in which a BIOS can recognize the second hard drive is to boot it as a slave drive, with the primary hard drive booted as a master drive.
Turn the PC off and remove the desktop chassis. Refer to the pin connector diagram. This is displayed on the sticker, on top of the hard drive, for the position of the slave pin. Place the plastic connector on the slave pin as detailed on the diagram. Connect the hard drive to the power and IDE/SATA cable. Ensure the other ends are connected to the motherboard. Use the screws to mount the drive. Replace the desktop chassis. Turn on the PC. Enter the BIOS, by default this can be done by pressing F2. If this does not work consult your motherboard manual. In the BIOS, press right until the boot device tab is highlighted. Set the slave drive to boot following the primary drive. Read the bottom line and use the relevant key to save the settings. Restart the PC.
Hope it helps.
http://www.pcmech.com/article/installing-a-hard-drive-step-by-step/ Installing a hard drive.
Jan 24, 2013 | Western Digital WD Caviar Black WD1001FALS...
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
May 12, 2010 | Intel D102GGC2 Motherboard
Sata isnot reconized in bios nor will it install xp on a sata drive it starts to load all files then when to enter to set up xp home sp-3 the board is new been shelved then it gives windows cannot be...
Look up the specs. on the mb and find out if it supports sata1 or sata2 drives.
Your motherboard should have four sata ports and you may want to change to another port.
Also, you may need to format this sata drive, booting from the ide drive. Windows takes a long time to format but may be the only answer.
Last, make sure your bios settings are sata as raid.
Hope this works for you, its a pain.
Nov 19, 2009 | PC Chips MB PCCHIPS K8T800 M860 V1.0...
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Unable to complete full boot with SATA Blu-Ray Player installed
Try reducing the size of the raid to under 2TB. If the system install, then try expanding the raid.
Jul 10, 2009 | Gigabyte GA-MA790X-UD4P Motherboard
Sata drive cable positons on motherboard
The plug in sata ports do not matter for order unless you are plugging into ports reserved for RAID. Check your motherboard manual to see if any ports are reserved for this setup. If so change any cables out goint to those ports. You will also need to enter bios and make sure SATA is enabled in your settings. Once you have done this you should be able to boot and your drives will be auto detected. Hope this helps.
Jun 03, 2009 | Foxconn G33M Socket LGA775 motherboard
2 Sata Hdd not supported
Hi rafiqbrush, let me go over a few things for the P5B MB.
There is a total of 5 serial ATA SATA drive ports on the board & one ATA IDE/PATA port.
The 4 main SATA ports are numbered, 1 - 4. Your primary SATA drive must be connected to SATA port 1. Your second SATA drive must be connected to SATA port 3. See page 2-26 in your manual.
All SATA drives are seen as master drives. Once the two SATA drives are connected (As per manual), boot to the bios main menu.
At the main bios menu make sure your bios shows both SATA drives. Than go to the bios title "Boot". Make sure your primary SATA drive 1 is listed in the boot order. Save & exit the bios. (SATA drive 1 must have windows installed on it).
Link to Asus P5B web site;
http://support.asus.com/download/download.aspx?modelname=P5B&SLanguage=en-us
Good luck rafiqbrush!
Thank you for using fixya.
Mike
Dec 10, 2008 | ASUS P5RD1-VM Motherboard
Computer will not boot with Pioner Blu-Ray BDC-SO2 installed.
Hi stokarek,
With respect to SATA drives. All are master drives. As you mentioned if there is a fight between drives the trouble can be settled in the bios. I gather the WD160GB drive holds windows on it & the WD is connected to SATA 1 port. Enter you're bios & go to the Boot section. Open you're manual to section 2.6 boot menu page 2-32. Make sure you're WD is the only hard disk drive listed. After you add the Blu-Ray (To SATA 2 port), (its pin setting should be set as master. Than go back to the boot menu & make sure the Blu-Ray drive is listed under the WD drive.
Keep in mind for the future that if you want to boot to the Blu-Ray drive you'll need to press the F8 key at boot up. Windows select boot device window will open & high-light the Blu-Ray & press enter so the Blu-Ray will boot. Windows should no longer stall. If this does not work try switching the pin on the blu-ray to slave. (I'm not sure there is even a pin setting on the blu-ray drive. Never the less the bios boot order is the boss.
Link to Asus main driver site for ASUS M2N8-VMX
http://support.asus.com/download/download.aspx?modelname=M2N8-VMX&SLanguage=en-us
Good Luck stokarek!
Mike
Jul 08, 2008 | Acer AOpen MX 3ZA (91.88110.101)...
Lite On DH-4O1S Blu-ray Burner Logo
90 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Computer Links
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
