Question about Rio Karma MP3 Player
Rotary Wheel Failed
I have had my Rio Karma player for about 3 or 4 years with little or no problems. Just last week the 'ROTARY WHEEL' failed. The fault is - works when turning ACW but jams when turning CW, also seems loose and pushes into the body of the device. Can this be repaired or a replacement supplied by anyone ?
    New Friend:
  • 10 Answers
Please e-mail me at firehouse777@cableone.net
I can repair your player for you or sell you the part you need. thanks David
Posted on Jun 17, 2009
This guy does repairs/modifications
http://myworld.ebay.com/number66
Posted on Sep 02, 2008
Drill runs and rotates but does not hammer
Need more information - make / model
It sounds like you probably need a service kit - the orings are worn and it has lost compression. If you provide the make / model I may be able to direct you a little better.
Feb 23, 2015 | Drills
Maytag Dishwasher Model DWU7702AAB The dishwasher is not cleaning the dishes, leaving a **** on everything. Looks like soap residue or something is clogging it. How do I remove the rotary wheel at the...
Not sure about the rotary wheel at the bottom for the drain but the problem could be the rinse aid pump that has failed.
Check out this parts diagram, it may help
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=DWU7702AAB&mfgModelNum=&fkMfgID=1
Aug 04, 2011 | Maytag Dishwasher
How do I change parts, i.e. from grinding wheel to sandpaper wheel?
There is a collet type on most rotary type tools. This is located on the end of the tool where the grinding wheel is inserted in the device. The collet has a normal thread pattern. Turn counter clockwise to loosen the collet. Some time the collet gets tightened to toght and then just take a block of wood and gently hit the collet to see if this will loosen the bit.
Mar 14, 2011 | Craftsman Single Speed Rotary Tool
Transfer error on rio karma
Feb 10, 2009 | Rio Karma MP3 Player
Rio karma hard drive
Hi. I use this adapter for RCA Lyra MP3 players and it could be the same for your Rio Karma. To be sure that it is a mini IDE connector, open the karma up by going here http://www.takeitapart.net/archives/rio-karma/ and if it is a mini IDE then you can go to Ebay and search for item # 230283935161. I hope this helps.
Aug 24, 2008 | Rio Karma MP3 Player
Rio Karma Battery
Try looking at Ebay item # 350057466979 or simply search for rio karma battery and you will find what you need. Replacing is as simple as taking some screws off and opening the rio. Don't have someone else do it because it is a simple thing that won't be worth paying someone else to do it.
Mar 17, 2008 | Rio Karma MP3 Player
Can not copy files from Rio Karma to PC
Files can be copied to the computer from the karma although it doesn't work all that well.
You'll need to use Rio Taxi. I think you can get that if you connect the karma to your network using the dock then browse to the karma's ip address and get it. If not you may have to try and find a place to download it.
Nov 07, 2007 | Rio Karma MP3 Player
RIO Karma mp3
Dear Mr Thorburn,
I could not send you my quotation re. French leaseback, since I appear to have a wrong email address for you. Could you please urgently forward your email address to e (contact@solicitor.fr)?
Thank you.
Regards,
Fabien Cordiez
Nov 06, 2007 | Audio Players & Recorders
Id failure
If you still have the Karma, I would like to buy it for parts. Please reply to besweitzer@comcast.net
Thanks
Aug 08, 2007 | Rio Karma MP3 Player
Rio Karma freezing on startup. wont connect to computer.
WoW! thanks a million, I had tried everything to fix my wifes RIO and nothing worked! hitting it actually solved the problem!!!!
Sep 27, 2006 | Rio Karma MP3 Player
Rio Karma MP3 Player Logo
142 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
