Question about Vacuums
Motor runs but shaft doesnt turn - Vacuums
Belt keeps coming off- Dirt Devil Breeze Cyclonic Bagless Upright Vacuum
Turn it upside down and switch on the power briefly to see what happens to the belt while running. Some vacuum cleaners have a wire guide of some sort to keep the belt running true, but yours may not have it. The end of the brush roller that connects to the belt could be worn uevenly, causing the belt to ride off the motor shaft. The motor shaft might not be parallel to the brush roller.
Jan 18, 2014 | Vacuums
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
Beater bar motor quit, now the main motor quit. Replaced the on/off switch. still nothing
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Vacuums
Power is not coming on
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
Dc22 motorhead belt replacement
sounds like you may have debree caught on the belt shaft, causing motor to heat up and cease to work until cooled off. check motor shaft where belt attached to run wand head.
Apr 14, 2012 | Vacuums
Have a two clear view probably 3 year old belts
sounds like the motor bearings are bad. when those bearings wear out the motor shaft doesnt stay strait and allows the belt to track off.
Jan 16, 2010 | Bissell CleanView 3596 Bagless Upright...
Bissell Pro 2X. The brushes spin as soon as I turn it on but only spins for an instant then it quits spinning. The vacuum stays running. the handle is down.
it might be the drive belt slipping if the unit is off then the belt is locked onto the belt and then when the unit is switched on the belt slips and if its loose it doesnt hold the belt to the motor shaft
Nov 03, 2009 | Bissell 9200 Upright Vacuum
Motor runs,brushes turn,no suction
either the fan on motor is broken or off shaft or the unit is plugged,if its plugged the motor will sound like its running faster than usual
Oct 01, 2009 | Vacuums
Motor not turning
Don't forget, the agitator bursh doesn't work when the vacuum is upright. Maybe that is your problem.
Apr 01, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Maybe a second belt or pully.
If that spindle you are talking about is the motor shaft, then the motor is bad. Usually the belt goes from the brush roll to the motor shaft. It may help if we knew brand and model number.
Dec 04, 2007 | Vacuums
Vacuums Logo
88 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
