I need to download a manual for the Samsung TV model no LE22S86BD as the transmitter has been switched to digital. I cannot fine the manual that came with the TV.
  • 1,591 Answers
For the manual, click the following link or copy and paste it into the address bar of your browser.
http://downloadcenter.samsung.com/content/UM/200709/20070907161605328_BN68-01182K-00Eng-0814.pdf
It can take a while for that to initiate and download.
Don't forget to at the very least, favorite the page so you can get back to it, or better yet, save the document to your desktop or documents folder for later use or so you can print it out later.
You will need to have Adobe Acrobat Reader to view it.
Easier still, you can right click the link, and either "save link as" or "save target as" (depending on your browser) and save it directly then open the saved file.
Posted on Apr 06, 2011
How do i connect hammacher wireless speakers to a toshiba smart tv
Model of both the TV and speakers, please. For example, without the model of the TV how is anyone supposed to know which inputs/outputs it has?
Edit: Dan, Thanks for providing the model numbers. I was hoping the solution would be something simple like switching the audio from internal to external speakers in the TV settings. However, when I looked at the owner's manual http://support.toshiba.ca/support/ceg/manuals/LEDTV/40-50L3400UC_E.pdf it appears that the rca jacks you tried on the back of the TV are inputs for old VCRs, DVD players etc. rather than an output which would be needed to send an audio signal to your speakers. In this case you will need to use the DIGITAL AUDIO OUT on the back on the TV. In order to use this you will need to purchase an Optical Digital Toslink Coaxial to Analog RCA converter. Make sure it uses a larger Toslink connector and not a mini one. The Toslink cable will plug into the DIGITAL AUDIO OUT on the back of your TV and then be plugged into the converter device. Your white and red RCA cables will go between the converter and your speaker transmitter unit. In addition the converter will have a power adapter that needs to be plugged into a wall outlet. There may need to be some audio settings changed in the TV menu to get this to function properly. It's best to buy from a retailer with a good return policy just in case it doesn't work.
Hope this helps.
Dec 15, 2016 | Toshiba Televison & Video
How can i get local channels on my rca tru flat tv BD20TF10
The RCA BD20TF10 was manufactured before digital tuners (ATSC) were required. It only has an analog (NTSC) tuner so you will need a digital to analog converter box to watch most local channels. (These were the boxes available with the discount coupon as the ATSC broadcast transmitters were enabled.) Depending on the converter box model, use either the composite video input or use the RF antenna connection. If you use the RF output from the converter, you will need to set the TV to channel 3 or 4 (set the switch on the box to match). Then follow the directions for searching for channels with the converter box.
You may be able to find a low power analog station still broadcasting. However, you'd need to be close to the transmitter or have an antenna that is rated for a long-range signals. (Usually this will need to be an outdoor antenna with few obstructions between the transmitter and the antenna.) To scan for any available NTSC channels, make sure that the TV is set to TV mode. Then press Menu. Use the Up/Down arrows to highlight Channels and press OK. Select Auto Channel Search and press OK. You may need to confirm this step by highlighting the Start Search option and pressing OK. This will also let you add the appropriate channel for watching the signal from the converter box with the RF cable. The manual for this TV is available from Sears Parts Direct here: http://www.searspartsdirect.com/partsdirect/user-manuals/BD20TF10-Rca-Parts-Television-Parts-manual . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0312126.pdf .
I hope this helps. I'm not sure if the Menu feature is available from the front panel buttons. You may need a remote with a matching code to do the channel scan.
Sep 26, 2016 | RCA Televison & Video
Download Center: Download Software, Firmware, Drivers ...
www.samsung.com/us/support/downloads
Samsung ElectronicsEnter your product or model number and Samsung's Download Center allows you todownload the latest drivers, manuals, firmware & software.
ManualsOnline.com: Free TV and Video User Manuals
tv.manualsonline.com/
TV and television manuals and free pdf instructions. Find the user manual you need for your TV and more at ManualsOnline.
TV User Manuals, PDF Guides, Service Manuals and ...
www.retrevo.com > Manuals
Retrevo has links to download TV PDF manuals for more than 11249 products. Here are quick links to manuals for Philips, Samsung.
Toshiba: TV Manuals
www.toshiba-om.net/tv_manuals.php
Caring for our environment. In Toshiba's continuous efforts to preserve the environment, extended versions of the manual are made available to download from ...
Downloads & Manuals - LG
www.lg.com/uk/support/software-manuals
LG Electronics
Jan 27, 2016 | Televison & Video
How do I manually/automatically update the channels on my Samsung DNli DV3 TV?
Hi Hugh.
Please follow these instructions to manually/automatically update the digital (DTV) channels on the Samsung LE26R73BD.
Please use the following buttons on your Samsung remote control to navigate the on-screen menus:
- "D.MENU" - Opens/closes the on-screen menu (below the numerical key "0")
- DIRECTIONAL ARROW KEYS - To navigate up/down/left right through the on-screen menus
- "ENTER/OK" - Selects/confirms a selected option (in the centre of the arrows)
Automatic Channel Scan / Update:
1. Make sure you are in digital TV mode - Press the "TV/DTV" button on the remote to switch between analogue (ATV) and digital (DTV) modes.
2. Press the "D.MENU" key
3. Highlight "Installation" (first option) and press "OK/ENTER"
4. If asked for a PIN code, enter 0 0 0 0 using the numerical keys on the remote. If you have set a different PIN code, please enter your own code here.
5. Highlight "Select County" and press "OK/ENTER"
6. Use the LEFT/RIGHT arrows to select "UK" then press "OK/ENTER"
7. Highlight "Auto Scanning" and press "ENTER/OK"
8. Highlight "Scan Mode" and use the LEFT/RIGHT arrows to set the value to "Digital"
9. Highlight "Start Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 21 . . ."
10. Highlight "End Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 69 . . ."
11. Highlight "Start Frequency" again and then press "OK/ENTER" to start the channel scan.
Some of the options above will already be selected so will not need to be changed. I've provided the correct settings just in case they are incorrectly set. Note: UK Freeview stations are on channels 21 to 69 inclusive.
The scan will take a few minutes to complete and the progress will be displayed. When the channel scan is complete, the menu should close automatically and the TV will return to viewing mode. If not, press either the "D.MENU" or "EXIT" button to return to watching TV.
Manual Channel Scan / Update:
7. Highlight "Manual Scanning" and press "ENTER/OK"
9. Highlight "Channel Number" and use the LEFT/RIGHT arrows to choose which channel number you wish to scan . . .
UK Freeview stations are on channels 21 to 69 inclusive. In manual tuning mode, these need to be scanned one at a time. Please note, many of these channels are "empty". UK Freeview only uses 5 of these channels (called Multiplexes or MUX) or 6 if you have HD. I am unable to tell you which 5 channels these are as they vary according to whichever transmitter or repeater station your aerial is aligned to.
10. Press "OK/ENTER" to start the channel scan.
11. Repeat steps 9 and 10 for each additonal channel you wish to scan.
Please note: Manual scanning can cause some unexpected results - particularly if your aerial has a reception from more than one transmitter/repeater. For this reason it is better to use the automatical scan unless you have a specific reason for needing to scan manually.
Hopefully this will be all you need to update the digital channels on your TV. If you have any questions or need further assistance, please let me know.
Regards,
BElectric
Jan 07, 2011 | Samsung Televison & Video
I installed the FM transmitter module which came with my samsung LCD TV model LA40C530F 1R. I tried accessing the FM transmitter menu in order to turn the transmitter On and to set the frequency but that...
1. Press the menu button(green)
2. down arrow once - (a picture of a speaker should appear with sound written vertically next to it)
3. Right arrow once (selects the sound menu)
4. Down arrow till you see FM transmitter (down arrow 4 times on my TV. If you don't see the FM transmitter option in the menu then upgrade your TV to the latest software (details at the end of this help file)
5. Right arrow to get into the FM transmitter menu
6. select the "FM transmitter: off" line and turn it on (FM transmitter : on)
7. Change the frequency to to one that is not used by a radio station or has interference noise (get a radio and tune it till you hear the choosh sound with no beeping or clicking from lightning - then set the tv fm transmitter to that frequency using the up and down arrow keys and enter.
8. You should here your tv sound comming through the radio even if the tv sound is off.
If you need to upgrade your tv software then:
1. format a usb stick
2. download firmware.exe from"
http://www.samsung.com/za/consumer/tv-audio-video/television/lcd-tv/LA32C530F1RXXA/index.idx?pagetype=prd_detail&tab=support
3. click on firmware
4. click on "Upgrade File(USB type)" and download it to your usb stick
5. when the download is complete double click on the file and extract it to the usb stick.
6. eject the usb stick.
7. plug it into your TV and slelect software upgrade when prompted - I didn't loose any settings even though it warns you that you will (samsung are just covering themselves)
Sep 03, 2010 | Televison & Video
I need a instruction manual for samsung lcd tv model # LN-S4051D
You can download or view the manual at manualnguide.com.You may need internet explorer 8.0 for downloading.
Apr 07, 2010 | Televison & Video
Convergence problem
reset your tv with defaults settings.f chip and resstor blown then it need change.
Jan 06, 2009 | Philips 55PP9401 55" Rear Projection...
Hitachi TV
If your remote transmitter is multifunction, such sa TV; DVD; and VCR operative; You may be in the wrong mode. Press the TV function first and then try to change the volume. If you still have problems, the remote may be defective.
Nov 15, 2007 | Televison & Video
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
