Question about Electric Garden
I have a promble,i want my ligths to have a switch,but i dont now how to connect the wires from the switch
  • 4,336 Answers
This is difficult to answer, as you did not mention what you are working on. So, I presume house lights and 110 volts.
TURN OFF THE POWER. There should be three wires going to the light, black, white, and ground.
The black wire is the power wire and it is what gets cut and the switch installed to connect the cut black wire.
If you have any question, get an electrician to do this, as electrocution exposure is what you risk.
Posted on Apr 06, 2011
  • 396 Answers
All lights need 2 connections. A Positive (+) and a Negative (-). If you cut just one
of these and put your switch inline you will be fine. Most often the Grounded wire
is switched so that if the switch shorts out, there wont be a dead short, that could
damage the electrical circuit of the device. If ground shorts to ground, it's no problem.
If Positive short to a Negative Ground-Big problem. Since this is an electric saw, most
likely the chassis is grounded. Also, this may be a set of AC (Alternating Current-just like in your house)lights. The same switch install should work here also. Here is a quick diagram of how to wire up
either 1 or 2 lights. Sorry it looks rough but it should work for you.
Haveing prombles with lighter it dosent work it dont charge
check all your fuses in cab and under hood, if all are good check if wire has fallen off the back of lighter housing.
Dec 19, 2012 | 2004 Ford Explorer
Brake light dont work, change bulbs, fuse, bake switch, and has power still dont work
You have a failed brake lamp relay,this is located at the back right hand in the trunk at the quater panel.
Mar 12, 2012 | 2003 Honda Civic
Radio wiring code for 1987 mercedes benz 300. With aftermarket radio the windows switch ligths blinks and have no instrument ligths.
Hi, the aftermarket stereo does not use the illumination wire. You must tape that wire off (purple/gray). That wire is either connected to the wrong place or is touching chassis ground and causing your instrument lights to dim.
Connect the stereo's red wire to the car's black/yellow wire; and connect the stereo's yellow wire to the car's red/white wire.
1987 Mercedes 300E Car Stereo Wiring Chart
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Black/Yellow
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Purple/Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre Dash
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Car Audio Rear Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Black
Right Rear Speaker Positive Wire (+): Green
Right Rear Speaker Negative Wire (-): Black
Sep 13, 2011 | 1987 Mercedes-Benz 300-Class
I just bought two flood lamps to fit to the bumper of my 95 jeep wrangler, how would i wire them to a toggle switch?
  1. 2-wires on each fog ligth
  2. toggle switch 2-hook up
  3. okay run hot wire from battery to one side of toggle
  4. on fog ligths one wire migth be white or black
  5. take one of the wire on fog ligth (white)&other fog ligth (white)wire
  6. take a wire hook both white wire from both ligths an hook to this wire an run it to the other side of toggle
  7. black wire on ligths hook them to ground
  8. after you hook the ligths up an they work it best to put a fuse connector between one of the wires on toggle
Dec 06, 2010 | Jeep Wrangler Cars & Trucks
I change the turn signal lever I took apart unplunged everything carefully put everyhing back together carefully but as I was workig on it I heard my horn honk twice I look no bear wires anywhere finish...
your security system is activated. try turning the key on let set for 10 minutes turn it off then start. on some models it has to be done 3 times on off on off on off start. 10 minutes each time
Jun 22, 2010 | 2000 Chevrolet Tahoe
Brakes ligths dont work
bad brake light switch
Sep 04, 2009 | 2003 Chevrolet S-10
316 reversing ligths
Hi miguel_mitie, the reverse light switch is on the right hand side of the gear box and has a square 2 pin connector, it may also be worth checking the wriring in the rear harness by the boot lid hinges as the wires have been known to break
Jan 23, 2009 | 1996 BMW 318
Electrical fan connection
Firstly, yes the fused spur should be earthed. You should wire from the fused spur to the fan L,N & E.
Your light switch should be in line on your light live supply wire.
If you wish to use the light switch to turn on the light and fan at the same time you should also run a live switch wire to the fan L1.
This should FixYa.
Please remember to rate this solution.
Dec 09, 2008 | Dryers
How install fog ligths
you will have to make cut outs in the bumper and thats it unless you want to bracket the to bottom of the bumper/ Please rate my response thank you very much
Dec 01, 2008 | 2001 Dodge Dakota
I have some doubts about my VRCD400-SDU autoestereo installation, could you please send me an example of how should be connected the stereo wires? Already I have completed the connection but I dont...
Here is a link to the owners manual for your radio, it should have all the information you need in it for wiring it properly.
http://www.roadmasterusa.com/forums/index.php?act=attach&type=post&id=46
Aug 21, 2008 | Audio Players & Recorders
Garden Logo
83 people viewed this question
Top Electric Garden Experts
Steve Oakes
Mike Squire
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
