Question about kawasaki Garden
I am working on a toro zero turn mower with a Kawasaki FH601V motor. The motor will start up and and idle fine however when you throttle up it boggs out. Air filter and carb is clean. Any help would be greatly appreciated.
  • kawasaki Master
  • 4,340 Answers
This sounds like a main jet issue. What is a concern is I presume it was okay, before, so that would mean jet restrictions....
Try turning main jet richer or leaner by 1/4 turn and test again...Otherwise, carb surgery will be needed.
Posted on Apr 06, 2011
How do I engage the bagger on a zero clearance toro mower
That's should be something I imagine is covered in your owners manual. Why not try going on their website and downloading the manual in pdf format so you can learn.
Sep 27, 2014 | kawasaki 48'' Toro Com Zero Turn Lawn...
How do I engage bagger on zero clearance
That should be covered in your manual. I'm not sure what a zero clearance mower is actually, are you assuming and making up a name for it?
Can you jump start a toro zero turm mower with a car battery and jumper cables?
Better to not jump them can burn the leads up. Pull it out and slow charge it
Jul 17, 2014 | Toro NEW 42 TIMECUTTER 21.5 HP KAWASAKI...
Toro zero turn mower with Kawasaki 691v 24.0 horse motor starts cutting out and smoking after running for about 20 minutes.
Check the oil to make sure you don't have gas getting in your oil. If that's not a problem then you may have a leaking head gasket.
Sep 29, 2013 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Toro 52" deck with 19hp kawasaki engine runs fine when not under a load, when blades are engaged the throttle constantly goes up and down. I am assuming it is a governor problem, and have made sure the...
Could also be a carburetor issue, remove air filter and make sure that its not clogged, even try running it for a short time under the same load. If problem persist tske it to rdpair shop bc there are several other issues it could
Aug 19, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have a 2005 Dixon zero turn mower the motor is hard to turn over but once it starts turning it turns fine when the motor starts it will only idle and not accelerate it has a 14.5 hp Briggs and Stratton...
sounds lie it's starving for gas.
Does this engine have a fuel pump or is the gas gravity fed???
Some engines this size do have fuel pumps.
I'd also take the bowl off the carburetor and check the Jet.
Aug 10, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I just bought a new toro ss5000 22 hp kawasaki and it will not start, has gas, oil level seems ok turns over fine.
there has to be a safety mechanism you are over looking. check that you have spark. if not then it is a sensor, if so then check you have fuel flow. being brand new i am thinking you are just over looking something simple. if all else fails try a small amount of starting fluid through the carburetor and see if it starts and runs on that. I know that sometimes after I rebuild a unit it takes some "help" to get it going then it runs and works fine
Feb 17, 2013 | Toro TimeCutter SS5000 zero turn mower
Garden Logo
432 people viewed this question
Top kawasaki Garden Experts
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
dannydoesita
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
