Question about Tefal ActiFry Deep Fryer
Paddle turning, not making correct noise, no heat
My bread maker paddle is turning correctly, but it is not mixing the ingredients. We put liquids in first. The first time we used it, it was perfect?
You may have too dry or too watery a batter. Check your ingredient mix for accurate measurements.
Recheck the unit without ingredients in place to be absolutely sure you have the paddle seated correctly. Although most are designed to make it very hard to put the paddle on incorrectly, old dough or batter may harden in place and keep the paddle form fully seating correctly.
Mar 01, 2015 | Regal Ware Kitchen Appliances - Others
The paddle on my kitchenaid won't turn. It just makes a humming noise. Any suggestions?
Is the humming noise the sound of the motor straining to turn without moving (it won't last very long like that) or the sound of the motor turning but not operating the paddle?
Dec 21, 2014 | KitchenAid Food Mixers
Why won't paddle turn??? Everything else works
Unless the bin sits correctly on the mechanism below, the paddle will not turn. It needs a very slight twist sometimes to sit it correctly. Or perhaps the paddle has some old bread still stuck in it from previous usage, pull it off (it just lifts up) and give it a thorough clean. I assume it has been working correctly?
May 28, 2014 | Kitchen Appliances - Others
I have a Black & Decker B2500C model bread maker - used it this morning for a white loaf and it worked fine. Tried to make a cinamon raison loaf a few hours later ("sweet" course) and the...
maybe a striped gear in the bread maker or the drive pin on the paddel shaft,,
worst this i can think of is,,,,its putting you on a diet "shoot the thing?"
Nov 28, 2010 | Black & Decker Bread Machine
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
I have the Black and Decker All-In-One Deluxe Automatic Breadmaker B1600 Series and it's worked well for years. Today I put the ingredients for a loaf in the bread pan and when it started to mix the paddle...
There is a sealed bearing in the bottom of the bread pan. The paddle sits on the sealed bearing shaft. Over time the bearing begins to fail and the paddle does not turn freely or it may even freeze up. If you are sure everything is installed correctly this may be the problem. See if the paddle moves freely by hand and is not really loose. Sealed bearings can not be replaced. Eventually you will need a new bread pan. Sorry Hank
Apr 21, 2010 | Black & Decker Bread Machine
Blade in my Kitchen Pro 6725 does not turn
You probably need a new belt. Either that or as a result of adverse temperatures in that cabin the motor is gone.
Unfortunately Regal does not make bread machines any more and that belt is very difficult to find.
Maybe if you can measure it you an find something close.
What a pity...
Hank
Sep 03, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
My kenmore series dryer is making noise as it runs. It heats but makes a noise as if coins are in the dryer. I cannot see anything from inside the dryer, is there a way to remove the front face of the...
there's 2 basic ways to removing the front panel. First is 2 screws at the very bottom of the front panel, when removed the panel can be lifted and un-hinged from the top. The other is by using a flat screw driver and prying the top up at the edges on the front side the removing 2 screws or hex screws located inside the front panel toward the top. make sure you undo door swich wires before completely removing the front panel. then in the middle of the drum on the inside of it either 1-3 screws hold the drum to the back. Remove belt first then screws then pull drum straight out. The noise may be from your rear drum bearing or coins have gotten in the paddles of the drum(inside) paddles can be removed. I had coins in one of my paddles, made 60some cents lol at same time found perfctly round lint balls. Good Luck
Mar 02, 2009 | Kenmore 63942 Dryer
Hotpoint side by side noise
Have you made sure that the ice tray/box is inserted correctly? By lifting up and inserting the box until it goes in all the way. Also, check the ice chute from the inside and look for any obstruction such as ice formed/melted causing the blockage. Once you correctly insert the ice tray back in, try the ice button to reset the paddle drive. Also, these icemakers are slow to deliver when the ice bin is low in ice. FYI, if you stack too much frozen goods underneath the area below the ice tray, the paddle drive mechanism will sometimes come into contact with the food packaging. The wrapping from the packages can get caught under the paddle drive and creat a problem by slowing it down. Check and clear it. Be sure to unplug the refrigerator before you do this. Let me know if this helped.
Oct 28, 2008 | Hotpoint HSS25GFP Side by Side...
Tefal ActiFry Deep Fryer Logo
44 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Gerry Harvey
Gerry Harvey
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
